Hey SpeedyElectricPower!
That's true, the pressure that is in there has probably already taken into account so it would only recirculate that pressure, but is it? Instead of going into the cylinders it would go into the oil evap and back again in the turbo. Not sure how that works.
I do not use a MAF, I use a MAP, so my control totally depends on the pressure in the intake manif, no matter how much volume or speed the air flow has.
I wanted to weigh everything!!! But it takes time and some parts can't be handled by hand or hardly (engine, tranny). Since my mech has caused me 3 months delay already and he's got 1 month left before I get the car back home, it would have stupid of me to use that time to weigh the parts instead of fitting everything in. So I had to sacrifice that part of the build and let go. I will try to weigh the entire assembly together though, engine and tranny fitted. That might be possible without losing too much time. With my corner scales it's easy to weigh, now. Just takes time to fit things on the scales, but once everything is ready, just before bolting it in place in the engine bay I will try.
BTW, with that KEP adapter plate the OEM front engine mount bracket does not fit at all. Since I have removed the PS pump, we will try to use the PS alu bracket and fit the OEM mount bracket on it. More custom stuff and like I said, 1 month left and my mech is super slow. I hope he'll make it on time. I am so angry at him since last July, oh well. If there is one mistake I made about this project it's not trying to fit the VR6 in, it's having the car at my mech shop for the last 6.5 months. Should have been at my home. Anyway, can't go back.
The Porsche flywheel weighs a little more than my lightened Autotech flywheel. If I recall my VR6 flywheel was about 12lbs, I believe the Porsche is around 15-16lbs. Too late to weigh it alone, now, but like I said, I only care about having the engine in before I take the car back home. The rest has to be low priority, unfortunately.
