So I went to bleed the clutch today and no go, I could not get the clutch to draw fluid, I was using a vacuum pump, and would not draw fluid from the slave cylinder bleed valve, I have s JDM 5sp, so the slave cylinder is different than the USDM one, so I could not try a different slave cylinder. Any ideas ?
