Results 1 to 8 of 8
Thread: High beam light connector
    Kirkland, WA
    Did anyone receive a set of high beam connectors in their package, I see the low beam but not high beam
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Norton, MA USA earth
    I had to buy them.
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    The high beam come from your donor, if you used a 2002-2003 donor, you have to buy them.
    Not compatible?
    We have to buy connectors from a 06 Camry Head light socket (DORMAN 85812)?
    I went to a local bone yard and got connectors and bulbs for 5 bucks.
    Jun 2012
    Did anyone have an issue with their high beam bulb fitting poorly? I can insert it and twist and it will not pull out directly but it is loose and does not fit in like the low beams did, tight. I know there is an o-ring on the bulb, but is there a larger o-ring that is in the light housing or something that I might be missing?
    Jun 2012
    If someone could look at the Headlight where the bulb goes in, is there an o-ring, mine looks like there should be one that sits in the chromed plastic.LBHeadLight.JPG
    Jun 2012
    I finally got back in town, and tightened the screws on the lock ring and it holds much better.
