That 6/10 tube is very good stuff, I love it.
Hi Aloha818 and Hula Girl,I'm thinking of something between the bikini top on my Jeep and what Porsche has. Maybe the u-channel across the windshield frame like on my Jeep, a support bar that bolts to the back across my two hoops, and receiver for rear straps inside the body through the engine cover intake slots on each side, similar to Porsche. Everything to be designed to remove and fit in the trunk without a lot of fasteners/connections left when the top if off to make you wonder what is missing.
Any comments would be appreciated! Thanks.
First let me say: Great job. I look for you post every morning.
I also am entertaining a Bikini top idea. I'm planning on using some awning track for the front windshield edge.
See attached photos.
arp15c.jpgmazdas-mx-5-spyder-concept_100368756_l.jpgmazdas-mx-5-spyder-concept_100368769_l.jpgmazdas-mx-5-spyder-concept_100368771_l.jpg
I'm with you. I want to add a sort of targa bar over the roll bar, widen's the top at the occupant's head and supports the top. Use a "frankenstein bolt" like a miata uses for the hard top in the rear and a strap with a latch and the ability to pull it tight.... perhaps some strong elestic to aid in keeping it tight
Dan
The first and last time I did any body work was a bit over half a lifetime ago when I was 18. I had a 1968 VW Bug that needed a lot of body work and then a paint job. I did all the body work myself which was a real challenge for a novice since everything was so curvy.... not a single flat surface on that car! Someone else sprayed the paint. It turned out great, as I'm sure yours will..... I think a lot of us tend to go for perfection in doing body work, for the reasons you mention above, and we are surprised to see how good it looks after the paint is on.
As for no one noticing the little changes but yourself.... well, that's all that's important right? Otherwise just go buy a car Keep up the great work.
I really want a bikini top, and I know several others do as well. I talked to Dru at Huntington Beach about it, and he has an upholstery guy he knows. I suggest we work together and group buy/fab the parts, or at least share design details. I'm a ways off from having my windshield frame and body on to take measurements, but will be willing to help out in the process in any way.
Lee
Thanks- Chad
Looks that way.
"In wine there is wisdom, in beer there is strength, in water there is bacteria."
818 (Chassis #34) Delivered 9/25/2013, First start 3/2/2014, First drive 4/5/2014, Registered 8/28/2015, First Dyno 3/18/2016, First SCCA event 4/3/2016, First car show HIN Honolulu 4/23/2016
Thanks all for jumping in with your comments! I didn't realize that so many others had interest in a bikini top. I guess I hadn't read anyone making any comments.
Bob, thanks for the compliments! That is exactly what I had in mind for the overall look of the bikini top. The only attachment points being the inside of the windshield, the crossbar near the roll bar, and tie downs in the opening of the engine cover for the rear. Perfect!
Wheelhendrick, great idea. No sense in several people trying to invent the same thing. I'm about a week or two away from finishing putting the body together for the last time. When I'm done I would be happy to send measurements in. Let me know how I can get this started. I was planning on taking my car over to a local shop and see how we could come up with something, but then would be expensive for everyone else to pay to ship from Hawaii.
There's an older thread about bikini tops.
I bought both the 818s and 818r CD models too.
Zero Decibel Motorsports
Not to get too off topic but....
My mom is staying with us (wife and I) to help with the baby. She just bought a new sewing/embroidery machine and brought it with her. Have to ask if she's still into helping me. Just heard back from FFR too. I'll be able to buy their windshield to soft top mounting hardware. It'd be nice for any solution to be compatible with other solutions.
Windshield frame prep continues. After the epoxy sat overnight I started spreading filler. I had just finished up the Extreme model filler, bought the Gold this time. I like the Extreme better for running thin skim coats, way less air bubbles. Also the Extreme sets up faster to sand without gumming up the sandpaper. Also started getting the spoiler ready for paint.
I rounded the exterior corners all around, looks good
Then into primer. Looks much cleaner now without that plastic trim.
Wet sand tomorrow and into the booth on Saturday.
Next week I'll get the glass installed and start really looking at the bikini top.
Light day at work, so I thought I would take advantage and paint the last of the parts.
Had to get a little creative on how to support the parts and still have access to paint all sides
Naturally the last parts are my best work!
The windshield frame looks so nice being a continuous painted surface. The 14 year old spoiler looks better than new.
I've been working in a complete mess as I didn't want to spend the time cleaning up with so much more filler and sanding to do. So I've retired my can of filler and cleaned up this afternoon. Tomorrow I can actually start re-building an 818. I've been on paint duty so long I hope I can remember what goes where!
If everything goes good I'll be able to take a test drive again tomorrow
I spent the day putting the painted body panels back on. As typical, it took a little longer than I thought it would. Since I hope this will be the last time for assembly, a tweak here, a tweak there. A little demel, here a little dremel there, most of the day. I bet I took the doors off and on at least 8 times each side to get just a little more perfect. Still have at least one more time each side for minor tweets.
