Results 1 to 5 of 5
Thread: Cruise Control switch
    Senior Member AZPete's Avatar
    The WRX has the cruise control switch mounted in the steering wheel so when I installed the FFR steering wheel I had to find a place for the cruise switch. I ended up mounting it past the ignition key - still easy to reach.
    Subaru gave us a nice strong bracket at the bottom of the steering column to hold the cruise switch. Remove the plastic cover at the bottom of the steering column to find this steel bracket then remove the 3 (very tight!) screws holding the bracket.
    I had to cut and bend the edge of this bracket to mount the cruise control switch, in its steel mount, with two bolts. I then cut a chunk out of the plastic cover for the switch. Once connected to the OE wiring the ECU should not know the difference.
    Suisun City, CA
    Awesome! Good job, Pete!
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
    Exeter R.I
    Nice job, but don't think you will use it much, cause downshifting and passing will be much more fun!!!
    Nov 2012
    Huntsville, Al
    Sweet! Thanks for sharing. That idea is a keeper!
    Freeport, ME
    Great job xcellent documentation. Just what I might need to do!
    Dan
