I'm trying to decide between Vintage Air's front runner, Sean hyland and KRC power steering. http://www.krcpower.com/ecommerce/ca...sult/?q=coyote
http://www.seanhylandmotorsport.com/...coyote-engine/
http://www.vintageair.com/cyotfrntrnnr.asp
I went with the Front Runner. Easy install; just one engine blank to drill/tap. Plus, it looks great, integral to engine. Comes with the compressor, so tell Jeff you won't need the compressor. Got my Front Runner from Mike Forte. I think when you add-up all the components (compressor, pump, brackets, pulleys, belt, tensioner) prices are competitive.
Thanks dale I'm leaning towards the vintage air, KRC also make a cast iron pump that is less than $500 that's S800 less without ac which I could always run later 800 can buy alot of cold air.
