Page 6 of 25 FirstFirst ... 4567816 ... LastLast
Results 201 to 240 of 996
Thread: FFRSpec72 818R Build Seattle WA
  1. #201
    Puyallup, WA
    Its good to see you making great progress. Will have to come and see it once you have it driving.
  2. #202
    Clovis, Ca
    I like the center console, looks great. That's one thing I would like to finish at some point.
    You are going to need to remount the datalogger for 2 reasons:
    1: It needs to be mounted flat (for yaw sensors)and the correct Front/Rear orientation. (You can mount upside down and switch the axis values)
    2: Be careful mounting high dollar stuff with open ports facing "up". Water or other junk will get in there eventually.
    Are your washers on the wrong side of the harness eye bolts?
    You may want to move your sub belt mount. From that seating position, it is dangerous. I'm not sure why FFR welded those sub belt mounts there, 95% of people should not be using them with the seat orientation. Just go to the floor.
    Thanks- Chad
  3. #203
    QC, Canada
    Hey you did the same mod on the center console as I did, bending that top tab 180 around under the dash. You did it better than I did, though.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  4. #204
    Kirkland, WA
    Hi Tony,
    Does the MK2 support the SSM protocol that comes out of our ECU's?
    On the website, it talks about newer CANbus ECU's
    The answer is yes with a firmware update and a cable ODBII to CAN, so going from a slow bus to a faster bus should not be a problem
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  5. #205
    Kirkland, WA
    Chad, thanks for the suggestions.
    I agree on the mounting of the Data Capture, I will loose slip yaw but have roll yaw if I mount this way, also I agree with the crap getting in the open ports, may change the mount, just not much open space.
    Good catch on the washers, yes they were reversed, so changed that. I also moved the sub harness attach point per your suggestion and have gone to the steel floor plate.
    Tony Nadalin
  6. #206
    Kirkland, WA
    I made a new face plate, as bending the original one did not work that great
    Tony Nadalin
  7. #207
    Kirkland, WA
    I had some time yesterday also, so I finished some minor things and corrected some of the seat issues. I also finished up the dead pedals and fitted them
    I also started to rivet some of the front firewall panels, using black oversized anodized rivets
    Tony Nadalin
  8. #208
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Are the dead pedals custom that you added over the top of what FFR provides? Looks different from my S.
  9. #209
    Thanks Tony,
    That is good news.
    The published info on their website only talks about 2008+ ECU's.
    http://www.autosportlabs.com/racecap...bd2-interface/
    http://www.autosportlabs.com/product...-obd-ii-cable/
  10. #210
    QC, Canada
    You make your own alu plates/panels?
  11. #211
    Kirkland, WA
    Yes when needed, not very good at it.
    Tony Nadalin
  12. #212
    Kirkland, WA
    I finished the front brake lines.
    WP_20150101_010.jpg WP_20150101_011.jpg WP_20150101_012.jpg WP_20150101_013.jpg
    I also installed the proportioning valve, I will run a front and rear valve, I just installed the front, have to order a rear one, I used 2 1/8npt to 3/16th 90 degree adapters. Both valves will sit side by side
    WP_20150101_003.jpg WP_20150101_004.jpg WP_20150101_001.jpg WP_20150101_002.jpg
    My EJ302 came back machine shop
    Tony Nadalin
  13. #213
    Kirkland, WA
    The frame on the R does not angle in, and thus the dead pedals don't fit, so had to add a piece over top and thus the dead pedals are now same size bottom to top
    Tony Nadalin
  14. #214
    QC, Canada
    Nice, really nice! Beautiful!!!
  15. #215
    Kirkland, WA
    Zero sum day as I did not like how the front portion of the reasr brake lines were routed, so I spent the day redoing them (remove console, ebrake, etc.)
    Tony Nadalin
  16. #216
    Harley818's Avatar
    Vancouver BC
    Hey Tony, looking good.
