Results 1 to 12 of 12
Thread: Will these wheels/tires fit the 818?
    Senior Member Kalstar's Avatar
    Cape Cod
    5x100 18x8 45 offset wheels with 215/45/18 Toyo T1r tires on all 4 corners? These have never mounted on a car, I can pick them up for 400.00 and use them as street wheels and keep what I already have for the track. The tire calculator says the tires are about 3/4 wider and 3/4 taller then the stock 205/55/16. I know FFR says 40 offset, not sure if the .5 (45 instead of 40) is a killer.
    Advice appreciated.
    Senior Member DodgyTim's Avatar
    Brisbane, Australia
    The 45mm offset can be overcome with 5 mm spacers, lots online for $25 a pair, hub centric are best
    Senior Member Stickshift84's Avatar
    Rhode Island
    Those will abosolutely not work in the front. The tire diameter (25.6") is too large. You would need a 215/35/18 up front. Optimal tire dimater in back is about 25".
    Exeter R.I
    Jim, I concur with broken shift, j/k nick
    Up front for tires you want a 215 35 18 and or a 215 40 17 give or take a size depending on how r
    They run .
    For wheel offset: F you want a 40mm-35mm( 17x8, 18x 8 max) , R you want 40mm(9 max width, with like a 3mm spacer)- 35mm(8.75-9max width rim) a 9.5 wide rim might fit with the perfect offset, but your playing with God at that point, and I would recommend different control arms etc
    So you have 18x 8+ 45, that might clear in the back by a short amount, and upfront the tire is to tall.
    Cape Cod
    Thx guys for the answers. 400.00 saved!
    Cape Cod
    Ok Here is another wheel question..... 17x7 +40 offset. Will these fit with no spacers?
    Exeter R.I
    Hmmm maybe, but they will be inward and funny looking.
    Senior Member gwarden's Avatar
    Jan 2012
    Surry Va
    Ok I'm getting ready to buy some wheels and tires and thought I would run them by you guys for opinions
    I'm looking at the Enkei RPF1 in an 17" 7.5 width front and 8" width rear with 215-40-17 front and 245-40-17 rear
    they would be 23.7" dia front and 24.6" rear
    do you see any problems with that
    Senior Member Triathletedave's Avatar
    Calgary
    Quote Originally Posted by gwarden View Post
    My fronts are 215-35-18 with a 23.9" diameter, and so far the clearance looks pretty good. You should be fine with 215-40-17 at 23.7". Not certain about the rears though. I'm not sure what the maximum width and offset is allowed before you hit the trailing arms.
    TriguyDave
    818 noobie builder
    First start: Sept 28, 2014
    Go-carted: Oct 4, 2014
    Registered and Street legal Sept 30, 2015
    Calgary, Alberta
    Cape Cod
    For the budget builders out there I found this wheel while looking for a set for a buddy. I just got off the phone with the supplier. The wheels are $69.99 plus $15.00 shipping per wheel. Set of 4 shipped to your door for $340.00. They are 17x7 5x100 with a 35mm offset. The onlinetires was going to post a listing on eBay. They are called K125, so search for that. There are also NS-20 tires 205/40/17 tires for $250.00 shipping included, so for $590.00 one can have brand new wheels and tires. Figured I would pass it along.
    Apr 2014
    Is there anychance of a stepped lip rim or deep dish rim option for the 818?
    Dec 2013
    215/45/17 and 255/35/18. I'm looking at Michelin pilot super sports and they don't make a 215/40/17, just looking at alternates they do make.
