Likes Likes:  4
Page 7 of 11 FirstFirst ... 56789 ... LastLast
Results 241 to 280 of 411
Thread: SixStarCars' 818R - NASA ST3 - SCCA Solo X Prepared Build Thread
  1. #241
    Feb 2013
    Westminster, MD
  2. #242
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    Keith, I love your work.
    /begin hate
    But, I've got a whole gallon of Hate-orade for the Pink and Blue.
    So bitter tasting!
    /end hate
    How many guys you got working on the car?
  3. #243
    Senior Member Brando's Avatar
    Irvine, Ca
    Whenever my girl peers over at my screen and sees the pink she makes it a point to say how cute it is. We usually end up in a fight over it
    Your build is pretty tight, look forward to seeing it next month.
  4. #244
    Feb 2013
    Westminster, MD
    I am the only person working on this car.
  5. #245
    Senior Member BrandonDrums's Avatar
    Triangle area, NC
    CEL: Typically caused on EJ20 motors with a single cam sensor and using a light pulley and light FW or just a stupid light FW. My theory for this is that with only a single cam sensor the ECU is estimating the timing on the other bank. If it rev's too fast it gets outside of the tolerance zone for cam position interpolation. The AVCS motors have dual cam sensors, one for each side. I ran the 1lb pulley and a 14lb (?) flywheel. Never had issues.
    Harmonic balancing: I don't know where it is but I saw a technical letter written in response to an inquiry from Subaru stating that the OEM pulley is NOT a harmonic balancer.
    Difference: It does. Revs freer, easier to rev match, frees up a little power (more noticeable when off boost). Not my video:
    http://www.youtube.com/watch?v=e5VPh9LqjaI
    In my experience, it seems that the false misfire code from having a lightweight fly wheel actually happens when pulling off throttle, or when the AC kicks on. Not when you're revving the engine up while on-throttle. Similar theory to yours but the reduced flywheel inertia allows the engine to slow down more between ignition pulses so the ECU thinks it's misfiring.
    An actual misfire would behave the same way where RPM's would drop mid-cycle due to a loss of an ignition pulse. With a light weight flywheel, accessory loads can overcome the rotational inertia and replicate the behavior of an actual misfire by having the engine slow down more than expected over a single revolution of the engine. The ECU then assumes there was a loss of an ignition pulse and throws the code for the cylinder that was up for it's bang when the RPM drop occurred according to the crank position sensor.
    Edit: The reason this happens more on the 2.0L engines is due more to the lower sample rate of the ECU as the 2.5L WRX and STI in the US all have 32bit ecu's while all USDM 2.0L models ran on 16bit setups. The false misfire codes still happen on STI's, my bud has an 07 STI with both a lightweight flywheel and lightweight standard size crank pulley and he gets codes when in 5th gear pulling slightly up hill when the AC kicks on as well.
  6. #246
    Feb 2013
    Westminster, MD
  7. #247
    Puyallup, WA
    Wheres the GoPro video of you driving it?!
  8. #248
    Encinitas, CA
    Nice shot... looks great! (still trying to dig the pink, though ). Will the intake fit there with the body on, or is that just for g-carting?
  9. #249
    Mechie3's Avatar
    What's the tab that sticks up just underneath the Sparco lettering?
  10. #250
    Feb 2013
    Westminster, MD
    https://www.youtube.com/watch?v=zGxwbhkDjZM
  11. #251
    Feb 2013
    Westminster, MD
    Not the final intake mounting location, that was done in about 2 minutes.
  12. #252
    Feb 2013
    Westminster, MD
    Mount for the "trunk" Tried to not have the requisite 47 hood pins.
  13. #253
    south-central CT
    I like the CAI location. Finally, somebody using the side vents for something. Can't dig on the pink. Carry on.
  14. #254
    Irvine, Ca
    Ain't nobody got time for dat!
    hah that was classic
  15. #255
    Puyallup, WA
    Wise guy eh?
  16. #256
    Feb 2013
    Westminster, MD
    This is Keith's office assistant. He's in the hospital, he had a heart attack. Turns out the shock of you FINALLY saying something that wasn't negative just pushed him over the edge even with the slam at the end. Don't worry scrote, you'll smile one day and learn not to hate.
  17. #257
    Freeport, ME
    I'll be praying for a speedy recovery, God bless...
