my clutch master cylinder came from a 2002 impreza TSwagon
did anyone else have this problem? What was your solution?
Is there more than 1 type of clutch master cylinder by subaru that would work?
Why doesnt it fit?
I don't believe any of the non-turbo ones fit, my 07 didn't, and another member with an earlier model had the same issue. You can use the res from a wrx.
818 SRX - #91
Arrived 01/02/2014
First Start 10/31/2016
First Drive 05/22/2017
Registered 10/25/2019 BRAP818
Gotta use a 02-07 wrx one
Or, since the windshield surround is pretty close making access tight for refilling, the remote reservoir mount kit that Michael Everson's put together might be worth considering. That's the route I went down.
Rich
