Thanks Thanks:  8
Likes Likes:  31
Page 12 of 26 FirstFirst ... 2101112131422 ... LastLast
Results 441 to 480 of 1012
Thread: Frank's 818R build
  1. #441
    Feb 2014
    Asheville, NC
    The efforts for street legality started last night. Did some E-brake work, cleaned up the interior a little, and started on my windshield:
    I laid the R windscreen over it so I could make similar cuts for the bars. It's probably going to wait until the weekend, though, since another set of hands would help a lot I think.
    Also, the front rivets on the windshield/screen are going to be replaced with riv nuts to help make the change between windshield and windscreen easier/faster.
    As far as I see it, my list is as follows:
    License plate mount
    Plate light
    Charcoal canister
    Windshield
    Wiper
    E brake
    Switch plate for interior switches
    Rear bumper
    Front deck lid
    Blinkers
    Missing anything obvious?
  2. #442
    Clovis, Ca
    Just make sure if you (Or anyone) drives an R on the street, wear a helmet. Those angled side bars (near your head) will kill you in a very minor collision.
    Thanks- Chad
  3. #443
    Feb 2014
    Asheville, NC
    You're exactly right. I intend to wear a helmet and a HANS anytime I get in the car.
  4. #444
    Connecticut reg. requires: hazard switch, factory style 3 point seat belts (no harnesses), shift pattern on knob, label on fuse box (if visible within cockpit). I don't know if N.Y. is similar.
  5. #445
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Quote Originally Posted by tmoretta View Post
    Just a small correction - the seat belt rule is just that it must be FMVSS209 certified. We went through inspection with 5 points without any issues, but they wanted to see the tag. Schroth has some that are DOT legal. They never looked for our fuse box.
    Tamra
    First autocross 3/29/15
  6. #446
    Feb 2014
    Asheville, NC
    Huh. I never thought about DOT approved harnesses. I'll give a call and see what they say. If I need to, I'll pull the second seat and buy a single Schroth just for inspection.
    NY has a ton of rules but most of them I'm either exempt from or conform with, as far as I read.
  7. #447
    What are those rivets/rivnuts for on the windscreen? I don't have that.
  8. #448
    Feb 2014
    Asheville, NC
    Frank- What you see in the photo are nuts and bolts (1/4"-20's) that hold the windscreen to the mount. What I am talking about is how the race windscreen is held on the car. I have it rivited to the frame with 3/16's rivets. Two of them. I plan to replace them with 1/4-20's as well.
  9. #449
    Oh! The race windscreen, yeah ok I get it now.
  10. #450
    Feb 2014
    Asheville, NC
    Windshield was a ***** to install. I had to trim everything like a hundred times. It sorts fits. 33" to the roll bar and 26.25" to the corner of the door panel. It looks and feels great.
    How did you all attach the glass to the frame?
  11. #451
    Leesburg, VA
    I had a local auto glass guy professionally install mine for $150 after calling about 10 different places. Just tell them you need to install an MR2 windshield in a convertible, many places will not want to take on the liability of a non-standard glass install.
  12. #452
    +1 $175 with trim rubber
  13. #453
    I got it installed with approved glass silicone/caulking, just like it's been done on a normal car. I think it cost me $CAD90, 13 months ago. I promised the guy I'd show him the finished car in June 2015... doh!!! lollll
  14. #454
    Edmonton, Alberta
    What pump did you get with your surge tank? Where did you mount it and how's the noise? I got excited buying parts today and picked up some parts for my surge tank including a walbro 255. I just read online that their quite loud, might take it back for a Bosch 044, they're a little quieter.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  15. #455
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    I have the Walbro 255 and can verify that it is quite loud. I can hear it over the engine.
  16. #456
    Feb 2014
    Asheville, NC
    I mounted the surge tank directly to the frame. It's extremely loud; I can hear it over the engine if I'm idling. However.... without a windshield, the car is pretty loud at speed. So....whatever, race car!
  17. #457
    Edmonton, Alberta
    Is your pump in the surge tank or external?
    818 SRX - #91
    Arrived 01/02/2014
  18. #458
    Feb 2014
    Asheville, NC
    Mine is internal to the surge pump. I ordered this guy.
  19. #459
    Frank, Am I correct in my thinking that you still have original pump in the main tank?
    I was thinking that you would only need a low pressure pump in the main tank.
  20. #460
    Feb 2014
    Asheville, NC
    Bob,
    I've always had a Walbro 255 in my main tank. That's what my (built up) donor came with. I have one in my DD and have found them to be reliable and good for a lot of power. Not wanting to limit my power just to save some money, I got another Walbro 255 for the FST. I'm sure I could get away with a smaller pump in tank at this point.
  21. #461
    Feb 2014
    Asheville, NC
    I forgot to upload this one before. Changed some alignment stuff and forgot that the car handles differently with a passenger (my dad). Got it loose on the first lap and then over corrected. Turned her around pretty quick! You can also hear how loud the fuel pump is (though it's biased since the GoPro is close to it).
  22. #462
    Frank,
    I've had many spins like that.
    If you look at you steering wheel, You had very little steering input when it first broke loose.
    Were your tires cold?
    Is your car normally that loose?
  23. #463
    Feb 2014
    Asheville, NC
    Frank,
    If you look at you steering wheel, You had very little steering input when it first brook loose.