  18. #258
    Irvine, Ca
    That's intense. I wish him a speedy recovery. Get better soon Keith!!
  19. #259
    Encinitas, CA
    I think/hope that was a joke on Keith's part.
  20. #260
    818 Junkie... bstuke's Avatar
    Atlanta, GA
    Have they even allowed it in XP yet? From what I know 2015 will be E-mod.
    Yep.
    818R For Sale!
    818R Sale Thread
    PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
  21. #261
    Irvine, Ca
    If your joking it might be nice to clarify that
  22. #262
    iWire's Avatar
    Lake Forest, CA
    I'm guessing he's fine.
    When we say to our customers "if there is anything you need, please ask," we mean it.
    iWire Subaru Wiring Services
    Over 100 Custom 818 Wiring Harnesses Built
    http://www.iwireservices.com/factory...18-wiring-kits
    [email protected]
  23. #263
    Chicago, IL
    Now we're having fun again! =)
    Pretty sure that was a joke...good one too. C'mon Glyn, you've got to admit that was damn funny.
    Best,
    -j
    Executive Director
    The Community Garage
  24. #264
    south-central CT
    I didn't know I could bring on a heart attack. I like to think that I had a little help.
    Too bad Keith missed my other positive comment, "I like the plumbing work." and an off-hand compliment when I said "I don't think you are delusional." I do like the blue color, BTW!
    Might just be SEMA looming. Poor guy.
    I promise to lay off. Get better soon.
  25. #265
    Mechie3's Avatar
    I lol'd.
  26. #266
    Feb 2013
    Westminster, MD
  27. #267
    Leesburg, VA
    That killer B oil pan sure is dangling below the frame, you worried about speed bumps at all?
  28. #268
    Mar 2014
    Vacaville, CA
    Thanks for the pictures. There are several angles from underneath, like the motor mount pic, that aren't normally posted.
    What tubes are you using for the lateral links? They look very slick.
  29. #269
    Feb 2013
    Westminster, MD
    If there's a speed bump on a race track I've got much larger concerns.
  30. #270
    Feb 2013
    Westminster, MD
    Quote Originally Posted by Boog View Post
    Welcome. They're the standard cheap FleeBay chinese 6 piece kit with some fancy powder coat is all.
  31. #271
    Feb 2013
    Westminster, MD
    Also, yeah I'm ok. It was a bad joke.
    Here's the requested video of some neighborhood lapping.
    https://www.youtube.com/watch?v=w7Pq...ature=youtu.be
  32. #272
    Leesburg, VA
    Ha forgot this was the R. Maybe it's an optical illusion but just looked like that pan was going to be 1" off the ground.
  33. #273
    Las Vegas, USA
    The location of the brake bias valve gives me ideas.
  34. #274
    Irvine, Ca
    Quote Originally Posted by Santiago View Post
    Best,
    -j
    Guess who is gullable.
    <--- this guy!
  35. #275
    Feb 2013
    Westminster, MD
    Quote Originally Posted by brando View Post
    guess who is gullable.
    <--- this guy!
    Sorry!!!!
  36. #276
    Feb 2013
    Westminster, MD
    I can turn down the rear circuit only this way. The front locks way before the rear does, but when that changes I can dial it back a bit. WORST case I have to redo one line and I can put another in the front.
  37. #277
    Kirkland, WA
    Same location as in my challenge car, will be putting the one that came with the kit in the rear (since its just a splice in the line running down console and if needed will install one on front. There is not a lot of console space as I have the emergency brake there, shifter, bias valve and fire extinguisher pull, no room for cup holder in the R
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  38. #278
    5th pic from top. I see what seems to be fuel lines coming from over the tank and making a 300-deg back into the engine bay. There is enough space to route them there after the panels are on?
  39. #279
    Feb 2013
    Westminster, MD
    Acres. The body is 6-8" away from the frame right here, hell you could route the intake back into the area above the fuel tank if you wanted.
    This is semi-temporary. I don't like that if I was to get blasted in the side right there it could cut a fuel line. Worst case scenario I know but I'm going to move them after SEMA. Right now everything is being done fast, simple, and shiny. There will be a 2.0.
  40. #280
    Car is looking nice. Wish I could make it to SEMA, seems like 2014 is the year of the 818.
