Hey all,
I am chasing a donor and looked at one this evening. This question is not to discuss donor but an issue I found.
The guy changed the s/w and is using an NRG quick release.
But when you turn and engage your turn signal, when you come back straight the turn signal and arm don't stop flashing. The arm stays in blinking mode and so the flasher. He said apparently it's cuz he's using a quick release and remove the OEM s/w.
I'm not sure about that!
If yes, it means everyone using an 818 and not using the OEM wheel will end up having to put the flasher arm back to it's rest position manually.
What are your thoughts?
