Thanks Thanks:  2
Likes Likes:  12
Results 1 to 40 of 57
Thread: NISMO_RB25 Texas 818S Build
    Adkins, TX
    Hi Everyone,
    I decided it was time to finally start posting the progress on my build. I have my first child due on Thanksgiving, so my progress may be a bit slow over the next 6 weeks. I am on a sabbatical from work until early January, so as long as I can sneak out of the house every once in a while the updates will continue. Building a kit car has been a dream of mine for a long time, but I wanted something with a turbo and not a replica. The 818S is exactly the kind of build I was looking for and like many of you I put my deposit down a year ago and then started looking for a donor.
    Before we get to the build here is a quick shot of my daily driver and the truck I use to get parts and take out the trash. My addiction to boost isn't limited to any one manufacturer although I will admit the Skyline was my dream car and I got it for a great price. it is one of the federally legal ones.
    The donor was a 2006 WRX Wagon with 119K miles. Most fun negotiation ever when I explained that I was going to tear the entire car apart and I could careless that the body and interior were near perfect. I drove it for several months until the water pump went out. Once I got it apart I found it had a brand new timing belt and pulleys, but they had failed to replace the pump at that time. I will never understand why anyone would do a timing belt and not replace the pump while you are there.
    Why everyone needs a truck.
    Reason 428 to own an old backhoe. Apparently the hay fork can also be used to lift a stripped out wrx to put it on a trailer. That cowboy hat is my father as we both laughed that once again the backhoe was the solution.
    1995 Nissan Skyline GTR VSpec
    818S in progress.
    Adkins, TX
    Here was the kit on arrival. It went into storage for about a month while I finished getting the WRX stripped down so I could fit it into the garage.
    818S in progress.
    Adkins, TX
    I took all the body panels off an put them in storage as they were guaranteed to get damaged in my garage.
    One of the best recommendations I got was to either build or invest in a frame dolly. This one has worked out great allowing me to move the kit car out of the garage and pull in another car when I am done for the day. The other nice thing is the kit is perfect working height if you are sitting on a small rolling automotive stool.
    And reason 429 to own a backhoe was that with some straps you can lift an 818 frame onto a car dolly without having 4 people. BTW as tempting as it seems three people was just not enough to get it on the dolly. Unless you and your friends are body builders get one more friend or a backhoe.
    818S in progress.
    Adkins, TX
    Assembly work started late last week as I was waiting on some parts from powder coating. If you are wanting to get started on your build, but don't wan to get everything done at once you can start by pulling everything off the firewall and then going through all the boxes and getting out the parts. This picture shows everything you need to get started minus the firewall panels which are in the box.
    While I was waiting for the parts I started with dieting the harness. My only advice here is to follow the threads in the wiring section.
    Once the parts arrived I had a pretty productive couple of days. My rivets started looking a lot better once I finally used the guide tool for spacing. In addition to picking one of those up an air powered rivet gun is worth it's wait in gold after you just finished drilling hundreds of holes. Speaking of drilling, a right angle drill is a good investment and if you cut the shaft of drill bit down so that the bit is only a couple of inches long you can get into some of the corners easier. Just remember you will likely have to use a manual rivet gun for those areas.
    Today I put in the new lighter flywheel, clutch, and pressure plate. I found that when trying to do all this by myself that some ratcheting straps on the transmission will allow you to get the transmission bolted back on without killing your back.
    Those same straps came in very handy to getting the motor dropped in as I could tilt it however needed to make it work. In addition to removing the oil filler neck, don't forget to remove the oil dipstick. If you take the heat shields off the bottom of the headers then you should have no issues getting the engine in. If you want to make it even easier take off the plastic intake under the manifold and the oil dipstick tube.
    I didn't get a picture of it, but I ended up running a strap vertical which worked out better than the one you can see in the above picture.
    818S in progress.
    Adkins, TX
    And the final update for today is the motor is in place and Fedex showed up with the two inner CV joints that mate up to the Quaife differential output shaft.
    818S in progress.
    Huntsville, Al
    So..you might want to grab those door hinges off your donor....also your upper control arms look like you have them upside down...the upper ball joint should be tilted towards the car (inboard) not out....moving right a long though!!
    Adkins, TX
    I pulled the hinges off already. Good catch on the upper ball joint. I thought for some reason mine were on correctly, but I looked through a bunch of build threads and apparently I am wrong. Not looking forward to pulling those back out since I almost ripped my bench vise off the table putting them on.
    818S in progress.
    Senior Member AZPete's Avatar
    Nice start, NISMO. Congrats on the arrival of the 818 and especially for the arrival of your first baby!!!
    I'll PM you about some donor parts I'd like to buy. Check the "notifications" at the top.
    Houston
    I may have missed it,....where are you located in TX. I'm NE of Houston near IAH.
    fred
    Adkins, TX
    I am near San Antonio so not all that far away.
    818S in progress.
    Adkins, TX
    A decent amount of progress today, but only because I chose not to fix my incorrect front suspension.
    Here is a pick of the assembled rear axle using the stock outer, the FF provided middle section, and the inner joints to mate up to the new diff.
    For the rear suspension I didn't heat up one of the shock collars enough and spent way too much time beating it into submission. The second one was well heated and dropped in with no effort. When assembling the rear arms make sure you keep the two bags of spacers separated or plan on measuring them to figure out which ones to use. I must say installing those spacers can be a pit of a pain so having a few pry bars or big screw drivers and a mallet helps.
    I also realized I didn't have the transmission mount and had to go hunt that down. If I don't have a baby tonight I will be at it again tomorrow.
