Page 15 of 20 FirstFirst ... 51314151617 ... LastLast
Results 561 to 600 of 779
Thread: 818Rasmus E Modified
  1. #561
    Bowling Green, KY
    Nice work, now I have an option to my 3/4 4130 tub shaft I plan on fabing up.
  2. #562
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    Intimidating.
    This is the first time I've ever cracked open a transmission. Awe, wonder, and excitement mixed with a little bit of sick. And there's no shiny metal bits in the bottom. Getting the speedo gear in looks straight forward. LSD's gonna be a learning experience.
    Fast Cars, Fast Women, Fast Haircuts!
  3. #563
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    From what I've read, the diff swap is fairly easy. The tricky part is checking the lash. I'll be following your steps closely since I will be opening my case as well.
  4. #564
    Apr 2014
    While that cover is off... I'll just leave this here...http://www.subarugears.com/Casing.html
    http://www.youtube.com/watch?v=RXEUSVSpGHg
  5. #565
    Las Vegas, USA
    Quote Originally Posted by MrDude_1 View Post
    I like the way you think Dude.
    As much as I would love to do that, I probably won't. I'm worried about losing mounts for the transmission, compromising the structural integrity of the transmission case for the two remaining mounts, plus I need to keep several mounting holes for the cable shifter. I've also learned that trying to cut weight by shaving cast aluminum is low reward for the large amount of time invested.
  6. #566
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    The LSD install was not as bad as we thought it would be, although it was time consuming (probably around 8 hours total to open the case, sand blast the case, install the lsd, set the lash, and close it up. We posted links in our donor thread here to where we found other forum members "how to's." The Subaru factory manual is also great with diagrams showing the grease contact patches and how to adjust to get the right back lash.
  7. #567
    Keep your eye on the bearing at the gear end of the pinion. If you bolt the cases together and the pin on the bearing isn't in it's home, you could do some serious damage to the case halves.
  8. #568
    Mechie3's Avatar
    Indianapolis
    I cut that back piece off. Forget how much it weight. You do need to figure out something else. There's a guy (D Clymer?) on the Vanagon webside that has a chopped down rear with a plate welded on it with two studs for mounting. It's $400 though.
    Zero Decibel Motorsports
    Check out my new website!
  9. #569
    Las Vegas, USA
    Ring gear came off the factory open differential easy.
    Right side bearing pressed off easy. Having trouble getting the left side bearing off. I don't know how to do it without destroying it.
  10. #570
    Aug 2013
    Santa Rosa CA
    Buy a new bearing, life is to short.
  11. #571
    Las Vegas, USA
    Got the hypoid gear ring side bearing off the open differential without damaging it. Thanks Andrew. Cleaned and installed both bearings on the torque biased differential. Quaife brand.
    Correct garage door springs arrived. Installed! Works! It's glorious.
  13. #573
    Aug 2012
    Long Island
    Quote Originally Posted by Rasmus View Post
    plus you are left with a free meat grinder! BBQ in Vegas next spring!
  14. #574
    Feb 2014
    Asheville, NC
    Just my $0.02- Careful with those shims (highlighted in your photo, attached). They bend very easily and if they're off you might not have good engagement on the pinion gear.
  15. #575
    Hindsight's Avatar
    Atlanta
    Very cool! Any reason you wanted to re-use the bearings instead of get new ones since they are so cheap? Timeline, cost? Maybe new bearings would require more lash adjustment?
  16. #576
    Senior Member xxguitarist's Avatar
    We re-used them since OEM is around $60 ea.
    Still had to adjust the axial position of the front LSD, but since the ring/pinion are the same, the shims at the end of the gear shaft were good to go.
  17. #577
    Las Vegas, USA
    I reused them because they looked fine. Races weren't discolored from heat. No pitting. No scoring. Just the normal marks you see on a bearing race. The bearings themselves looked good too. No pitting, scoring, or rainbow colors. While I could have spent $45-$50 for two new bearing sets, I didn't see a reason to spend that money and wait for the delivery. I also repacked and reused all my wheel bearings.
    Plus Andrew reused his so I gave in to peer pressure.
  18. #578
    Hindsight's Avatar
    Atlanta
    Guess I am obligated to do the same then, that is, if my Quaife ever arrives. I ordered it in June.
  19. #579
    Kirkland, WA
    You forgot to put back the endcap on the steering shaft (where the seal is) :-(
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  20. #580
    Las Vegas, USA
    Thanks for helping me out with something I may have done incorrectly, but you've got me at a loss. Got a picture of what I'm missing? I don't know what that is.
  21. #581
    Hindsight's Avatar
    Atlanta
    On mine there is a white plastic piece that looks like it covers the 1" large-diameter section of column in the pic above, right where it exits that rubber bushing. Maybe it's a year-specific thing? I can take a pic of mine when I get home this evening.
  22. #582
    Kirkland, WA
    Yep that's the piece, I don't have a picture with me to post, not sure it does much except keep the dirt/water/etc. out. I have seen these on 2002/3/4 models, not sure about later models. It may have fallen off or been removed.
    Tony Nadalin
  23. #583
    Hindsight's Avatar
    Atlanta
    Mine's an 07 so definitely is there on the later models. Will post a pic tonight.
