Page 21 of 25 FirstFirst ... 111920212223 ... LastLast
Results 801 to 840 of 996
Thread: FFRSpec72 818R Build Seattle WA
  1. #801
    Kirkland, WA
    I have 65ft so I hope it'll be ok. The new nose will be a different color so that removes 3-4ft.
    Sorry about the comment on the door, you have an R so this does not apply to you. I remembered that when I went to sleep last night (I think about 818 stuff 90% of my days and nights).
    I'm amazed you managed the center of the rear bumper in one piece, that must have stretched a lot on the backup/TS lights but you made it.
    I measured last night and I have 25 feet left over from the 75 foot roll and there were 3 attempts on hood so I would say that with 5x50 foot roll you will have plenty and a little left over.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  2. #802
    Kirkland, WA
    I removed all the quick latches (I had used 7 on the rear decks) and just went with standard hood pins, but black posts and carbon fiber scuff plates.
    Tony Nadalin
  3. #803
    San Diego Ca 92106
    Did you find that the hood pins easier to use, or was it more a question of the reliability of the quick latches?
  4. #804
    Kirkland, WA
    Easier to use and better reliability, it is very easy to tell when a hood pin is missing and not so easy to see that the latch is not secure, these are not that simple to line up when you are in a hurry.
    Tony Nadalin
  5. #805
    Do not use quick latches on the engine access panel(s)! We did, not good when fire is involved, the get stuck. Aero latch or sliding hood pins! They ended up just ripping it off our car to get to the fire
  6. #806
    Clovis, Ca
    How about just not catching on fire? . If it's on fire- I could care less about the fiberglass. You already have big problems, especially if you have the gas tank/cell in the original position.
    Thanks- Chad
  7. #807
    did you/are you going to spray clear over the cf wrap?
  8. #808
    Kirkland, WA
    No as I wanted a matte finish for the CF not a glossy one, this goes with the matte grey better I think
    Tony Nadalin
  9. #809
    Reno, NV
    Where is the fuel cell in the NP01?
    818R Build date 10/31/15
  10. #810
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    I found, at least on the CF wrap I used on my interior trim pieces, that applying ANY top coating over it (I tried a eurethane spray-on clear coat and some clear epoxy laminating resin) causes it to turn solid block with zero CF texture or pattern appearing beneath the clear coat. I was using 3M CF look wrap.
  11. #811
    Surprisingly, Fire on the outside of the engine was NOT in the plan, but thank you for the input.
    Everyone is a comedian, I will have my revenge.
  12. #812
    Kirkland, WA
    Major milestone, I emptied the last box over this past weekend, no more FFR boxes !
    Tony Nadalin
  13. #813
    Hindsight's Avatar
    Atlanta
    That is satisfying!
  14. #814
    Clovis, Ca
    Quote Originally Posted by DanielsDM View Post
    You access it by taking the seat out on the inside. 2 barriers (3 with bladder) and more distance than the 818 from the motor (more than double). Plus no hot headers inches from fuel cell- that's why I moved mine on the 818R to passenger compartment. Better weight distribution also.
    Thanks- Chad
  15. #815
    Kirkland, WA
    Our experience is that you are not going to change the weight distribution, once corner balanced and a cross balance of 50% the distribution of the 818 will still be 40/60 with the tank anywhere within the roll cage area, as we played with this and no difference. Moving tank up front out of the roll cage area may make a difference, we did not play with that.
    Tony Nadalin
  16. #816
    Clovis, Ca
    I should of been more clear. I was talking fuel load offset.
    Thanks- Chad
  17. #817
    Reno, NV
    Tony,
    Have you gotten the Race Capture Pro setup working with the OBDII to CAN adapter?
  18. #818
    Kirkland, WA
    Tony,
    Yes I have it going to a 1000NIT JDI screen all is working
    Tony Nadalin
  19. #819
    Reno, NV
    Good to hear it's all working. I'm anxious to get mine up and going, kind of need to finish the rest of the car too.
    What data are you logging via CAN vs. direct connections to the RCP?
  20. #820
    Bowling Green, KY
    Tony,
    A while back you had ask how high my wing is off the rear deck. Well playing with the car today at lunch I remembered your request. My wing is 9" from the highest point on the rear deck to the bottom of the wing.
  21. #821
    While playing with the car today at lunch .
    Rub it in Mitch.
    What wing and AoA.
    When you need gas, do you drive it over to the museum?
  22. #822
    Bowling Green, KY
    Hi Bob, and yes rubbing on it is a nice way to relax during lunch
    I have the APR GTC 300 that FF sells, AoA measured at the cent of the wing is 2* currently.
    We have a Mobil station on site with 87, 93, 98, 104 and 110 octane fuels, I had the the engine tuned to run 93.
    We going to see you at 10/10ths, MVP or our event next month?
  23. #823
    Kirkland, WA
    I am getting ready to head to the track next week and needed to get my wing up higher above the roll cage, so I sent Doug at FORMACARs a cad file of what I wanted and he produced some excellent quality CNC 1/2" T6061 Aluminum wing struts for me. So I am now 6" above the top of the roll cage bar, so 18" off the rear deck as before I was at 11" above rear deck, even with roll cage.
    54C77EE4-59A6-44CD-BDBA-E2020C53233B.jpg 465FE532-544C-489C-80E3-B5F438B17C84.jpg IMG_1135.jpg
    Tony Nadalin
  24. #824
    Now, set your wing to 0-2 degrees and enjoy! The difference now that you are out of the shadow of the cage will be youge!
  25. #825
    USA
    Tony, nice mounts! How did you land on 1/2" thick? Based on the recommendation of my wing builder, I was going to use 3/16" and then add some cross bracing.
  26. #826
    Kirkland, WA
    I talked to the APR folks and they said that 5/16 would be the minimum they would recommend using on the way I have the wing mounted, so I went with 1/2 to be sure I did not have issues as I have my wing pushed back over the edge of the body now.
    Tony Nadalin
  27. #827
    Doug @ Forma's Avatar
    Columbus, OH
    The struts look great on the car, glad to help. Can't wait to hear how they perform!
    (Your Subie in the driveway looks a bit jealous.)
    Doug
    Former Design Director at FormaCars
  28. #828
    Bowling Green, KY
    Nice Tony, have fun and looking forward to a report.
  29. #829
    USA
    Interesting. Thanks! I'm going to need to consult with a few of the MEs turned self-proclaimed aerodynamicists at my company.
  30. #830
    Sgt.Gator's Avatar
    Bend, Oregon
    Lookin Good!
    Tony I take it this means you'll be at the The Ridge Enduro? How about you Jeff?
    Owner: Colonel Red Racing
    818R ICSCC SPM
  31. #831
    Car is going in to the tuner for dyno work and break in. We have tires ready to go, so it's up to what happens this weekend on the new rebuild. We hope yes.
  32. #832
    st george, ut
    retroracing is that your car that caught fire in turn8 at the ridge.
  33. #833
    If it was blue with a white roll cage and hump, then yes. Please don't tell me another 818 caught fire there, I might do damage to myself.....
  34. #834
    Kirkland, WA
    I finished up the data logger and virtual dash this weekend, so almost ready for the track if the rain stays away for more than 2 hrs
    Tony Nadalin
  35. #835
    Kirkland, WA
    New prototype JDI display/tablet going in, should be bright enough at 1100 NIT
    Tony Nadalin
  36. #836
    Kirkland, WA
    Track time today, I lost all power, no boost, and smoke out the exhaust, it's a VF30 turbo
    Tony Nadalin
  37. #837
    May 2013
    Colombia
    Hi Tony, can I ask where you got that JDI display? I can't seem to find a supplier.
    Speedy G
  38. #838
    Kirkland, WA
    Quote Originally Posted by Speedy G View Post
    Speedy G
    Mine is from work but you can get a Cube T7 AliExpress.com as I friend of mine just go 2 from them
    Tony Nadalin
  39. #839
    Car looks great... turbo doesn't -major shame!
    Did you get some good track time in, or did it let go immediately?
  40. #840
    Sgt.Gator's Avatar
    Bend, Oregon
    Oh man the turbo! Sorry to see that.
    I assume the bearing went, which means you have metal shavings in your engine oil. You'll need to pull the oil pan off and check for excessive glitter. You know what happens from there.....
    818R ICSCC SPM
