Likes Likes:  2
Page 6 of 27 FirstFirst ... 4567816 ... LastLast
Results 201 to 240 of 1079
Thread: MRG MotorSports 818S Build
  1. #201
    Hi Frank,
    Using KIR-47900 Seat, Aluminum, Intermediate Road Race, 15 Degree Layback, 18 in. Hip Width,
    I added a custom bend to the back of the kirkey seat. It is 5.5" from firewall at bottom. 2.5" at the 10" high bar and touching the 24" square bar and touching the angled roll bar.
    The cross brace is right under my bent knee. So no problem at all.
    Here is a picture of my seat test a long time ago. I will be permanently installing it this week. I'll post more pictures.
  2. #202
    Getting ready for a dyno run
    This week I am going to Turn In Concepts to do a dynamometer run for 2 reasons.
    First: To make sure everything in my engine is running proper.
    I don't want anything going on that will break the motor, like a lot have experienced.
    Second: I want to establish a base line for my engine.
    So I can see the result of modifications I make later.
    Currently my 2004 FXT 2.5L turbo AVCS DBW engine (93K) is pretty close to stock. The only significant change is that I have no exhaust after the catalytic converters.
    The published numbers on my engine are:
    210 max HP @ crankshaft
    235 max ft-lbs @ crankshaft
    Does anyone want to take a guess at my wheel HP and torque numbers will be?
    I would also like to get some opinions on my future mod list.
    My application is Autocross, track day and daily driver.
    I put the list in the order of importance.
    Engine reliability mods
    Air to water intercooler
    STI style oil Pan and pick up.
    Accusump
    External Oil cooler
    Low oil pressure / hot engine LOUD buzzer (marine type)
    Help engine breath easier.
    K&N air Filter
    tgv delete
    equal length headers
    up pipe without CAt
    down pipe with out CAT
    Misc improvements
    add gauges
    Wide band AFR
    Boost gauge
    AOS system
    Performance Mods
    bigger turbo
    turbo blanket
    Please make recommendations as you see fit.
  3. #203
    Bob, I like the upgrade list above. It's nearly identical to mine including the wide band AFR etc. If you later go with a bigger turbo, depending on how big you go, most of them will require a fuel pump and injector upgrade too. Also, it seems that anything more than a stock turbo with a tune is going to really be pushing the stock pistons so you'll probably want to price in some machine work and some forged pistons in that stage of the build, unless you are ok with the high chance of blowing your ring lands and then doing a bigger build after that happens.
    RE the headers.... not much bang for the buck with the stock turbo. It will also take away the characteristic subie rumble and make it sound more like a Honda instead. Some don't care about that, some do.... but a good header runs $800 - $1700 and you will want to spend more money on header wrap or coating (wrap is the way to go IMHO). You can get a bolt-on turbo upgrade for that kind of money. It also seems to be a challenge to find a header that will fit in the 818.
    RE your tuned HP rating with current components.... ~250-270 WHP would be my guess, but it depends on how aggressive they go with it and the brand of Dyno.
    Good luck with it and keep us posted!
  4. #204
    I believe the 04 forester xt came with strong internals. Is this correct?
    I was going to use a EL header off my NA engine with a custom up pipe and cat removed.
    I want it to sound like a Porsche, not a Honda.
    I'm not going to do a tune yet. Just a verification.
    It is a Dyno Dynamics AWD unit
  5. #205
    I haven't been in Subaru's long enough to know... maybe one of the resident Subaru gurus on the forum will chime in on that one.
  6. #206
    Accusump
    External Oil cooler
    K&N air Filter
    tgv delete
    up pipe without CAt
    Misc improvements
    add gauges
    Wide band AFR
    Boost gauge
    AOS system
    Performance Mods
    bigger turbo
    turbo blanket
    Anybody else have comments or suggestions on this?
  7. #207
    Member CanadianYank's Avatar
    Sep 2014
    Carstairs AB
    Not a Suby expert Bob but Im interested in your findings. I'm guessing 30HP more? Good luck and have fun!
    The most important things in the world have been accomplished by people who don't give up and have just kept on trying...
  8. #208
    Encinitas, CA
    But it'll sound like this Porsche:
    (pretty much like a Honda)
    Not this one:
    unless you put an H6 in!
  9. #209
    First drive milestone tonight.
    Tonight Michael and I both drove the 818 for the first time.
    It was only a few hundred feet in and out of the garage.
    Michael first comment was that it didn't have very good traction. Every time he would leave out the clutch the tires would spin
    His next comment was that he thought he had to push on the brakes pretty hard.
    I think both comment were understandable. The R888 were cold and the brand new south bend 2 stage clutch really grips. Michael normally dumps the clutch at 3000 Rpm on his 4wd impreza and he only thing hat slips is the clutch.
    Second, He has never driven a car with manual brakes. The power booster increases the pressure by a factor of 6.
  10. #210
    Senior Member Quiny's Avatar
    Massachusetts
    You may already know this but the proportioning valve needs to be screwed in all the way to have no effect, I never read the instructions and assumed out was bypassing.
  11. #211
    Quote Originally Posted by Quiny View Post
    Hi Quiny, thanks for the suggestion.
    I don't have the proportioning valve installed.
    Instead of reducing pressure to front brakes, I plan to increase the size of the rear brakes.
    I also have antilock actuator installed (plumbed) but not wired yet.
  12. #212
    Massachusetts
    Do you mean the stock ABS or is this something different? If it is something different please elaborate. I was thinking the same thing about increasing the size of the rears to compensate, I hate the idea of a front proportioning valve.
  13. #213
    I am using the stock ABS unit.
    I also hate the idea of a front proportioning valve on the 818. I have a plan for the rear brakes see post# ( I will edit when I find it) couldn't find it but here is a picture. Basically changing to a vented rotor with a dual piston caliper should double my rear braking force. Then I will put a proportioning valve on the back if needed.
  14. #214
    Exeter R.I
    From my experience with the 818 the brakes are more than we need with the 4pot/2pot setup I am running. I can smoke the tires and come to a hault with great control. As you mention manuel brakes do feel like you have to push harder when you first try them, but once you get used to them, IMO they have a much better feel and control on a lite race car. Abs can't hurt.
  15. #215
    Red face Measured corner weight
    Michael and I just had the second biggest day in our 818 life.
    The best day was the day we pick up the kits.
    Today we spent the afternoon at Turn In Concepts.
    Got a Dom tune
    measured corner weights
    did a bunch of go karting.
    First corner weights:
    Michael adjusted ride height to 4.5 eyeballing the spring to get them to equal lengths.
    Michael was within 1%. Not bad for a rookie.
    Also the total weight of 1564 LBS in go kart mode. We might make the magic 818kg number.
  16. #216
    Wow, those are spot on!!! With or without Mike in the car?
    I never realized the body panels would weight as much as 300lbs.
  17. #217
    they don't.
    we are in go kart mode. no doors, no windshield, no dash, no nose steel.
    without Michael or I in the car. We won't talk about those numbers. Let's just say either one of us would easily but it over 1800 lbs.
  18. #218
    While we were at Turn In Concepts http://turninconcepts.com/today we had them check out the performance of our engine.
    Totally stock 2004 XT 2.5L TD04 Stock Turbo 90k miles
    Tune done by Dom Acia of http://getadomtune.com/about.html
    After Dom deleted all my CEL codes (evap system and automatic transmission)
    He took a look at the power.
    Boost was set at 12psi
    Out of the box we were at 185whp
    He did his magic an raised it to 195.5whp
    I love the way it stays near peak hp from 4000 to 6500 rpms. Means I won't upset the car if I keep the rpm between those 2 points when shifting.
    220 ft-lbs torque means 1.48g in 1st (if tires would stick) 0.88G in second and 0.62 G in third. I'm good with that.
  19. #219
    Tony and Dom of Turn In Concepts take the 818 out for a spin (wet roads with slicks)
    By the way, Tony (dark hair) is 6"2"
  20. #220
    I learned a couple interesting ECU functions yesterday at the tuners.
    1. The neutral safety switch and the speedometer must be hooked up for AVCS to work
    2. I have a DBW (drive by wire) throttle. I do not have a throttle pedal stop installed. Pushing the pedal al the way down causes an ECU fault and puts it in LIMP mode. Disconnecting battery power for a few seconds will reset the ECU.