  24. #584
    Chicago, IL
    Also have the same on mine - damn thing does pop off rather easily though; it's just lightly pressed in there. Mine is an 05-07 column, so should be same as Hindisight. I'll post a pic of it if it's any different though.
    Honestly, I was planning on removing it anyway...none of the FFR cars seem to run it.
    Best,
    -j
    Executive Director
    The Community Garage
  25. #585
    Hindsight's Avatar
    Atlanta
    Might save 5 grams of weight by removing it but gain 3 grams per year in grime
  26. #586
    Apr 2014
    If it does, you can utilize the WD40 and rag weight reduction system. With the R-version cowl installed, can you still reach there easily?
  27. #587
    Las Vegas, USA
    Hows my tooth engagement look?
  28. #588
    Hindsight's Avatar
    Atlanta
    Looks pretty good to me. Did you have to adjust anything at all?
    Here are the pics of the bushing:
  29. #589
    I switched to yellow because it's hard to see the pattern in Prussian Blue. What's the other face look like?
  30. #590
    Las Vegas, USA
    Here's a better version of the ring and pinion engagement pattern.
    Drive Side
    Coast Side.
  31. #591
    Las Vegas, USA
    Thanks for the pictures of the bushing I'm missing. My donor didn't come with that.
    As far as the Ring and Pinion, no, I didn't adjust anything. I just dropped the output shaft and differential back in after swapping to the T.B. differential and checked the pattern. I feel like I'm really lucking out with this transmission. Everything just seems too easy. I'm suspicious, I'm missing something.
  32. #592
    Did you use Dykem?
    We used a non-drying blue grease. Lets you get a lot of rotations, and not have the odd double wear pattern?
    Also, just to double check, you torqued down the transmission case halves & the bearing plate at rear for the pattern?
  33. #593
    Las Vegas, USA
    Yep, Dykem, the 'normal' kind.
  34. #594
    Las Vegas, USA
    Figured out what the Factory Service Manual wanted me to do, to measure the ring gears backlash.
    I just couldn't figure out where they wanted the roller ball to go. Plus it didn't mention that I need to 'lock' the pinion down to measure the backlash.
    My rig.
    Backlash: 0.008"-0.0085". Glad I measured too. Factory limits are: 0.0051"-0.0071" so I'm running a little sloppy. Reads like the FSM made a typo:
    Each time holder rotates one tooth, backlash changes by 0.05 mm (0.020 in).
    0.05mm = 0.0020". So if I adjust by one tooth total, backlash should drop to 0.006"-0.0065".
  35. #595
    Hindsight's Avatar
    Atlanta
    It doesn't look like you torqued down the transmission halves though..... did you? I don't see any bolts above. However, I also don't recall if the Shop Manual tells you to do that but it seems like you'd need to.
  36. #596
    Las Vegas, USA
    They're only six bolts holding my transmission cases halves together for this measurement. With maybe 20 ft-lb. The two "big ones" that surround the output shaft's bearing right near the pinion and the four that hold the back of output shaft to the back of the case near the shims. FSM didn't read that I needed to torque to spec the case halves before measuring, but that section of the FSM is seriously lacking in detail.
    Moved the backlash adjusters half a tooth tighter each. For one tooth total. I found I could do half tooth adjustments if I just flipped the locking tab over.
    Backlash measured at 0.006" now. Which is right in the middle of the FSM's spec (0.0051"-0.0071"). Nice. As far as 'feel', with the 0.008" I could feel the ring gear clunking into the pinion when I turned the output shaft with my hand. With 0.006" I can't feel it clunking.
    Updated Drive-side tooth engagement pattern as a result of tightening up the backlash.
    Updated Coast-side tooth engagement pattern as a result of tightening up the backlash.
  37. #597
    Hindsight's Avatar
    Atlanta
    Great info. I agree on FSM. Did you need the special tool to turn the backlash adjusters?
  38. #598
    Las Vegas, USA
    No. Which is just bizarre to me. I'm getting so lucky with this transmission, I feel like it shouldn't be going this easy. Like I'm wasting all my hotroding luck on this one part. All I did was get one of my blunted screwdrivers with the most tip surface area, put that on one of the teeth and gave it a few small taps with a 5lb dead blow. 4 taps and I'd moved it 1/2 tooth.
    I'm gonna torque to spec the case halves around the pumpkin. See if the backlash changes. Good thought there Hindsight. Let's see.
  39. #599
    south-central CT
    How can you call it a frikin pumpkin? It's in a transaxle. JK. Relax...
    The manual is seriously deficient in so many ways. I was trying to diagnose a center diff issue and read this wonderful Subaru English technical-speak:
    "In MANUAL MODE, as the operation amount of DCCD control dial (driver’s will) is prioritized, the control that increases/decreases the engagement power of solenoid clutch LSD is performed."
    I made an adjuster by just bolting two 1/4-20 bolts in a long plate to act as a wrench on the side-plates.
    Don't forget about how it "feels" VS pre-load and the eventual thermal expansion of the aluminum VS that of the steel.
  40. #600
    This $10 tool from Amazon works excellent for turning the side adjusters:
