0
0
2005 Factory Five Racing Challenge Car
The Challenge Car model is the professional competition racing version of the Type 65 roadster. The race car is designed single-mindedly for racing dominance, and with this California based Challenge car you’ll be able to run with the best… and do it the right way, with safety and performance.
Built from the foundation of the proven 65 roadster chassis, the modified challenge car chassis meets SCCA GT1 design criteria and has been seriously upgraded in all areas to address the specific needs of the competition driver.
I am selling my 2005 Factory Five Challenge Car with an extra set of wheels, two transmissions and the spares listed below. I am the original owner and racer. It has been a very competitive car, better than the driver. It is in great condition, very clean and very well built. The car meets the original specifications or previous rules that do not include the power and brake upgrades, but the spares package includes the parts and upgrade kits needed to meet the new rules. This car does not have a passenger seat. To make this vehicle physically street legal it would need the lighting wired up, a horn and a windshield added. The car is located in Corona, California.
Engine
5.0L Ford V8
1.7 Ratio Roller Rocker Arms
Aluminum Under-drive pulleys
Stamped Valve Covers
Canton 7qt Front Sump Oil Pan with windage tray
Vented aluminum oil overflow tank
AFCO Aluminum Radiator
Cooling Fan with on engine thermostat trigger
JBA 1 1/2 primaries exhaust headers
Polyurethane Energy Suspension motor mounts
Mobile One Synthetic Oil used
Electrical
Well organized, easy access simple wiring harness
Ignition Coil mounted on engine
Trunk mounted battery
Cockpit mounted cut-off switch
Headlights and Brake lights wired in
Gauges-Auto Meter Ultra-lite Mechanical Tachometer, Fuel level, Oil Press, Temp
Push button ignition switch
Wheel/Tires/Brakes/Suspension
Factory Five 5 Spoke Lightweight 20lb Wheels (17"X9" 5/114.3 w/35mm offset)
Carbotech XP Brake Pads
Ford Fox body 11” Front Rotors
1994 Cobra 10.5” Rear Rotors and Calipers
1994 Cobra master Cylinder
Castrol SRF Brake Fluid
Front Brake Air Cooling Ducts
3-Link Rear Solid Axle w/Panhard bar
Koni Front shocks with 700lb Springs
Bilstein Rear Shocks with 500lb Springs
Toyo RA1’s
Steering
Fox body power steering rack
Fox body steering pump with extended reservoir neck
Redline Fluid
Drivetrain/Chassis
Tremec T5Z Transmission with Steel Throw-out shaft
Deist Safety Bell housing Blanket
Adjustable aluminum clutch quadrant
Spec Clutch with Steel Flywheel
Steel Driveshaft
2.73:1 Ratio Ford 8.8 Axle with welded suspension brackets and axle tubes
Black Powder Coated Chassis
Driveshaft Loop Welded in
Side intrusion plates
Fuel
Fuel Safe SM122-AFF Aluminum 22 gallon Fuel Cell
Aston Lemans Gas Cap Side Fill System
Exterior/Interior
Competition Windscreen
Hood scoop painted black, not cut out for improved aero
Driver accessible Fuel cut off switch
Fire Bottle fire suppression system
Aluminum full containment racing Seat (Light weight Kirkey racing passenger seat available)
5 point Seat Harness (current)
Great visibility with convex side mirrors and curved center pedestal mirror.
Easy paint touch up with flat black and high gloss Viper Red racing stripes with decal add-ons
Easy touch up high temperature exhaust coating
MoMo padded steering wheel that is easy on hands for long races
Additional Details
Always cleaned thoroughly and checked for damage after every race
1st Race was May of 2005 with top 3 race position finishes consistently
NASA race log book included
Easily meets weight rules
To make street legal the car would need the blinkers and license plate wired, a horn installed, and a windshield purchased and installed. The chassis has mounts for the windshield to mount up.
Spare’s
Complete Engine and suspension upgrade kits to meet the new rules
Brand new T5Z Transmission
Kirkey racing Passenger seat
1 set of racing/street wheels
$25,000 or OBO
Mike Beeler
951-733-8953
Reason: rewrite
Sure I have more pics... but I'm limited in the number I can place here. If you want more pics send me you addy and I'll forward them to you.
- You may not post replies
- You may not edit your posts
Forum Rules
