Thanks Thanks:  9
Likes Likes:  2
Page 1 of 4 123 ... LastLast
Results 1 to 40 of 133
Thread: 818 assembly tips- add yours
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    The outer can be a real pain to get past the circlip when installing it. I use a hose clamp to compress the circlip, fully tighten it then back off 1/4 turn so it will slide. Put the CV on the tip of the spline and give it a good whack with a dead blow hammer. It will slide over the circlip, fully loosen and remove the clamp and then fully seat the CV to the base of splines.
    I pack them with this
    Administrator
    Enterprise Alabama
    Rear shock spring preload, adjust it before putting it on the car. From the bottom of the spring perch to the bottom of the threaded sleeve is about 3" at ride height. Much easier off the car since you have to put 3/4"ish of preload on spring
    Exeter R.I
    When installing engine/tranny, two people is a good idea, remove the up-pipe and headers, along with the FFR recommend removal of the coolant tank and oil filler neck, protect frame with pipe foam insulation and be aware of your inlet tubes associated boost line bung ( broke my bung lol), or just remove the inlet. I agree with adjusting the coil over first, not a lot of room to adjust them when there on.
    Mechie3's Avatar
    Get more than 25 cleco's. 35 is better, 50 is great. It can be done with 25, just not as well. Some 3/16's cleco's would be nice for the firewall but I got away with using a series of 6 clamps.
    If you are marking aluminum then removing it to drill, check the locations first to ensure you can actually drill the frame and rivet in the spots you marked.
    Some panels overlap slightly. Line up adjoining panels and then mark for drilling to prevent panels overlapping on top of rivets or rivet holes in one panel that are on the edge of another panel.
    I took the route of fitting all of the aluminum first so it can be deburred and powdercoated for quick assembly all at once later. For the interior panels I drilled the panels while them already clamped onto the frame and drilled the frame and panel at the same time.
    Get a deburr tool (one in link or a countersink deburr tool for small holes). Some of the laser cut pieces are rough as are the saw cut spacers and could use deburring.
    Straight edges and large holes: http://fierychill.com/imperial-210-f...Fe1DMgodbFgA7A
    Zero Decibel Motorsports
    Freeport, ME
    You get tons of bolts, nuts, washers, screws etc I organized them by type on a small portable card table. Now I'm not digging through a box to find the correct fastener etc...
    Administrator
    Enterprise Alabama
    Get yourself a block of styrofoam to drill the aluminum panels on.
    Here is my rivet spacing guide, a carpenters square, one edge drilled on 2.5", one on 3" and one on 2". Mark the backside of all the aluminum with a Sharpie BEFORE you pull them off the chassis and then take them over to the foam block to drill them. I've done 20 FFR's this way, way easier faster way to build.
    Administrator
    Enterprise Alabama
    Early production control arms on the upper front left side need to be modified, there is a running change by FFR to correct this so please verify before doing this modification.
    Trim the welded stud on the ball joint plate 1.100" and you should end up with .800" of thread past the fully threaded nut.
    Flip the pivot arms so the grease fitting face down and assemble as shown.
    On the subject of axles
    The empi boot kits are really nice and come with clamps, new clip, boot and a premeasured amount of grease. When you rebuild its a great option.
    Also the tri-bearing carrier on the inner cv can be on there tight after removing the spring clip. I have used a hammer, but I did mush one once making it harder to get the clip back on. an better option was to use a press and it came off super smooth. The carrier is directional so make sure it goes back on the right way or it will not get on far enough to reinsert the clip.
    Senior Member fateo66's Avatar
    Golden, Co
    If you cant seem to get your coilover threaded sleeve all the way down, assemble the upper spring perch and slowly tighten the adjustable ring until the sleeve drops down into place.
    1997 RSVX Impreza Awesomeness!
    1999 RHD 22B RSTI
    2002 WRX
    2005 Saabaru
    2008 STI
    2013 FFR 818 #30
    Vancouver B C
    Great ideas guys, with out changing Wayne's thread I'd like to add a general shop tip, I'm sure Wayne and the other pro's around here have lots of tip's for wrenching & shop and I hope they share some of those idea's also.
    Most of the build threads that I see here - it looks like the lucky guys are working day after day on the project, for me that won't be the case. When I finish with a caulking gun I screw an electrical marrette (plastic thing that screws onto 2 or more wires to hold them connected) over the tip, the threads of the marrette bite into the tip of the caulking tube, sealing it against drying out.
    If you have to use a tap to make or clean up threads put a dab of grease in the flutes (the valley between the cutting surfaces) of the tap, it will pick up most if not all of the cuttings.
    Finn
    Mechie3's Avatar
    When making your brake lines, measuring is difficult. Use some formable wire (I used galvanized baling wire) to make the shape you need then copy that with your brake line. Mark the start middle and end of the bend with marks perpendicular to the brake line. Draw a line parallel to the line on the surface that is in plane with the bend so you know how to orient the tube in the bender.. Helps you to make lines that can hug the frame nicely without lots of mistakes.
