!!MAJOR UPDATE!!
Ok today is a major update in this build.
We prepped the frame to test fit the engine/tranny. Had to cut the Subaru engine supports, made a huge mess cuz we used a torch and water to cool down. But the result is great, almost no damage to the powder coat:
2014-09-06 10.16.18.jpg2014-09-06 10.16.26.jpg2014-09-06 10.16.36.jpg2014-09-06 10.16.51.jpg
While the engine was out, I found a cracked bolt edge on the tranny casing, but there is still strength on it. Not much I can do for that!
Then we started test fitting.
With a 6sp 02A tranny, the VR6 does NOT fit without major frame (and possibly body) modifications.
Then my heart stopped for a couple of seconds.
With a 5sp OEM tranny, might be extremely tight or would not fit. My guess is would not. My guess is any transversal engine/tranny setup have good chances not to fit. Car engines, for bike engines I don't know.
The culprit is the width of the block and tranny. The reason why we couldn't measure things up before we got the engine out is cuz everything was bolted on and extremely hard to get precise measurements, we had to get the engine out to measure. Besides, this width depends on where the axles will fit and that also was too hard to measure in place.
The block and tranny are 35" wide and fit a few inches in front of the axles. Since it fits at the same height as the axle, the distance between the bottom of the left frame to the right bottom frame is about 25". Impossible to get 10". The big cross bars that support the shocks from top to bottom of the chassis cannot be altered without altering seriously the design of the car. Therefore, the 6sp 02A tranny with VW VR6 engine is a NO GO.
At that point I realized my budget is totally out of whack and there is probably no way I will build this car for a decent price. And now I know that it will probably not be over until Autumn 2015.
My next post will detail my next steps. Cuz no, this project is not dead.