    818S in progress.
    You should not be working that hard if you are pregnant. LOL.
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Now that was funny!
    Great progress BTW
    Exeter R.I
    Quote Originally Posted by NISMO_RB25 View Post
    What diff you using, how you going to lock 02-04 stubs in with a closed LSD?
    Encinitas, CA
    Funny, I had no issue assembling my coilovers... I was prepared to heat them up, but they all dropped right on.
    I picked up a super-cheap pair of calipers from Harbor Freight... would I trust them to a mil? probably not, but they've earned their keep identifying the spacers.
    P.S. Someone suggested a rattail file drill attachment to ream them out; I got one from Amazon for $5.
    Adkins, TX
    you lucked out on the coilover collars. I would have never gotten them on without heat. I picked up a caliper from Summit and it has definitely proven valuable when I drop the spacers and managed to kick them across the garage.
    818S in progress.
    Adkins, TX
    I ended up changing the ball joint and then changing it back as the angle wasn't correct as can be seen in the picture. Today was spent moving the LCA to the outer most holes which was a lot of grinding, cursing, hammering, and more hammering.
    818S in progress.
    Huntsville, Al
    your looking at it at full droop, when the control arms are in ride height the ball joint is almost straight up and down...your car build as you want...I didn't validate the wagon install though either...
    Adkins, TX
    Thanks for that. This is my first kit car build and I appreciate any input. I have gotten far too good at swapping them out so I will take another look once I start adjusting ride height.
    818S in progress.
    Adkins, TX
    Well the little girl has decided she is happy where she is, so we have scheduled an induction on Wednesday before daylight.
    They were both helping me in the garage today.
    I drilled a couple of hundred more holes today and used clecos to hold everything in place.
    The sad part is removing it all for powder coating.
    818S in progress.
    Exeter R.I
    Congrats man!! I have a little girl 3 now and were having our second which is in progress, if you have any questions shoot me a pm etc
    Adkins, TX
    Thanks for the support. We have had a busy couple of days with not much sleep, but my wife and new little girl are both home and everyone is healthy. I can pretty much guarantee my updates will be slow going for the next month.
    818S in progress.
    Congrats to all three of you!! We are all glad to hear that the baby girl is home and happy. She is darling! I'm not surprised that you are exhausted and I predict that you won't get a full nights sleep . . . or many rivets set . . . for quite a while. Enjoy the time, as it goes quickly and what seems like only a month she'll be asking to borrow the car. Wait, it will be the 818 Dad built!
    Bowling Green, KY
    Congratulations, what a beautiful girl.
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    VERY cute! Congrats!!
    Exeter R.I
    Awwww, very beautiful, congrats
    Freeport, ME
    Congrats, your first? BTW caution: They Grow UP! :-)
    Edmonton, Alberta
    And they grow quick! I blinked and my daughter was starting school...
    Congrats!!
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Freeport, ME
    Starting school... mine's 17 and hormonal! LOL
    Wonderful... congrats.
    Mechie3's Avatar
    Now you have to sell the car. You didn't finish before the baby came. Game over.
    Congrats!
    Adkins, TX
    The interior panels are now installed along the sides and hopefully tomorrow I will get started on the pedal assembly and steering column. The textured powder coating looks great and I will definitely use that for the remaining parts. If I haven't said this enough the air rivet gun is awesome.
    818S in progress.
    Adkins, TX
    The pedal assembly along with the brake and clutch master cylinder are now installed. I used a riv-nut tool and almost got it stuck trying to get the top riv-nut in place for the gas pedal.
    818S in progress.
    Adkins, TX
    Since my donor is an 06 I am using the drive by wire pedal. The mount provided by FF put it at a very odd angle and low. Here is the factory mount:
    Here I cut off the top portion, drilled one extra hole, flattened the bottom tab, and like magic it lines up perfectly with the other pedals.
    I would recommend two people to put the steering column in so that one can line it up while the other mounts it in place.
    818S in progress.
    Mechie3's Avatar
    What rivnut tool is that? Does it work well? The inner shaft on my harbor freight ones deformed after doing 2 of the 1/4-20 rivnuts. I want to rivnut the body in place instead of riveting and don't want to do the screw/nut method for all of them.
    Adkins, TX
    It is just a cheap one I got from Northern Tool. For the price if it doesn't hold up I can just buy a couple of more. I have only done about 4 so far, but I think as long as you adjust the tool correctly it should hold up.
    http://www.northerntool.com/shop/too...D-_-707-_-CONF
    818S in progress.
    Freeport, ME
    I found that I needed to grind the face of the tool's insert to get the stud fully threaded into the nutsert. I have done more than 100, mostly 10-24 inserts with mine from Harbor freight
    Adkins, TX
    Well after 9+ years, two kids, and moving out of TX and back to TX, I am resuming the build.
    Today I got the brakes to all work.
    Unfortunately when I went to fill the transmission the axle seals are leaking. New seals should be in this week.
    818S in progress.
  39. Thanks Rob T thanked for this post
  40. #39
    DFW, Texas
    What part of Texas are you in? I'm going to have to slow my build down if I want to make the longest build time record, haha. Currently at 6-7 years.
  41. #40
    Adkins, TX
    Quote Originally Posted by NevaLift2Shift View Post
    I am close to San Antonio. Wife said I can't buy another project until I finish or sell this one, so 100 degree weather seems like the perfect time to be in the shop. We need to hurry up before FF discontinues some of the add on parts we might want.
    818S in progress.