    When installing the shock collars heat them with a heat gun for 45 seconds. They will fall in place. No sanding or decal removal. Also they lock in place for easier spring adjustments.
    Freeport, ME
    DO NOT use masking tape to mark your harness connectors! It is NOT strong enough and some will get damaged or destroyed. tags with string to tie them on or tags held on by small zip ties are far more durable. Losing the ID of a small plug in that huge 42 lb octopus could take a long time to identify.
    Ask me how I know! ;-)
    Dan
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    I've been using a Dymo Labelwriter 450 Turbo with the labels that were included. They stick very good, and being printed means I can still read them later.
    Freeport, ME
    If you have an 02-05 donor the throttle pedal can be a challenge
    1 the split ferrule nut. the threads line up only one way so test it on a 1/4 x20 bolt first and mark the nut. I found that the threads lined up when the flats were rotated 1 flat from the slot. Once you find where the threads line up and it mnakes a single nut mark the flats with a magic marker, makes it easier to re-align when you are up under the dash area. I used RTV to hold it in place after it was tightened.
    2 you need to slot a fender washer to place vs the firewall so the ferrule doesn't pull through the firewall
    3 some of us found that the pedal works better w/o the bracket (Tom W. was 1st) It moves around quite a bit when you use the bracket. The pedal lines up better too.
    4 the hole through the firewall isn't big enough at 1/4 inch (manual inst. ) if you use the black plastic piece the hole has to be just over .515 inch. If you don't use it the ball will slide through the pedal hole. I cut a slot in the plastic piece, slid the ball thriough a 5/16 hole and replaced the plastic piece to hold vs the pedal. You could also slot a washer to hold it in place vs the pedal. I also used RTV to hold it centered.
    Dan
    Norton, MA USA earth
    Buy a metric ferrule for your front master cylinder location instead of using the FFR supplied adapter. They make the 10MM tube nut that accepts 3/16 brake line. This allows you to bend the line a little lower and not interfere with the windshield surround.
  17. Thanks Kiwi Dave thanked for this post
  18. #17
    I'm guessing I need to make this modification, but how can I tell if I need to?
  19. #18
    Eugene, OR, USA
    If I recall correctly, this is necessary if you have an angled ball joint. If the ball joint is perfectly perpendicular to the pivot arms, it is not necessary because you can just flip it over and use it as is. The angled ball joint makes that impossible because it would be at the wrong angle (backwards), so you have to modify control arm.
  20. #19
    Freeport, ME
    \The new arms also have two hex links that are the same length vs one long and one short as seen above IIRC
    Dan
  21. #20
    Encinitas, CA
    After stripping the Aluminum and fiberglass panels off the frame from shipping, also remove the rear strut tower brace or cover the fender support plates with padding. If you walk into this protruding sharp edge, it hurts. Really hurts.
  22. #21
    Freeport, ME
    You should see what it does to your head when you hit it!
    Dan
  23. #22
    Adkins, TX
    Motor drop in
    In addition to the oil inlet removing the two lower heat shields on the headers along with the oil dipstick will give you enough clearance to get the motor in. Removing the dipstick tube and the plastic intake hose would make it even easier, but it wasn't required. Some ratcheting straps connected to the back of the transmission allows you to angle the motor as it is going in without having to fight it.
    I also replaced the clutch and flywheel. Using a strap in the back and one in the front enabled me to get the transmission hooked back up with out any help or breaking my back.
    1995 Nissan Skyline GTR VSpec
    818S in progress.
  24. #23
    Near Denver Colorado
    Lessons learned so far on my build:
    1) The hose clamp was a little too wide to work getting the CV joint on the rear axle, but a tywrap worked great
    2) Careful when you pull the front axle out of the differential in in that the retaining clip can easily catch and ruin the seal
    3) A set of dial calipers are very handy to sort out the spacers use in the suspension systems
    4) I had to pull both the exhaust manifold and coolant tank to get the engine in the frame
    5) A 3 inch C clamp works perfect to grab the center differential. It was slippery and difficult to get a hold of otherwise. Hook it over one of the 4 holes and you have a great handle to pull with.
    Larry
  25. #24
    Suisun City, CA
    For the super tight radiator tube adapters, here's what I ended up doing... Slide the inner sleeve onto the coolant tube and secure it with a clamp. Lube the outside of it and the inside of the adapter. This should help get the adapter slid on and keep the inside sleeve in place.
  26. #25
    Houston
    Check That EVRY Flange is Flat
    Valuable advice from Charley (Service mngr. Gillman Subaru in Houston). None of the flanges on the exhaust parts that I have were "true flat", including the Ffr after-turbo adapters. Some were terrible! and would almost certainly have leaked, if not immediately...pretty soon thereafter. (and I would probably have blamed the gaskets, and tightened the bolts unreasonably).
