Flatirons Tuning Engine and Transmission parts for your 818
We are a new vendor here, but we have all ready helped our a few people with their 818's, and maybe we have something for you too.
We have been specializing in Subaru performance for a long time now, and we have a huge amount of engine and transmission parts from pistons, cranks, blocks, bearings to gear sets, differentials, etc. I'll post a few things here, and if you don't see something that you need, let us know and we probably have it. We also have a ton of parts up on our web-site www.flatironstuning.com
Thanks for looking, and please feel free to ask us any questions you may have!
First up, Hybrid swaps. We have put together 3 different levels of kits if you want to put a 2.5 shortblock in your car with 2.0 heads.
Doing a budget EJ257 rebuild in your WRX? This is the kit for you. This kit assumes that anything that can be re-used from your 2.0L WRX setup is in good condition. It includes everything that is absolutely necessary to replace to get the EJ257 swap running in your WRX.
You may need to replace other parts due to wear, but this kit includes everything that is totally necessary.
It includes:
-- OEM Valve cover gaskets
-- OEM Intake manifold gaskets
-- OEM Water Pump gasket
-- OEM Oil pump seals and gasket
-- Either an OEM STi or Cosworth 1.5mm Head Gasket set
The next step up from the basic kit, the comprehensive kit includes all the gaskets required for you to do a complete resealing of your engine during a hybrid swap. It also includes the Cosworth 1.5mm Head Gaskets (Part # 20002145), designed to lower compression when using the 2.0L heads.
This kit does not include any hard parts, only gaskets, so like the Basic kit assumes that all mechanical parts are re-usable.
Subaru is not including Valve Cover Gaskets any longer in the 2002 MGK, and they have removed the Half-Moon seals from both kits as well. Because we feel these are important parts that you will need, we have now changed our prices to include them so you will not need to purchase them separately.
Save by buying everything for your EJ257 swap in one place!
This kit includes everything that we recommend to do an EJ257 hybrid swap the right way.
This ensures you have peace of mind, knowing all the vital components supporting your new block are also new, or upgraded. Also, all of these items need to be removed during the swap anyways, so it is a wise choice to do them now while the engine is out of the car, as opposed to wrestling with it down the line when you need to replace the old water pump you re-used.
The OEM kit includes:
-- All gaskets to reseal the entire engine (Comprehensive Hybrid install kit)
-- Cosworth 1.5mm Hybrid swap head gaskets
-- New OEM Thermostat
-- New OEM Water Pump
-- New OEM Timing Belt Tensioner
-- Cosworth Kevlar Timing Belt
-- New OEM 11mm Oil pump with new bolts from the 2009 STi or OEM Subaru 10mm pump with new bolts
The Gates Kit includes:
-- Gates Racing Belt Timing Kit, which includes new tensioner, all idler bearings, water pump, and Gates Kevlar Racing Belt
We can also put together a custom kit with the exact parts you want. It is no problem for us to switch the 11mm Oil Pump for a Cosworth Blueprinted Pump, ditch the Cosworth head gaskets for the OEM ones, or add on a set of ARP head studs, timing belt idler pulleys, or Group-N Engine Mounts. We have anything you need right here.
If you are looking to re-build your engine, we have a Rotating Assembly Kit with just about every option that you could need
Searching for the right parts to build your EJ257 block? Look no further. Flatirons Tuning has now assembled our most popular forged internal setups into ready-to-build kits.
These do not come assembled. We can arrange to have the kit assembled before shipment for additional charge, however, this kit is designed for the customer who is planning to have the block assembled themselves.
This rotating assembly includes everything you will need to build your existing EJ257 block or a pair of our blank case halves. Save money and time by buying all the parts together from one place!
The kit includes:
- OEM Heat-Treated EJ257 Crankshaft
- ACL STD Race Bearings
- Eagle Rods
- Your choice of either CP or Wiseco pistons, with Rings
If you are having your block machined and need an oversize piston, or if you want Cosworth bearings in a size other than the standard Size 1, just send us a PM to discuss your options.
Please note the new lay-out below. The basic Rotating assembly will be as listed above. If you want to up-grade any items, just add them to your cart after you have selected the base rotating assembly.
Material
- Wax SS304 Stainless
(Bend in shape from one pipe / No welding)
Kinugawa Part # 323-02049-003
This header is Ceramic Coated with a special Satin ceramic Coating.
Satin Ceramic Exhaust Coatings are the most advanced exhaust system coatings available. They are a very durable ceramic-reinforced coating available. When properly applied, it becomes the most effective thermal barrier coating available, increasing performance while extending component life, and has been tested to over 2000° F without lifting, cracking or flaking.
