Page 1 of 3 123 LastLast
Results 1 to 40 of 102
Thread: Brake routing suggestions- Post your pics
    Aliso Viejo, CA
    I'm hoping to put together some pics of good brake line routing. The manual shows a lot of non-90degree bends and I'm wondering if we can use the stock lines and make it much more organized via 90degree bends (where Possible) and still have enough length.
    Mechie3's Avatar
    You're going to have to buy/cut stuff anyways I think. My instructions called for a medium length section of which I only had long and two very short segments. I might have some pics in my build thread.
    Mechie3's Avatar
    Finished my brake and clutch line routing this weekend. I tried to make it as clean and hidden as possible. It took a lot of time to do it this way and I had to buy two extra lengths of line and some couplers (partly because I wasted some line when I didn't like the bends). For a lot of these bends I used my homemade 1/2" radius tubing bender. Some of the bends are compound angle so they don't show up well in pics.
    It doesn't look it in photos, but in real life from the angle you see everything you actually don't see a lot of things. I like the way it looks and was happy with the end result.
    Brake MC goes to valve moutned between the two cylinders. Clutch line bends down immediately then goes in towards the wall.
    Hard to see, but the line off the bottom of the valve goes in to the firewall an dthen tucks underneath the outcropping sheet metal over to the end then up to the tee. I need to finishe mounting the tee. Clutch line goes to firewall, hides under the same outcropping, comes down, then hides along the seam near the steering knuckle.
    It doesn't look very straight here, but it is. It follows the seam then bends down near the front control arm. I used several P clamps in this area to ensure it would never contact anything.
    Here it comes over the coolant hose and into the pass through. There's about 1/2" clearance minimum on all sides of the clutch hose (brake hose is on right).
    Brake line on top, clutch line on bottom. Runs parallel to the frame way to the back of the car.
    Brake line tucks into frame and goes out through rear firewall openings. Clutch line goes up next to the gas tank so I had room to add a coupling, then bends out into the engine bay area and continues up.
    Top down view. you can just see the coupling on the left from the previous pic. It follows teh frame rail up, then follows the side rail to the rear. I did not run the clutch line under the manifold as FFR instructs.
    Mechie3's Avatar
    Lastly, there is a coupling at the removable rear cross brace, a short run of hard line, then the flex line. If the motor needs to be pulled, the coupling at the side of teh engine bay can be undone so that nothing blocks the removal of the motor.
    Norton, MA USA earth
    Aliso Viejo, CA
    Well done Mike and team, This will help alot of other folks out there. Thanks.
    Senior Member AZPete's Avatar
    Mechie, your line to the rear brakes goes into the opening in the firewall from the outside and your clutch line enters the opening from the inside. There is an aluminum panel #80171 that may cause a problem with your rear brake line on the outside of the opening. Here, I have only taped the panel in place until I finish my brake lines but I believe it's in the correct location.
    Mechie3's Avatar
    Just one more thing I can change.... :/
    It did always bother me how it wasn't perfectly vertical. Just have to live with a few holes in the firewall.
    Mechie3:
    Quick question... I see you are using removable fasteners to attach the brake lines instead of rivets. What kind are they? Did you tap a thread into the frame or are these thread-cutting?
    Mechie3's Avatar
    I used the P clamps and rivets in the FFR kit. Might be the lighting (or the fact that one p clamp isn't riveted yet) making it look removable.
    Freeport, ME
    It would be easy to use riv nuts. I'm using 10-24 screws and riv nuts in a bunch of paces to make parts removable. Buy a harbor freight tool and the riv nuts (nut serts) from mcmaster.com
    For those following, the manual says to route the hose to the clutch slave cylinder under the intake manifold. Like Mechie, I didn't like that because then the metal line would be shaken by the movements of the engine. I routed the OE clutch hose above the intake manifold and mounted the connector to the frame above the engine so the flexible line can flex and the metal line cannot.
    Freeport, ME
    I did the same, however now that I had a possible remove the engine scare with my water pump issue I would mount the frame tabe on the frame to the left of the engine vs the removable shock tower brace like I did on mine... live and learn
    Mechie3's Avatar
    That's a long braided hose! Mine is only about 6" long, if that. Maybe I should find a longer one. That would prevent me from having to empty the system to pull the motor.
    Freeport, ME
    That's why it would be nice to yank the slave cylinder and pull the motor with no bleeding...
    Mechie3's Avatar
    Yeah....don't route the brake hose to the outside near the control arm. The splash guard mounts right on top of it. Not of a fan of how many things have to fit through that small side opening. They certainly fit with clearance, just don't like how they can vibrate and bang against each other in an area that will be difficult to inspect.
    Clovis, Ca
    Hey Guys- Are we doing Double Flare or Double Bubble if we cut our own lines?
    Thanks- Chad
    Fresno, CA
    Chad, I have always used a double flare.
    Doug
    Mechie3's Avatar
    double flare as well.
    Aliso Viejo, CA
    Heres my routing. I only had to flare one line and I picked up a couple more lines of the appropriate length from Napa.