    I'm focused on my wiring for the last couple weeks. Beat it into submission and starting to look less like a rats nest.
    Nice job on the console, shifter and ebrake. thats next for me, so it was good to see how you did. I'm doing the longislandwrx shifter mod lowering it down into the tunnel.
    I ended up re-doing my brake lines a couple times to get it right. Nothing is worse than looking at your finished car thinking you could have done a better job. Do it right the first time. Yours looks good.
  17. #217
    Kirkland, WA
    Thanks, I thought that before I put fluid in the system now is the the time to do any changes as it will be worse once the fluid is in the system. My weakest point is the wiring, thus I subbed that out to iWire, I wish that I could have done that but it would take me years
    Tony Nadalin
  18. #218
    Kirkland, WA
    Had time today but did not get much done as I had to decide where to put the ignition panel, I did not want to take up dash space as I will add some more gauges and they are more important to be in my line of sight than the ignition panel so I choose to put it to the left of the steering column and still in reach It will all meet tech inspection.
    Tony Nadalin
  19. #219
    Kirkland, WA
    I remounted the Data Capture Pro today, under dash (away from weather, etc.) so I can reach it to turn logging on/off manually if I need to do so.
    I also sharkskin coated and mounted (temporally) the front suspension splash panels
    Tony Nadalin
  20. #220
    Kirkland, WA
    I found this interesting for folks buying an engine and want to make sure it is what you expect it to actually be http://clubsub.org.nz/forum/showthre...Identification When I purchased mine I made sure it was an EJ207v7
    Tony Nadalin
  21. #221
    San Diego Ca 92106
    Good to know, thanks. You should post this in the sticky in the engine thread.
  22. #222
    Kirkland, WA
    I finished the rear proportioning valve, so brakes are done, still have to bleed them though, so I should now be able to adjust out any brake issues I may have with both valves
    I added two power distribution block, 1 for constant 12v and the other for key-on 12v
    I also moved the location of the remote oil filter so I can get the shortest lines, easy changing and out of the way
    Tony Nadalin
  23. #223
    Oct 2014
    San Francisco Bay Area, CA
    Coming along very nicely!
  24. #224
    Oct 2014
    What data inputs are you feeding the capture pro?
  25. #225
    south-central CT
    Tony, why are you using two proportioning valves? I thought it was typically only the rear they were used on. Is it to affect overall sensitivity and responsiveness?
    I like the tapping and use of the coated clamps.
  26. #226
    Kirkland, WA
    True, but I'm not convinced yet on the braking system on the 818, on the Challenge car I knew ahead of time I would only need a rear, so I plumbed both a front and rear in the 818 just in case since Jim indicated that the way the 818 is set up is a little bias on the front, but I'm not as concerned with the front locking up as I am the rear. so for safety I went with both as it was easier to do this now then later.
    Tony Nadalin
  27. #227
    Kirkland, WA
    Quote Originally Posted by soaringDude View Post
    So I will have boost, oil pressure (from a new galley plug), oil temp (from remote oil fill bung), water temp (heater bypass), RPM, along with any of the ODBII data and the outputs from RCP will be yaw (slip and roll), acceleration, GPS
    Tony Nadalin
  28. #228
    Kirkland, WA
    Oil pressure sender (remote), will go in the galley and replace the galley plug (galley plug with 1/8" NPT, 1/8" NPT coupler, grease gun hose, sender)
    Fire system ready to install the nozzles now, AFFF 4.0L system with 6 nozzles and 2 activation pulls (one for me, one for corner workers)
    Tony Nadalin
  29. #229
    Kirkland, WA
    I found some time over the weekend, so I attempted to bleed the brakes, well I had a leak it was in 2 cheap couplers I bout from Autozone, and as it figures was in a very hard to reach spot (in the console tunnel), so once I changed out the couplers (hours later) I had no issues, so I now have a solid brake pedal.
