Thanks Thanks:  20
Likes Likes:  104
Page 22 of 25 FirstFirst ... 122021222324 ... LastLast
Results 841 to 880 of 967
Thread: Adam's Canadian 13B Rotary 818-SR Build
  1. #841
    First guess was Australia, based on the 'top' picture . Sounds like a sweet trip
  2. Likes AZPete, longislandwrx liked this post
  3. #842
    However I finally had an opportunity on Monday to go for my inspection, and I failed. Not terribly though, but I’m working on getting the fails addressed in the next few days and going back for re-inspection.
    Attachment 115716
    That sucks. What elements failed?
    Where you aware of those before the inspection or they pulled a Trudeau on you during inspection?
  4. #843
    Edmonton, Alberta
    3rd high mount brake light (still pretty sure this isn’t a legal requirement), my battery tie down was a thick rubber strap like on a motorcycle (has to be metal). Window defrost, I had a little 12v thing that sticks on your dash that others have passed with, but this guy needs vents all along the windshield not just one spot. Need a brake fail light showing either low fluid or low pressure. Since I’m using a remote reservoir I can’t do fluid level so I’m installing a brake differential switch. And when I installed my bump steer kit I forgot add a second jam nut on the outside by the spherical joint.
    Everything is done but the brake switch, which I should have done today.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  5. #844
    God damn, Adam, and I thought QC was picky! Maybe we have an overall tougher inspection but you got more picky details.
    Also very surprised you need a full defrost on an open top, totally useless. Now I reckon the snow 1-2 weeks ago but that is not a reason for a defrost! I'm surprised you already fixed that one which seems to by far the most difficult to implement.
    True you did some super major implementations on the car already so a defrost is not going to slow you down. loll
  6. #845
    Edmonton, Alberta
    Finally!
    What a day! So I had all the items that caused me to fail addressed, appointment booked, left early just to be sure. Last “nice” day, probably for the year based on the forecast. At some point during the 20min drive I blew a -10 oil line. I didn’t notice it until I was pulling into the shop and seen that oil pressure was around 1bar. I was logging, but for some reason the file won’t work, so no idea how low the pressure got or for how long. So here I am, parked outside the shop, oil EVERYWHERE! With all the lines and coolers this thing takes around 10 Litres, dipstick was dry.
    I used the push lock style lines, which I’d since learned that they’re not good for oil (despite being rated for it), especially on a rotary which runs really high oil pressure. Since I’d need to remove the entire body to replace the lines, I decided to just add some hose clamps to get me through the inspection process and do the lines over the winter. Well one of the lines on the driver’s front oil cooler let go and spewed everywhere, even came in the footwell!
    Standing outside with the mechanic looking at all this mess it starts raining. So we push it into the shop and start talking about how I can get it home. I decide to hack up the cooler line that burst, disconnect both coolers and just install a loop on the thermostat to bypass them all together. He grabs me some tools and says “I’ll get started on the paperwork”. Wait, what? I’d totally ruled out passing an inspection and was just focused on damage control. So I installed my new line, added 3.5 Litres of oil and fired it up, good pressure. I cleaned up what oil I could and paid for my inspection. He was happy with all the fixes I added since the first inspection, and knew I’d fix the lines properly based off the rest of the build.
    I was a mess on the drive home, such a mix of emotions. I’d just passed my inspection, but did I toast the engine? Rotaries rely on oil for 50% of their cooling, am I going to make it home without overheating the oil? Will another line or my new one fail? I was glued to my dash, pressure was staying good but the oil temp was climbing. I told myself if it hits 100c I’d pull over and see if it goes down idling or maybe shut it off for awhile, but it was getting really windy and bad weather was approaching fast! Just about home and getting off the highway I hit 100c, but it starting dropping as I slowed down for my exit and made it home! Holy sh!t that was stressful!
    So it’s very bitter sweet. I’ve driven it over a 100km between the two inspections, but with winter setting in this evening and the need for new lines, I don’t think I’ll get to drive it with the plate on this year. Big plans over the winter, tearing the car down quite a bit to wrap it and install a bunch of upgrades. My motivation is high though, so I’m excited to get her looking and performing her best for the spring!
    818 SRX - #91
    Arrived 01/02/2014
  7. #846
    Denver, CO
    Sorry to hear about oil, but congrats on plates!!!
  8. #847
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    I second those emotions.
  9. #848
    In a way I'm relieved to see other people get those frustrating issues I got, but in another way I feel so much the god damn frustration you went through!!!! That sucks so much... so much!
    10L of oil?? Wow and I thought I had a lot with 8... loll
    I get those emotions!!! I went through those many times and still go through the very very stressful emotions every single time I drive the car. I know exactly how it was when you drove back and it ain't a pleasant moment.
    However now you can concentrate on fixing the issues, just like me. You and I really are in the same boat. lolll One suggestion, try to keep your motivation high, when it drops, you feel bad.
    Very happy that inspector was kind enough to let it go and saw how you build and that there's no point of not fixing this properly, so he understood!!