    Edmonton, Alberta
    Now that you guys are almost finished your builds, did you have to change anything? Is there anything you would do differently?
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Senior Member metros's Avatar
    NoVA
    I'm starting to look at routing and wanted to bump this thread up and ask the same question as Canadian.
    Now that some of you have had the engine in and back out, would you route the brake lines differently the second time around?
    Massachusetts
    For anyone with a running complete car or anyone who has test fitted the windshield how am I supposed to put fluid in the brake master cylinder and clutch once the windshield and dash are in ??? Looks like poor design work from FFR.
    Mar 2014
    Hingham, MA
    Quote Originally Posted by CU9DZ View Post
    Check out Mike Everson's solution (Replicaparts.com). I visited his shop yesterday and picked up his clutch plumbing kit. I ordered his brake reservoir kit, coolant tubes and exhaust this morning. He is a real nice guy whose engineering and fabrication are excellent.
    Exeter R.I
    I changed my rear lines to nickel copper. Than I ran hydraulic lines from the front to the back lines. It was much easier than the solid lines I had. I ran them like Mike E .
    south-central CT
    Not to say that I am an authority but I thought that you changed out regular brake hoses for SS braided, teflon-lined high performance brake hoses because the regular brake hoses would swell and absorb some of the pressure by way of swelling. If this is true, haven't you just increased that (potential issue) by many times?
    Exeter R.I
    The fronts are still the steel solid lines to the stainless Teflon lines to brakes. The middle lines are a newer style nylon/Teflon line. I put new solid nickel copper rear lines to connect the rears. I have SS Teflon from those to rears.The lines I put in the middle are a Teflon reinforced line and used in many racing applications, it is just a test run to see if they perform as they are advertised. I have received great feedback from fellow car builders on there performance. Thanks for the input as I too am interested in there ability. If they are what there said to be, they would be a much better way to install lines in the 818.
    Feb 2013
    Bowling Green OHIO
    i am not there yet, but i thought i saw a picture somewhere of the shroud cut for access to the reservior. I am hoping to go this route, i thought i was finally done with the brake lines but maybe i havent redone them enough yet
    Massachusetts
    I saw the remote tank for the reservoir and also the cut out of the windshield shroud. Don't know which option I will use yet for access to the clutch and brake tanks. I just started the front section of the clutch lines like Mechie3 did. Going to route the back lines to the clutch along the side and put a removable section on the strut bar. Don't like going over the engine with the line.
    Thanks for the help.
    nkw8181's Avatar
    Dallas, TX
    If you wanted to go with metric fittings what size would you need to fit the lines from ffr? It may be a stupid question but I had to ask
    Nolan
    Harley818's Avatar
    Vancouver BC
    I've seen it noted a few times in some build threads but you could buy a 10mm fitting that can accommodate 3/16 in. lines..... provided you are prepared to cut and flare the tubing.
    I'm planning to use 10mm fittings and lines to come off the master cylinder, then adapt to 3/16 fittings further along in the line where it won't be seen so readily. I don't like the look of the FFR adapters, or the extra height that they add.
    Then I'll convert back to 10mm at the brake flex lines using the pink fittings provided by FFR.
    San Jose, CA
    I placed my orders with FedHill last week for 10x1 metric fittings and I'm using the eastman tool to flare the tubes. I bought some additional 3/16 line so hopefully I don't need too many couplers. Since at the moment all the routing is in my head, I have to report back in a couple weeks how it all went.
    BTW, any decent auto parts store will have the fittings in stock.
    Nov 2012
    Medina, OH
    Quote Originally Posted by Jaime View Post
    Agreed, Advance Auto had them when I needed them. The hardest part was remembering to put the little buggers on the Brake line BEFORE flaring them!
    Rich
    Along with the 10x1 metric fittings get some coat hangers. An old trick is to bend the coat hanger wire as a template first, then bend the brake tubing to match the wire piece. And, 2 sockets screwed to a board make a good bending tool. Bigger socket = bigger radius. Eastwood flaring tool is worth the money.
    Harley818's Avatar
    Vancouver BC
    Finally got to my brake and clutch lines......
    I wanted to keep everything out of the way of the central access triangle in the front of the 818, so I located the proportional valve between the clutch and brake master cylinders.
    Then I ran down to the bottom access way on the drivers side, and along the side frame rail to the back.
    I split the lines right behind the firewall, ran back to the crossmember under the engine where I terminated the clutch line, and ran one brake line to the opposite side.
    Just need to finish off the tie-downs now
    Nice bends. Did you do by hand or with bending pliers?
    Harley, you have the rear brake line and clutch line entering the front firewall opening on the outside but there is an aluminum panel that mounts along the outside edge of the front firewall. If you remount the lines coming into the opening from the inside, just above the lower control arm, you'll avoid a headache later.
    Edit: DON'T mount your flexible brake line to the caliper like this photo. I had to move it later because it conflicts with an aluminum panel.
    Here's another tip I should post in this thread about where to mount the tabs for the front flexible brake lines:
