Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
Thread: 818 performance comparison (by the numbers)
    Junior Member wildbill's Avatar
    Halifax, Nova Scotia, Canada
    Quote Originally Posted by snowphun View Post
    Where are you getting the price from? I have heard around $60k, which isn't too shabby for a cf chassis and solid fit and finish. Very interested to see how the 4C turns out.
    From the Top Gear article "It'll go on sale towards the end of this year and cost somewhere around £50k, which is a fair bit to swallow for an Alfa". Throw in a rough currency conversion and you're $75k USD +.
    You could build a fleet of 818's.....lol.
    Central CT
    Yeah, the world doesn't work that way, you can't just convert car prices in Britain to dollars. That "fleet" of 818s you build would be lacking to the 4C in many ways. What car isn't going to look expensive when compared to an 818 strictly for performance numbers?
    Senior Member FFR-ADV's Avatar
    NH
    The ATS 2500GT looks very comparable to a high performance 818 build:
    Frame Tubular Chassis With Integrated Rollcage With Honeycomb Panels
    Body Composite Bodywork With Carbon Panels
    Wheelbase 2.44 Meters (96.06 Inches)
    Overall Length 4.25 Meters (167.32 Inches)
    Overall Width 1.90 Meters (74.8 Inches)
    Overall Height 1.15 Meters (45.27 Inches)
    Dry Weight 980 Kgs (2,161 Lbs)
    Engine Rear Mid-Engine, ATS CP 4 Cylinders Turbocharged Flat Four 16 Valves, Double Electronic AVCS
    Engine Output 499.8 Horsepower (Possibly 551 Horsepower) And Torque TBD
    ECU MOTEC M600, Traction Control, Switchable “Manettino” Power
    Gearbox 6-Speed Manual
    Cooling System Front Aluminum Radiator With High-Efficiency Alloy Pipes
    Oil Cooling System Oil Cooler Radiator
    Lubrication System Wet Sump, Dry Sump Optional
    Drive Style Rear-Wheel Drive
    Clutch Single-Plate Race
    Differential Limited-Slip Differential
    Exhaust System Full Stainless-Steel Exhaust System
    Acceleration (0-To-100 K/Mh [62 Mph]) 3.3 Seconds
    Top Speed “Over 300 Km/H" (186.41 Mph)
    Suspension Type Front & Rear Independent Suspension W/ Aluminum Billet Uprights, Symmetrical Wishbone Arms, Anti-Roll Bars And Teflon Bushings
    Dampers Ohlins Adjustable Dampers
    Skid Pad 1.6 Gs
    Front Brakes 380 Mm (14.96-Inch) Rotors W/ 12-Pistoon Calipers
    Rear Brakes 355 Mm (13.97-Inch) Rotors W/ 12-Piston Calipers
    Read more: http://www.topspeed.com/cars/others/...#ixzz2ZiruMDlC
    Price: If you have to ask its probably not an option....
    Cheers!
    I agree, thats why the "rough exchange" was just a "rough exchange"....we don't have real numbers yet. The Detroit Free Press also says it weighs 2100lbs and $60k. I completely agree.....we can't compare these cars as a complete package, but from a straight track performance viewpoint you get a lot of bang for your buck with the 818. Either way, the C4 is very cool and so is the 818.
    I was just making a bit of a light hearted joke.
    Those brakes are huge on the ATS! And quite a lot of power on a 4cyl too.
