Results 1 to 40 of 64
Thread: ISC Suspension-NA 5X100 to 5X114.3 Wheel Adapter, Fit STi Wheels on your 818!
    Sep 2011
    Wareham + Bow
    Hello everyone! We here at AJW Performance have been selling ISC Suspension-NA coilovers and other accessories for many years now. They are good quality brand and have never let us down. Recently ISC has introduced their new Wheel Adapters, an item that has been very important to members of the Subaru community! These wheel adapters allow you to use STi Wheels on your WRX or in your case, your 818 or 818R! These are offered in 15mm or 25mm. Please see below for the official Description from ISC.
    Finally, A name brand Subaru wheel adapter that works well and is affordable! No sense in paying 450.00 for competitors adapters any longer. This set ( 4) of bolt pattern adapters will allow you to bolt STI fitment wheels (5x114) to your WRX (Legacy, Forester, BRZ or any 5x100 Subaru)! Unlike most bolt pattern adapters, these are available in 15mm AND 25mm(SKU 16).
    The ISC Subaru wheel adapters fit all 5x100 Subarus. Precision-CNC-machined billet aluminum bolt pattern adapters, and twenty special low-profile lug nuts. The adapters are hub-centric for both the car and wheels. Offered in both a anodized ISC gold, or a stealth black finish. ISC Logo is engraved on spacer as well.
    Materials Used:
    Adapter: CNC 7075 light weight high grade aluminum
    Included Hardware: M12*1.25, Grade 10.9
    *** Please Note*** 15mm adapters are so thin, the factory studs will most likely stick out beyond the spacer. That means the 5x114 wheels you are bolting on MUST have pockets in back for the studs to poke into or modifications will need to be made to the studs. Make sure to check your wheels for clearance before you order these. Most STI wheels DO have pockets on the back side, so it is usually fine. You can also modify a wheel to have pockets, do some research on this and see if it right for you.
    Please PM us for FFR intro pricing! For fastest response please e-mail us at [email protected] or call us at 603-715-9076!
    Sep 2011
    Wareham + Bow
    Wheel Adapters in stock and ready to go out the door!
    Sep 2011
    Wareham + Bow
    Wheel Adapters are in stock and ready to go!
    Senior Member TahoeTim's Avatar
    Mar 2014
    Lake Tahoe
    Can you enlighten us Chevy/Ford guys on the benefits? It's a steep learning curve for me on all the Subaru tricks. Are the STI wheels cheaper? more options? what is the benefit?
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    More wheel options - especially race wheels.
    Quote Originally Posted by TahoeTim View Post
    mostly for additional wheel fitments... lots of the wider wheels are not available in 5x100 but do exist in 5x114
    another benefit would be doing an STI knuckle swap (with 5x114 hubs/bearings) on the front and running a pair of these on the rear (rather than messing with sti rear knuckles/cvs/axles) so you can run matched wheels all the way around.
    Sep 2011
    Wareham + Bow
    These are great for running other types of wheels that aren't available for the WRX. Many wheels come in 5X114.3 which is much more common.
    Sep 2011
    Wareham + Bow
    Sep 2011
    Wareham + Bow
    Wheel Adapters are in!
    Sep 2011
    Wareham + Bow
    Wheel Adapters are in stock! Ready to ship same day!
    Sep 2011
    Wareham + Bow
    Sep 2011
    Wareham + Bow
    Lots of wheel Adapters in stock! We're ready to go and ship them out!
    Sep 2011
    Wareham + Bow
    Good Morning folks, wheel adapters are in stock and ready to ship!
    Sep 2011
    Wareham + Bow
    Bump!!!
    Sep 2011
    Wareham + Bow
    We've got lots of parts in stock and ready to ship out!
    Sep 2011
    Wareham + Bow
    Tons of wheel adapters are in stock!
    these are very nice, do they make a std spacer as well? ie 5x100 to 5x100?
    Sep 2011
    Wareham + Bow
    They do not, however we can knock the studs out of those and you would have hub centric spacer but you'd have a lot of free space.
    Sep 2011
    Wareham + Bow
    Wheel Adapters are in stock and ready to go! Let us know what you need!
    Sep 2011
    Wareham + Bow
    Wheel Adapters are in stock and ready to be shipped! Let us know what you need!
    Sep 2011
    Wareham + Bow
    Hello folks! Wheel Adapters in stock!
    Sep 2011
    Wareham + Bow
    Good Morning everyone wheel adapters are in stock and ready to go!
    Sep 2011
    Wareham + Bow
    Wheel Adapters in all sizes in stock!
    Sep 2011
    Wareham + Bow
    Every style of wheel adapter is in stock today!
    Sep 2011
    Wareham + Bow
    Lots of wheel adapters are in stock and ready to go!
    Sep 2011
    Wareham + Bow
    Wheel adapters in stock and ready to ship!
    Sep 2011
    Wareham + Bow
    Lots of wheel adapters in stock!
    Dec 2013
    Whats the advantage of getting the 15mm ones?
    Sep 2011
    Wareham + Bow
    Quote Originally Posted by [email protected] View Post
    The ability to fit 5X114.3 wheels without adding to much width. If someone has a +48 offset wheel and only wants to run a bit less then these are a better suggestion and option than the 25mm which may be to much.
    Sep 2011
    Wareham + Bow
    Lots of adapters are in stock!
    Do the adapters affect the rotors in any way or do the spacers go on afterwards?
    Sep 2011
    Wareham + Bow
    Quote Originally Posted by coloskydiver View Post
    Negative, running adapters/spacers can affect the hubs a little but so will putting any aftermarket wheel on your car.
    Sep 2011
    Wareham + Bow
    Let me rephrase the question. I have aftermarket breaks/rotors for a 5X100. If I go with spacers, do I need to change the rotors since they are built for a 5X100?
    Sep 2011
    Wareham + Bow
    No, nothing has changed if I am understanding your question correctly. You are 5X100... the adapters can get you to change from 5X100 to 5X114.3 or ISC makes SPACERS now for people to keep 5X100 OR 5X114.3. Does this answer the question? Sorry for the misunderstanding.
    Sep 2011
    Wareham + Bow
    Sep 2011
    Wareham + Bow
    Sep 2011
    Wareham + Bow
    Wheel Adapters are in stock and ready to go!!!
    Sep 2011
    Wareham + Bow
    Wheel adapters are now on sale for the rest of the month. If you were on the fence before, now is a good time to buy!
    Sep 2011
    Wareham + Bow
