Results 1 to 11 of 11
Thread: Wheel spacers
    Senior Member rcotner's Avatar
    Wilsonville, OR
    Wheel spacers
    I have 20X315 wheels and clearly will need spacers. According the the FFR manual I need 1" spacers but that is with 290 rubber. By eyeball it looks like I will need 2" spacers. Any recommended brands or web sites for purchasing? I do not plan to install fenders.
    Fresno, CA
    I would check out Sunnit. Remember with the spacers you will also need longer lugs!
    Doug
    Senior Member Boz1911's Avatar
    May 2013
    Peachtree City
    That's a lot of spacer, what offset are your wheels? I'm using 20 inch wheels and almost that wide of tire with no spacers and I have plenty of clearance. I'd do some measuring before adding spacers and long wheel studs. Depending on the length of the wheel studs and without modifying them you may need open end lug nuts which may or may not detract from the looks of your wheels.
  4. Thanks clays123 thanked for this post
    Wilsonville, OR
    I had planned on using wheel offsets as opposed to traditional spacers with long lugs. The offsets are centered on the hub (supported by the hub) and bolt to the axle lugs, then bolt to the wheel with lugs pressed into the spacer. Pretty common if off road application with huge tires. I purchased my kit in two stages so I still don't have the body (next week I hope). I will be able to tell then if I need to space the wheels out. I don't know the backspace or offset. These are factory five wheels and I don't see any of those details in my documentation.
    May 2013
    Peachtree City
    Quote Originally Posted by rcotner View Post
    That sounds better than what I was thinking. To give you an idea where the body will be there are two small body mounting tabs welded to your frame right above the rear axle. The wheelwell will end about 3/8 inches or so from those tabs.
    Wilsonville, OR
    I went ahead and purchased 1.5" offsets. I believe the clearance will be very tight without them and to be honest I am OK with a wider wheel base and I am ok with showing a bit more tire. Thanks for the advice!
    Summit sells some made that use the existing lug nuts and studs and have an additional set built into them so you don't need to mess with longer lug studs. I believe Eibach and Cal Customs.
    Wilsonville, OR
    New spacers installed. Thanks for the input!
  10. #9
    Please Ray, what is your total axle width now (bolt up face to bolt up face)?
  11. #10
    Mar 2013
    Long Island NY
    I used one inch adapters from here:
    http://www.ezaccessory.com/
    I had the 59.25" width rear so now its 61.25"
    My rear rims are 18x11 with +23 offset (6.9" backspace)
    Great site for conversions:
    http://www.rimsntires.com/specspro.jsp
    I have 1.5" of clearance to the body from the rim to the body.
  12. #11
    Wilsonville, OR
    MT-ED, my face to face width is 62.25".
