This afternoon I started cleaning up my column, removed excess bracketry, the steering lock, etc etc, I was getting ready to test the fit so I could press the column to shorten it an inch or so when I noticed it would not fit through the hole enough for the bolt holes to line up. I started looking at pictures and I haven't seen another with the rib on the end like mine has. I was told it was an 02 column.
Does any one else have this column? how did you address the problem?
Thanks!
