We have had great weather for driving around!
First thing I did this weekend is open up the transmission to see if I couldn't get 5th gear sorted out. A mechanic friend said it is usually synchro (in which case I'll be getting another transmission) or the nut at the end of the gear train. Since that was work I did converting to 2wd, I'm hoping that was it. So I opened everything up, torqued it to 120 Nm and re-bent the end to secure it. It was about an 8th of a turn further than when I did it the first time, so I did have it loose.
The project went quicker than I expected and everything is now back together, but I need to add oil. I didn't have any oil to refill the transmission, so I'll run and get that in the morning and give the car a nice run and see how 5th gear works.