    And you know what, I got my plate on Oct 13th 2017! Almost exactly 2 years day for day! You and I are really the same. lolll
    Keep it up and I will too!
  10. #849
    My Xmas present for you, bud.
  11. Likes Bob_n_Cincy liked this post
  12. #850
    south-central CT
    George Barris got hold of an 818 kit.
  13. #851
    Did you know George died 4 years ago?
  14. #852
    Hey...that interior is almost as nice as AZPete's!
  15. Thanks AZPete thanked for this post
  16. #853
    Edmonton, Alberta
    Merry Christmas to you too bud! Love the Zonda, in fact the Zonda R is my poster dream car, just savage!
    Haven’t worked on the car for a couple months. I told my wife that once I got my plate I’d finally do some renovations that I’d been putting off for years. All done those, and LOTS of parts lined up for 818!
    First to show up is my Radium FCST (Fuel Cell Surge Tank) which I’m really excited about!! Two pumps in the surge tank and then the lift pump. I’ll only need the one pump for gasoline, but if I decide to push the limits and run e85 I’m all set. Also nice to know that there’s a spare pump just sitting there.
    I’m going to build a new tank out of aluminum, and I’m thinking of putting the pump assembly to the passenger side and making a access panel behind the seat so I only need to remove the one seat to access everything. The pickup would still be fairly close to the centre, and even with the surge tank I’ll install some sort of baffling. Also need to add a vent line to the filler as my first fill at the pump resulted in gas puking everywhere.
    I’m not sure what I’m doing with the engine yet. I’ll do a compression test, cut open the oil filter and inspect the oil for any bearing material. I’ve got a lot to do, so ideally I’d prefer to postpone a rebuild until next winter.
    818 SRX - #91
    Arrived 01/02/2014
  17. #854
    Edmonton, Alberta
    Filmed this last spring, along with more content throughout the summer that I just never go around to editing. Admittedly it’s a bit winded, but it’s hard to make the final touches and the teething of a new build interesting. This one is a little rotary premix 101, tuning idle, compression testing, cooling system whoas and when it’s finally time to go for a drive I realize I don’t have reverse. Doh!
    818 SRX - #91
    Arrived 01/02/2014
  18. Thanks 7tvette thanked for this post
    Likes Kurk818, 818sNH, 7tvette, Santiago, Frank818 liked this post
  19. #855
    Edmonton, Alberta
    818 SRX - #91
    Arrived 01/02/2014
  20. #856
    Edmonton, Alberta
    Almost caught up on content. Picking out a wrap color now!
    818 SRX - #91
    Arrived 01/02/2014
  21. #857
    Edmonton, Alberta
    So excited to get this installed! Unbelievably short crisp shifts and fully adjustable. It’s the K-Tuned Rev2 Street billet shifter. Found some cables locally for $60cad! They’re not perfect as the bulkhead threads to cable end is longer, but for the price and availability I couldn’t pass them up and I’ll make them work. Cables are 84”, which is about 6” longer than I needed but my routing now incorporates a sweeping “S” that shouldn’t affect the feel of the shifting much.
    The side to side motion needed to be reversed which I was able to accomplish by rotating the pivot arm mounting and making a new bulkhead mount. Once I have the Blast Plates from Moore(group buy on hold due to Covid-19) I’ll remake both bulkhead mounts so I didn’t get fancy with the temporary one.
    Next up is a new fuel tank!
    818 SRX - #91
    Arrived 01/02/2014
  22. #858
    Feb 2019
    Houston, TX
    I think you have me sold on one, I'm positive it will work really well with my mechanical linkage. As soon i recover from the COVID-19 financial fallout I'll pick one up.
  23. #859
    Edmonton, Alberta
    New gas tank ready to finish welding up.
    818 SRX - #91
    Arrived 01/02/2014
  24. Likes aquillen, DSR-3, Kurk818 liked this post
  25. #860
    Edmonton, Alberta
    Feels like it took forever to get here but very satisfying to finally bolt this in! Just waiting for fuel lines and fittings in the mail...
    818 SRX - #91
    Arrived 01/02/2014
  26. #861
    Edmonton, Alberta
    My inspection day story...
    https://youtu.be/cHMUQVh4-kw
    818 SRX - #91
    Arrived 01/02/2014
  27. Likes Blu, AZPete, STiPWRD, DSR-3, Kurk818, Santiago liked this post
  28. #862
    Senior Member AZPete's Avatar
    A huge congratulation, Adam! That's a gripping video of inspection day.
  29. #863
    Jan 2020
    Crazy story! Congrats on getting the plate.
  30. #864
    Edmonton, Alberta
    Thanks guys. Hell of a day, but just another part of the journey!
    818 SRX - #91
    Arrived 01/02/2014
  31. #865
    Man o man that looks good and what a RELIEF for the plate! Plz don't do like me and ENJOY the car!
  32. #866
    Edmonton, Alberta
    You mean tear it apart and rebuild it?
    Too late!