    Thanks Charley
  27. #26
    Freeport, ME
    The FFR shifter assembly at the rear of the car contacts the rear bodywork/screen when in 2nd, 4th, Reverse gears. While there are solutions that require you to buy a new shifter arm you can re-purpose the existing arm with a bandsaw, a welder and a drill.
    It is detailed on my thread at
    http://thefactoryfiveforum.com/showt...-Thread/page14 go to post # 543
    Dan
  28. #27
    Nov 2012
    Medina, OH
    Nice Dan. I did a very similar mod that didn't require welding for those who don't have a welder. My setup is for the K-Tuned shifter from Wayne at VCP, but can be applied just as Dan did. Rather than weld the sleeve of the factory bracket (very clean look btw), I used a piece of 1-1/4" solid trailering draw bar to fill the space between the wings of the shifter bracket and drilled the holes for the transmission shaft and retaining pin. See post #78 on my build thread (page 2) to compare mine with Dan's. My pictures highlight the K-Tuned setup, Dan's highlights the FFR setup. For the weight conscious, Dan's will be lighter.
    http://thefactoryfiveforum.com/showt...-Phoenix/page2
    Rich
  29. #28
    Freeport, ME
    Rich, you need a welder! Missed your posts 2 weeks ago :-(
    Just goes to show us how many ways there are to skin a cat!
    Dan
  30. #29
    Nov 2012
    Medina, OH
    I need the skills to run a welder! I'm halfway there after scoring a miller on Craigslist last year, but haven't learned how yet. This could have been an opportunity to practice, but it's been cold, and it's in storage. Ventilation hasn't been an option.
    Rori has a similar, but stunningly beautiful option using billet aluminum. Had he done that a few weeks earlier, I probably would have picked up his.
    Rich
  31. #30
    In the assembly manual p. 59 - 61 (Cockpit front firewall aluminum) although the photos show the pedal box already bolted in, there is no mention of this. So that if, like me, you follow the instructions and rivet on the first two aluminum pieces, you will then have to drill out the rivets, bolt on the pedal box, and re-rivet the "left cockpit front upper cover". Although the emailed manual revision tells how to bolt the pedal box to the frame, nowhere does it mention that it is crucial to accomplish this step before starting to mount the aluminum.
  32. #31
    Im assuming they changed the frame design, because my manual doesn't show the pedal box installed, because its done after the sheetmetal.
    Edit
    Just downloaded the full revision I manual
    I see what you are saying... The earlier frames had the pedal box MOUNT welded to the frame... The new frames it bolts on.
    If you look at https://www.factoryfive.com/wp-conte...-1i-update.pdf
    It shows the pedal box front plate (mount) being installed before the sheetmetal.
    Good advice for someone with a new frame.
  33. #32
    Leesburg, VA
    Edit
    Thanks for posting the rev I update. I was a bit confused when I read it and am about to install my firewall so I'd like to make sure I understand everything. On the newer chassis, does the pedal box have to be bolted in before the upper left portion of the firewall is installed? I'm guessing yes since the firewall is not shown in the rev I update pictures.
    The windshield install is also confusing. On pg 16 they tell you to "Cut the area out using the rear hood support aluminum as a maximum guide". What does this mean and why does this need to be done? Perhaps for the wipers? I don't see any cuts in the picture.
    Also, can the windshield be installed in its surround off of the car before any cutting is done? Or does the surround need to be on the car prior to the glass install?
  34. #33
    Eugene, OR, USA
    Edit
    I'll bet they made that change to accommodate other pedal boxes, so it makes sense.
    Have you seen the 818 Registry on Google Maps?? https://www.google.com/maps/ms?msid=...a=0&dg=feature
    Want your 818 added to the Registry? https://docs.google.com/forms/d/1zmF...rNCY4/viewform
  35. #34
    Eugene, OR, USA
    I don't know about the newer frames, but on the older ones you mount the pedal box after the aluminum. Looking at the updated manual, I would guess the same is true. What you have to mount before, is the pedal box mount.
  36. #35
    It appears the pedal box mounting plate needs to be mounted first ( not the pedal box itself, which bolts through both) but I'll leave that someone with a new chassis to answer.
  37. #36
    Leesburg, VA
    Understood. Any insights into the new windshield instructions?
  38. #37
    Well, to clarify, the pedal box mount has to be bolted in before the aluminum. The pedal box comes later.
  39. #38
    Freeport, ME
    There is a new support for the back of the hood. It also covers the hole that you cut to access the brake and clutch cyl reservoirs. It's just a piece of aluminum with rubber on the top to support the back of the hood. Mine came last week by FedX
    Dan
  40. #39
    San Jose, CA
    For the pedal box, what hardware should be used to mount it?
    Never mind, there was a bag marked "Option Hdw" in the box with the pedal mount that had 5 button head screws and nuts.
  41. #40
    My kit (picked up on 4/5) included a bag of bolts marked pedal box.