    LTD
  21. #221
    San Jose, CA
    Picking up the news a couple of days late. Congrats on the runs, major milestone accomplished!
    Quote Originally Posted by svanlare View Post
    Thanks Steve,
    After scales, dyno, and go karting we had a meeting to discuss modification.
    Immediate action Items:
    Accusump
    AWIC
    Pedal Stop
    Oil Cooler
    motor/trans mounts
  23. #223
    Regarding the DBW pedal stop.... How do you know where to set the stop?
  24. #224
    I had no clue.
    This is what I found in the manual.
    Says stroke should be 2.05 to 2.24 inches.
  25. #225
    Ah cool thank you. The manual surprises me...... sometimes it omits things that are critical and other times it defines everything (like gas pedal travel lol).
    Adding a note for this in my build notes.
  26. #226
    If you think about it, this is a necessary safety feature. As the pedal goes down, the sensor resistance goes down and the voltage goes up. At some point, the resistance goes down to a point where it looks like a short circuit. If the ECU didn't freak out about this, then if there was ever a short in the pedal wires, the car would get stuck at full throttle.
  27. #227
    Quote Originally Posted by Jaime View Post
    My pedal actually has redundant potentiometers in it. That's why it has 6 wires.
  28. #228
    Mechie3's Avatar
    Any reason to keep the boost at 12psi? Running a stock downpipe? I used to run my 06 (same engine and turbo as your FXT) at 21 (stock block, plenty of other mods).
  29. #229
    I am not a turbo guy, but 21psi out of a TD04 sounds like a lot.
    My up and down pipe are both stock and both have cats.
    I asked for at tune at stock pressures for reliability and to get used to driving the car. I am very glad I did. This car at 1564 lbs, is stupid fast.
    Dom told me my engine was the same as an STI, if I add a stock STI turbo and intercooler. Then could be at 300+ HP.
  30. #230
    Jay like our bike
    A little off topic, but I guess I can hijack my own thread.
    Just got word "Jay likes our bike"
    He took it out for an hour ride in the hills around silicon valley.
  31. #231
    Massachusetts
    That is incredible, what an accomplishment. He must have really enjoyed it to be out an hour. Congratulations, when do they go into production?
  32. #232
    last month was the official release.
  33. #233
    Mechie3's Avatar
    It was a lot. Pushing the edges of what it can reliably do. Lasted for 4 years before the car was totaled. The cat's would be a big reason not to do that. Stock downpipe has the flat flange too which causes problems.
  34. #234
    Hi Craig
    I think I will like my motor curve with 12PSI of boost.
    If I get rid of the cat in the up pipe and go with an exhaust like stickshifts.
    Where could I get to raising the boost? (staying with the TD04)
  35. #235
    San Jose, CA
    Accusump
    AWIC
    Pedal Stop
    Oil Cooler
    motor/trans mounts
    AWIC and Oil cooler I'm considering what to do in the initial build now. I'll be watching the mods here and on some of the other threads closely as cooling seems to be a recurring theme.
    Senior Member Stickshift84's Avatar
    Rhode Island
    Awesome work guys and great videos!!! Keep up the great work. Seeing your power level puts my car and a bigger build plan in perspective. My engine is hurt but further modified than yours and only making about 14 psi now. So I figure am making maybe 230 hp. It is simply a blast to drive. Cant wait to feel mine once I get it around 300 to the wheels (end goal).
  37. #237
    Michael's first drive
  38. #238
    Were you somehow able to check how good/not so good the rear rad location works? I believe we have to wait for the full body to be on, but just in case you saw something out of the ordinary.
  39. #239
    We have not run hard enough even for the ecu to turn on the radiator fans yet.
    We did about 10 dyno pulls but TIC had a big fan blowing air through the radiator.
    I have temporally mounted a fan for the TMIC.
    We will not know for sure until hot weather, body on and a track day.
    I am confident that there will be no issues.
    But I have been wrong before and will be again.
  40. #240
    Bigger rear brakes
    Went to bigger rear brake. Using front calipers on all four wheels. H6 rotor, drilling and grinding to mount the bracket. Brake pad modification also. I maintained the parking Brake. Sorry Rasmus this one is heavier.
    Does anyone want to trade me for some matching red shocks?