    818 SRX - #91
    Arrived 01/02/2014
  33. Likes Kurk818 liked this post
  34. #867
    Edmonton, Alberta
    I made a to-do list. Who thinks I'll be driving my car this summer? And who thinks I'd prefer to work on it and will just tear it apart every time its done? ( I swear it isn't the case, lol)
    https://youtu.be/4mn4CaJWmw4
    818 SRX - #91
    Arrived 01/02/2014
  35. #868
    That to-do list reminds me of my few lists I made from time to time... still got one open!
    I think you will be driving the car every other day this summer AND taking it apart the other every other days! How 'bout that...
  36. Likes Canadian818 liked this post
  37. #869
    Edmonton, Alberta
    Been busy this spring, actually looks like I’ll get to enjoy the car this year!
    https://youtu.be/nENlZwT9lr0
    818 SRX - #91
    Arrived 01/02/2014
  38. Likes Bob_n_Cincy, Santiago liked this post
  39. #870
    The Quick Latches are a pain in the beeep cuz you're not using springs. I have 20lbs springs on every quick latch and it works superb, it pushes the panel up every time I press on the latch.
    Curiously I cannot find the springs anymore on their website...
  40. Thanks Canadian818 thanked for this post
  41. #871
    Edmonton, Alberta
    Thanks frank but I’ve moved on from them. I have 6, so I’m sure I’ll try them again on another project someday and look for springs then.
    818 SRX - #91
    Arrived 01/02/2014
  42. #872
    Chicago, IL
    Just an FYI. The GTC-300 is a twisted element wing. The basic rationale for this style of wing is that its designed to work with a fastback style rear window (think Ferrari, the 818C, etc.) by optimizing it's angle of attack (AOA) across the wing's span. Airflow along the sides of the car is more or less level with the road. However the airflow coming over the roof and down the sloping rear glass approaches at a steeper angle. So in this application the wing "sees" the air coming at it from different angles, thus making for different AOA across the span. Solution: twist the element to accommodate for that condition. Setting the tips at 0AOA is likely to produce the same AOA in the middle when the air is flowing down the rear glass (now flowing "straight on" towards the upturned middle section).
    Without a fastback profile, I would focus on the middle AOA. That has the greatest span, so this will contribute more to the wing's performance. Yes, that means the tips will be at a heavy AOA, but that's just life with a twisted element wing. Test - test - test.
    Best,
    -j
    Executive Director
    The Community Garage
  43. Thanks Canadian818 thanked for this post
  44. #873
    Edmonton, Alberta
    Quote Originally Posted by Santiago View Post
    Best,
    -j
    Thanks for the advice man!
    The plan is to add some form of roof in the near future. This was the wing FFR offered with the 818R back when the car first came out. Obviously it was the wrong wing for that car, especially with no windshield. They did do testing with it and if I recall correctly they recommended the centre of the element be set to 0* which makes the sides 15*. That was with the race splitter and diffuser which I also have. So that’s where I’m going to start. Once I’m able to get on track I’ll play with increasing the angle after I’ve gotten aquatinted with the car and track. Lots of testing in my future!
    818 SRX - #91
    Arrived 01/02/2014
  45. #874
    Lots of testing... I know what that means! Trust me... loll
    Here you go, just for you in case you change mind in the future.
  46. Thanks Canadian818 thanked for this post
    Likes AZPete liked this post
  47. #875
    Thanks for posting that Frank. I just bought a bunch of those QuickLatches and felt my stomach drop when I heard the comments about them. Your solution makes sense and looks very straight-forward to implement.
  48. #876
    Quote Originally Posted by sgarrett View Post
    I can provide more pix on my thread if you need, but since I could not find the springs on Quik-Latch's website, I searched and found them elsewhere: https://www.speedwaymotors.com/Quik-...it,139590.html
    Maybe either get them from elsewhere or ask Quik-Latch if they still source those...
    Never failed on me, once you adjust the latches properly, angle, height, those springs work like a charm. And god knows how many times I pushed on my latches to remove my deck lids and open up my hood.
  49. #877
    Just ordered some springs. Thanks for the link!
  50. #878
    Lemme know your feedback once you install them. Your thread, my thread... I think Adam might be jealous he removed his too quickly.
    Speedway Motorsports was a good place when I ordered the bumpsteer kit, for which I ordered double of everything and sent half to Adam. I can't recall if you installed that bumpsteer kit on your extreme build, Adam?
  51. Likes Canadian818 liked this post
  52. #879
    Adam you bast...! You thought you'd get away without us knowing? We all know you are hiding in your garage to replace your apex seals with "never-break" seals and this new engine "while you're at it":
    BUSTED!
  53. #880
    Edmonton, Alberta
    Haha Frank, no engine builds going on here. Just working on making her pretty and tinkering with my RX8 as I learn to drift. I did install the bumpsteer kit, made a video about it, and gave you credit in the video. Obviously someone isn’t watching my video's, lol.
    Here’s a little teaser...
    818 SRX - #91
    Arrived 01/02/2014
  54. Likes mikeb75 liked this post
