This is strange that they still want an AOS.
The dry sump tank is essentially a large AOS. The swirling air in the top of the dry sump tank separates the oil and air. The oil going to the bottom of the tank and the air going out the top of the tank to the valve cover ports. If there is extra air caused by blow-by, this goes to the small breather tank.
I am not running a vacuum regulator on my system. I deleted my PCV System.
I have no connection from crank case fumes to the intake track, so no oil/sludge can get to the intake track.
