4th gear makes sense, since you spend more time under WOT there, I guess. Thanks for the info, I'll start off with the HWG tune then (which lowers boost IIRC) and if I experience it, see if a custom tune will address it.
HWG map will RAISE boost for people not hitting target. You want LWG map for less if you are overboosting