    Bob,
    I'm mostly blaming it on both cold tires and lots of on the fly suspension adjustments. Figured I was at the track for the last time for the year, might as well play with stuff! I found some things that worked, and some that didn't (see above for the didn't)
    Car is normally pretty stable, especially through minimal steering input turns like that one
  24. #464
    That was a real snap! It almost looked like you caught a bit of the curb, but when I looked a second time you weren't on it. Were you letting off the throttle? (trying to get my head around the car behavior since I have no MR engine experience)
    I'm sure there's a funny caption between you and your dad
  25. #465
    Feb 2014
    Asheville, NC
    Made a bumper for street legality. It's not mounted yet (paint is currently drying), we'll see what NY says.
  26. #466
    Feb 2014
    Asheville, NC
    Oh! Almost forgot!
    Check out my windshield! Glass installed by First Class Auto Glass. Was Just under $100 with trim. Fantastic service, we talked cars for a while, they gave me a few cans of cleaner and a roll of their favorite glass wipes. Very good experience.
    Also, woke up to this on 10/18-
    Winter is coming, and fast. Jealous of all you California guys right now.
  27. #467
    Feb 2014
    Asheville, NC
    Update- sounds like my bumper WILL be good by NY state So excited!
  28. #468
    Hindsight's Avatar
    Atlanta
    Congrats! I can't even imagine snow right now...... crazy seeing that pic.
  29. #469
    You will need a bumper if you drive it in snow. lolll
    I can't believe you got snow before me. That's almost impossible...
  30. #470
    Feb 2014
    Asheville, NC
    Frank- we get a LOT of snow being right on Lake Ontario. It starts in October and usually gone by mid May. Means I have a lot of time to improve the car over the winter (and lots of time to hoon around in my WRX)
  31. #471
    I like your build man... Kudos!
  32. #472
    is the DOT a lot more picky when it comes to inspecting a custom car?
    Some of those things... bumper... glass windshield...interior switches (for what) would either get past my radar or seem unnecessary.
    As a side note, why did FFR ditch the bumper from the S version? You would think that if you are going at insane speeds on a race track or going at insane speeds on a race track in some form of wheel to wheel racing, that you would want that extra protection.
  33. #473
    True. We have huge plans over the winter, don't we.
    Only thing is you won't be able to test your improvements until May. loll
  34. #474
    Feb 2014
    Asheville, NC
    Quote Originally Posted by AgentH View Post
    Thanks! I apprecaite it.
    Agent, the NY DMV is picky about the weirdest things. They have their rules clearly written out, and they really care about some of them to a T, and some are.....eh, whatever.
    As for the bumper on the S...I didn't think it really had one in the rear? Either way, what I designed will in no way further protect me at track speeds. That's what the roll cage is for.
    Always
  35. #475
    Feb 2014
    Asheville, NC
    Had to space the license plate lights to make them actually light up the outside of the plate instead of behind it. Naturally, a washer didn't fit where I drilled the holes, so I needed to hack up washers. Everything on this car takes longer than I anticipate! lol
    Looks good, though!
    Also did my third brake light (high mounted on the roll bar behind the driver's head), some troubleshooting on the blinker/hazard circuit, and some *tuning* of the car (removing engine codes).
    I can't figure out one thing, though. When I turn the key to OFF, the ECU loses its retentive power. Trip odometer resets, CELs reset, so I assume learning resets. I'm sure it's from one of the pins coming from the integrated module or something like it that I deleted. However, I can't seem to find any pin that clearly is that constant 12V power to the ECU in the OEM wiring diagram. Anyone have insight to it? Maybe an ECU pinout?
  36. #476
    Feb 2014
    Asheville, NC
    Tons of progress this weekend. First up, garage modification:
    Added insulation so you can't see quite as much day light through the roof, and put up plastic on the ceiling. Then I added a thick plastic sheet (4mm) to drape down. The area is big enough to contain the car and still be able to work. It'll be a lot easier to heat this small confined area in the sub-0 temperatures. Also it'll be nice to not have snow getting inside the garage from the roof.
    Rear deck lid is on! Doesn't fit with the intercooler, so I'm plumbing the turbo directly to the intake(just for NYS inspection).
    Got my weight certificate for NYS inspection. 1,880 lbs according to their scale, with the street windshield and a small steel bumper. I'm not sure how accurate it is, and I have a feeling that's a little lighter than reality. 8,540 for the truck, trailer, car, 2 people, and a few tools. Lots of weight!
    Mounted and wired my defroster. I like my little switch panel (with hazard and OBDII port on the bottom).
    On the agenda before my inspection:
    -Windshield wiper (assembly should be here this week, courtesy Tamra/Andrew- thanks guys!)
    -Charcoal canister
    -Cleanup of wiring/fluid leaks
    -Intake plumbing (parts on route!)
    -E brake tensioning
  37. #477
    Apr 2014
    Shelton, CT
    Frank,
    1880lbs is very light. We were only a little below that before adding the body. How full was your fuel tank? Was that without driver? I'd be curious to see the car on quality scales at some point. Do you plan to corner balance it?
    Glad we could help on the windshield wiper assembly! It's already at the post office and you should see tracking info update later today.
    Tamra
  38. #478
    Feb 2014
    Asheville, NC
    Frank,
    This is without driver, and the fuel tank was about 1/3 full (plus the extra fuel in the Radium tank). I do plan to corner balance it once it has the aero on.
    I figure the street windshield + assembly, steel rear bumper, defroster, tow straps that were just hanging off of it (since it was just unload/reload without actually driving the car), etc. are all good for ~50-70 pounds.
    Awesome! Can't wait to fight with that next.
  39. #479
    Hindsight's Avatar
    Atlanta
    Must be because you haven't painted it yet
  40. #480
    Feb 2014
    Asheville, NC
    Then maybe I won't paint it! haha
    Calling Rasmus: what do you think, Mr. Lightweight? Is this scale just wrong?