    I also found some time to install the oil cooler and the remote oil filter, decided to install on passenger side, this is a puller fan, I also hope to catch some air from the side of the car, now to plumb up the oil cooler. So I put the side panel on to make sure I had the clearance and that I would catch the air, the mount is welded to the frame and sticks out just a tad over 3" from the side of the frame. I wanted the oil filter in a spot where I could change w/o removing the under the frame/engine panel and close to the oil cooler and engine block off plate.
    WP_20150124_19_14_06_Pro.jpg WP_20150124_19_14_18_Pro.jpg WP_20150124_19_14_30_Pro.jpg
    Tony Nadalin
  30. #230
    Kirkland, WA
    I had some time this weekend, I welded in the tabs for the fire nozzles and the corner workers emergency pull.
    Put 3 nozzles in the rear, one in the center to cover the front of engine, one to cover turbo, one to cover fuel lines
    2 nozzles in the cockpit area, one on steering column to cover lower torso, one on side to cover upper torso
    one in fuel cell area
    emergency pull for corner workers
    Tony Nadalin
  31. #231
    Jun 2012
    Beavercreek, Oregon
    Dude, is that fire pull handle on the passengers side? Can you reach it from the drivers seat while belted in? If you're on fire you don't want to be waiting for those corner workers to show up. Never mind I see you have two pull handles......................
  32. #232
    Kirkland, WA
    The oil cooler and remote oil filter are plumbed now, lines and couplings from Paragon Performance
    Tony Nadalin
  33. #233
    Kirkland, WA
    A fellow local R builder just de-powerd my rack, what a difference in resistance, I can turn the rack gears by hand now, should get more road feedback now. Now I have to re-install the rack (I just hate putting things together, then taking them apart and then putting them back together).
    Tony Nadalin
  34. #234
    Kirkland, WA
    Had some time over the weekend, slow but some progress, I wired up the remote kill switch (I have one near driver and one on passenger side for corner workers), also mounted the fire suppression tank, I had a slight change in plans since I went with an AFFF system I had to mount horizontal
    I also figured out were the seat back brace would go and how it gets mounted, I had to move the ECU (poor planning on my part)
    I mounted the inter cooler, there sure does not look like there is a lot of room as it sits pretty high, will have to see if it clears the body panels
    Tony Nadalin
  35. #235
    south-central CT
    Nice work.
    That's how I feel. Slowly crawling forward at my snail's pace.
  36. #236
    Kirkland, WA
    I started on the body work, I decided to use Nut Plates for the side panels and rear bumper/tail section, so this took a little extra work, taking interior apart again, but the results were great, as I have removable panels now. I looked at doing quarter turn fasteners but just not sure I could get the body tight enough.
    I will most likely not go with hinges for the rear cover but figure out a way to use some pins or aviation latch.
    WP_20150222_17_24_11_Pro.jpg WP_20150222_17_23_47_Pro.jpg WP_20150222_17_24_40_Pro.jpg
    Tony Nadalin
  37. #237
    south-central CT
    When you say tight enough, do you mean the ability to draw misaligning parts together or pull them into place (and them be tight)? I know I have struggled a little with a few 1/4 turns, just trying to draw the two parts together.
    I like the nylon and SS washer combo.
    I think I will try and incorporate these pins into my hinge/fastening system where I can:
  38. #238
    Kirkland, WA
    Both, so I used the nut plates to draw the body to the frame and also to draw the rear bumper to the side panels (I did not use the bolts as I wanted to avoid having to have a wrench around to take off body). So will you be using those pins instead of the FFR hood pins ? Have you installed any yet, I like them would like to see how they look and how you installed them.
    Tony Nadalin
  39. #239
    Hindsight's Avatar
    Atlanta
    Love the wiring... very clean. Is that split braid sleeving? What brand did you go with?
  40. #240
    Kirkland, WA
    Tony Nadalin