I am very happy with all the extra work and prep I went through to get to this point. The car totally looks like any production car. Even gaps, straight lines, blind panel attachment (only hood pins will be locking type to secure trunk), and with the elimination of the plastic trim on the windshield surround turned out great!
The trunk and engine cover are both installed. I included a pic of the front of the hood lining up with the bumper, a little work and it can be done!
I think while I have the car on jack stands I'm going to go ahead and install and paint the inner wheel wells.
Here are some pics, pretty dusty though;
While I have the car on jack stands I'm installing the fender well aluminum, painting with bedliner, installing vent mesh, and misc items that will be covered up by the aluminum.
It took me about 12 hours to fit, notch, clean scuff and paint the aluminum. I did not drill every rivet hole, but enough to cleco everything in place. No major issues, but did require notching and cutting around the fenders and obstacles.
Since I painted the front of the side sails, I cut the FFR supplied aluminum off in this area of both front fenderwells.
I had to move the seats so I could remove the rear wheel and install aluminum, what better place than where they go! If only temporary.
First piece of mesh, looks really clean without any trim.
Lookin good! Do you know how well the bedliner will hold up to rocks, and if it will offer much accoustic deadening? Any idea on the amount of weight it adds?
You mean like this 60 grit;
I also pre clean with acetone first.
Thanks for the compliment!
Like metalmaker said, bedliner lasts well, I painted in my Jeeps wheel wells 3 years ago and they look like new.
I'm going to use almost a gallon of bedliner on my 818, this includes painting almost all aluminum and all of the backside of all the fiberglass panels. I can't imagine that a gallon even weighs 10 lbs and probably 25% is the carrier that will evaporate.
Not sure what the acoustic benefit will be, but it will will be some, and at least better than just black paint that would still be needed to make the wheel wells look good.
Spent the last two days trying to finish up everything under the car and in the wheel wells so I can put the wheels/tires back on and drop the car to the ground.
I installed the mesh in both front and rear wheel areas, found a couple places that the brake line needed additional supports, needed to paint bedliner on the aluminum under the seating area, finish riveting the side sails, tighten some suspension bits and install cotter pins, the list goes on!
The windshield should get installed before the end of the week, and I needed to clean the shop and get rid of the dust to get ready to start on the interior. So I drove it outside and gave it a quick blow off and wash.
I'm very excited on how this car looks, very sexy!
Tomorrow I need to reinstall the rear lighting and the gas fill cap. Then a quick run and some more pics!
WOW!!!!!!!!!! Can not wait to see it all done, awesome job! Love the wing on the back too!
What was the rear spoiler from? It goes really well with the car.
That doesn't hurt but I would recommend an aluminum "metal prep" as a last step before painting aluminum. Like Afterblast which etches and leaves a zinc phosphate coating.
Carry on... nice work!
"Scotty, give me all the TRACTION she's got!" Pictures of what I drive till 818R is finished
Track Car Journal on IWSTI (with build info)
Quiny Tiburon
Scargo zinc phosphate etching is more for steel than aluminum, his aggressive scratching/etching should work fine since aluminum doesn't have a flash oxidation issue like steel
Dan
Car looks amazing Aloha.
Not sure if its the color, or the custom touches like the roll hoops, or the obsessive attention to detail of door gaps and panel alignment, or the excellent body prep, (or all of the above), but you can really see how great the FFR design looks with this car. It really does look awesome.
Maybe Jims design has grown on us a little, or maybe over time all the visions of what we individually wished for from all the design contest prototypes have faded, but wow, that just looks sooo good (and I'm not usually a fan of black cars). The way the curves of fender and Q panel flow, the vents, the aggressive look of the rear fender flares and humps. Just fantastic.
You've made FFR's vision really come to life. I'd like to see FFR look at incorporating some of your designs into the next 818 revision. Especially the roll hoops, sunken license plate (though I realize that complicates things for euro plates, 818 is a World Car), etc.
That looks really really good. I like the two hoops and even the red seats, which I didn't think I would.
Every inch a fantastic build!
Wow. Now let's see some sunset/golden hour pics with a good camera. Wish I was there!
Erik-
I agree with one modest addition. I was hoping he could do the sunset picture with the girl in his avatar! To me, that would be perfect.
Awesome car with a stunning model at a location as close to heaven as there is. In my opinion at least.
The car is simply amazing, and I can't wait to see the final pictures!
I never really liked the orange on the 818, but I like the black. I hate red seats and not a fan of the spoiler off the car, but you made it work nicely man. Looking like a car, and besides my love for white, blue, gunmetal and red on this car, the black is totally on my list with your beautiful body work. Now be careful and drive it fast.
