Results 1 to 3 of 3
Thread: 2005 Factory Five Racing Challenge Car
    Dec 2011
    The Challenge Car model is the professional competition racing version of the Type 65 roadster. The race car is designed single-mindedly for racing dominance, and with this California based Challenge car you’ll be able to run with the best… and do it the right way, with safety and performance.
    Built from the foundation of the proven 65 roadster chassis, the modified challenge car chassis meets SCCA GT1 design criteria and has been seriously upgraded in all areas to address the specific needs of the competition driver.
    I am selling my 2005 Factory Five Challenge Car with an extra set of wheels, two transmissions and the spares listed below. I am the original owner and racer. It has been a very competitive car, better than the driver. It is in great condition, very clean and very well built. The car meets the original specifications or previous rules that do not include the power and brake upgrades, but the spares package includes the parts and upgrade kits needed to meet the new rules. This car does not have a passenger seat. To make this vehicle physically street legal it would need the lighting wired up, a horn and a windshield added. The car is located in Corona, California.
    Engine
    5.0L Ford V8
    1.7 Ratio Roller Rocker Arms
    Aluminum Under-drive pulleys
    Stamped Valve Covers
    Canton 7qt Front Sump Oil Pan with windage tray
    Vented aluminum oil overflow tank
    AFCO Aluminum Radiator
    Cooling Fan with on engine thermostat trigger
    JBA 1 1/2 primaries exhaust headers
    Polyurethane Energy Suspension motor mounts
    Mobile One Synthetic Oil used
    Electrical
    Well organized, easy access simple wiring harness
    Ignition Coil mounted on engine
    Trunk mounted battery
    Cockpit mounted cut-off switch
    Headlights and Brake lights wired in
    Gauges-Auto Meter Ultra-lite Mechanical Tachometer, Fuel level, Oil Press, Temp
    Push button ignition switch
    Wheel/Tires/Brakes/Suspension
    Factory Five 5 Spoke Lightweight 20lb Wheels (17"X9" 5/114.3 w/35mm offset)
    Carbotech XP Brake Pads
    Ford Fox body 11” Front Rotors
    1994 Cobra 10.5” Rear Rotors and Calipers
    1994 Cobra master Cylinder
    Castrol SRF Brake Fluid
    Front Brake Air Cooling Ducts
    3-Link Rear Solid Axle w/Panhard bar
    Koni Front shocks with 700lb Springs
    Bilstein Rear Shocks with 500lb Springs
    Toyo RA1’s
    Steering
    Fox body power steering rack
    Fox body steering pump with extended reservoir neck
    Redline Fluid
    Drivetrain/Chassis
    Tremec T5Z Transmission with Steel Throw-out shaft
    Deist Safety Bell housing Blanket
    Adjustable aluminum clutch quadrant
    Spec Clutch with Steel Flywheel
    Steel Driveshaft
    2.73:1 Ratio Ford 8.8 Axle with welded suspension brackets and axle tubes
    Black Powder Coated Chassis
    Driveshaft Loop Welded in
    Side intrusion plates
    Fuel
    Fuel Safe SM122-AFF Aluminum 22 gallon Fuel Cell
    Aston Lemans Gas Cap Side Fill System
    Exterior/Interior
    Competition Windscreen
    Hood scoop painted black, not cut out for improved aero
    Driver accessible Fuel cut off switch
    Fire Bottle fire suppression system
    Aluminum full containment racing Seat (Light weight Kirkey racing passenger seat available)
    5 point Seat Harness (current)
    Great visibility with convex side mirrors and curved center pedestal mirror.
    Easy paint touch up with flat black and high gloss Viper Red racing stripes with decal add-ons
    Easy touch up high temperature exhaust coating
    MoMo padded steering wheel that is easy on hands for long races
    Additional Details
    Always cleaned thoroughly and checked for damage after every race
    1st Race was May of 2005 with top 3 race position finishes consistently
    NASA race log book included
    Easily meets weight rules
    To make street legal the car would need the blinkers and license plate wired, a horn installed, and a windshield purchased and installed. The chassis has mounts for the windshield to mount up.
    Spare’s
    Complete Engine and suspension upgrade kits to meet the new rules
    Brand new T5Z Transmission
    Kirkey racing Passenger seat
    1 set of racing/street wheels
    $25,000 or OBO
    Mike Beeler
    951-733-8953
    Anymore pics?
    Dec 2011
    Sure I have more pics... but I'm limited in the number I can place here. If you want more pics send me you addy and I'll forward them to you.
