Results 1 to 12 of 12
Thread: Boyd tank
    Boyd tank
    I have the non-EFI tank and was wondering which bung is which? Pickup/sender?
    Horseheads, NY
    If I remember correctly, the pickup is closest to the sending unit, and you'll re-use one of the nylon plugs to block off the open bung.
    Look in the hole. You can see the tube for the pickup.
    Ok...well this may be another stupid question but any idea what kind of fitting I use? ...since its not the same kind of pickup as the factory tank.
    Quote Originally Posted by bbksv View Post
    That depends on if you are using the fuel lines and such from the kit or using aftermarket ones. Most who use the boyd tank use aftermarket fittings. Take one of the plugs to your local speed shop they can help you out. Also look at other guys build posts for ideas.
    Senior Member maczter's Avatar
    Feb 2013
    Xenia, OH
    The pickup is not open into the tank, you can see the tube. Both use a 3/8 NPT fitting. I used a 90 degree to -6 AN fitting, to braided hose to a 3/8 alum hard line ran to my fuel pump. On the return line since I did not need it, I used a 3/8 alum plug. Let me know if you want to see pics.
    FFR HR #530
    Race car theme, Tim Whitaker roll bar, Autometer Autolite Gauges, Satin Black, SBC 383/700R4, 8.8 rear with Cobra Brakes, 3.29 gear, Boyd Tank, QA1 springs and shocks,
    My build blog: http://jacks33hotrod.blogspot.com/
    Milton,DE
    Here's a big hint. If you are not using the return, install a 90* fitting and a plug. You never know if you will need it one day.
    Two weeks ago I had to add a return line on my finished HR. I was really happy that the 90* fitting was already in the tank.
    Olli
    Feb 2013
    Xenia, OH
    BTW...the pickup is the closest one to the sender.
    FFR HR #530
    Senior Member Motor_Freak's Avatar
    Feb 2014
    Los Angeles, CA
    I just got non EFI tank for my HR33, please help me understand connection.
    1. Sender
    2. Pickup
    3. Vent
    4.---????
    THANK YOU!
    Ang's 33 HRC amasciarelli21's Avatar
    New Jersey
    Return line if used
    Feb 2014
    Los Angeles, CA
    so, number 4 can be capped?
    DaveBoyd's Avatar
    Ocala, Fl
    Quote Originally Posted by Motor_Freak View Post
    #4 is the return for EFI application. Yes, it can be capped.