This header is Ceramic Coated with a special Satin Ceramic Coating.
We have had a number of requests for a precision balanced crank, and we are proud to announce that we now have one. We are working with ASF machine, and having them balance the stock heat treated cranks for us, and they are now available.
The crank's are usually balanced to within .3 - .5 grams.
They are on our shelf ready to ship, and at most would be about a week out. But we are working with ASF to make sure that these are readily available.
This is the Heat Treated crankshaft out of the 2010 Subaru WRX STi EJ257.
Heat Treating hardens the surface of the crank, which prevents scoring caused by a piece metal getting stuck between the bearing and the crank.
By increasing the hardness of the crankshaft surface, any material which gets caught between the new surfaces is simply ground down and filtered out through the oil, potentially preventing bearing failure.
This is a brand new part, straight from Subaru!
The Subaru Part # for this Heat Treated Crank is 12200AA330, superseded from the 12200AA430 which was Nitride Treated.
This is the OEM Main Shaft, and 1st through 4th gear that came in the 5-Speed manual transmission in the 2005 – 2008 Legacy GT.
This set is available with either the Main Shaft and 1st and 2nd gear, or the Main Shaft and 1st through 4th gear. This gear set can be retrofitted into most Subaru 5-speed gear sets, but depending on the year of your transmission, you would need additional parts.
We now offer the 1-4 gear set with installation kits for the 2002 - 2007 WRX. Each kit is slightly different, but they all include all the parts that are required for installation. There may be other parts that need to be replaced due to wear, such as bearings and synchros. If you need any other parts, let us know.
All of the install kits include a new speedometer gear, but WRX's with a 3.7 final drive will have a slight speedometer discrepancy.
Professional installation is very strongly recommended. If this gear set goes into any car other than it was originally designed for by Subaru, there is no warranty for strength expressed or implied.
Also, because of the number of issues that can arise due to improper installation, this gear set is not returnable once any of the parts are installed, and we will not warranty any damage to the gear set or any other parts that is the result of improper installation.
For more information about the Legacy GT Gear set, and other Subaru Gear Sets, please click here.
Assembled by RalliSpec, the close ratio gears from the STi RA feature strengthened and hardened components for improved reliability of the 5MT in modified Imprezas. The gearsets have REM-treated 1st-4th gears for even further improvements in reliability at high power levels. Each gearset includes all necessary gears for installation including a custom speedometer gear (3.9 final drive ratio only).
Please call for availability.
Now REM Treated for increased strength.
Professional installation is recommended.
JDM STI
1st-3.166
2nd-1.882
3rd-1.296
4th-0.972
5th-0.738
This kit contains the following:
STI RA Main Shaft
STI RA 1st Driven Gear
STI RA 2nd Driven Gear
STI RA 3rd Drive Gear
STI RA 4th Drive Gear
STI RA 3rd/4th Driven Gear Cluster
STI RA 5th Drive Gear
STI RA 5th Driven Gear
1st Gear Synchro (baulk ring)
Lock Nut, Main Shaft
Lock Nut, Pinion Shaft
Lock Nut, Driven Shaft
Oil Seal, Main Shaft
Custom Steel Speedometer Gear
(Calibrated for 3.9 Final Drive)
Case Gasket
You must select the correct Installation kit for the year of your car. If you are not sure what year your gear set it, you need the 02 WRX Install kit.
If you do not have Flatirons Tuning build your transmission for you, we do not offer any warranty on the parts due to the number of issues that can result from improper installation.
Assembled by Rallispec, the STi standard ratio gears feature a 5th gear that is identical to the stock WRX for those wishing to maintain the same highway performance. However, these gears provide improved reliability of the 5MT through similar hardening and strengthening features as found on the STi RA set listed above.
Now R.E.M. treated for increased strength.
This Kit Includes:
- Main Shaft
- 1st Gear Driven
- 2nd Gear Driven
- 3rd/4th Gear Set
- 5th Gear Set
- Main Shaft Lock Nut
- Output Shaft Lock Nut
- Pinion Shaft Lock Nut
- Transfer Case Gasket
- Front Main Shaft Oil Seal
- Custom Steel 3.9 Speedometer Gear
- Installation Kit for Correct year Car
Professional installation is strongly recommended, and you MUST order the correct installation kit for your car. If you are not sure what year transmission you have, you need to order the 02 Installation kit.
JDM STI
1st-3.166
2nd-1.882
3rd-1.296
4th-0.972
5th-0.738
Modena is one of Australia's premier manufacturers of Motorsport Gears and Differentials.
This is Modena's Torsen Style Torque Biasing Front Differential for the 2002 - 2007 WRX. This replaces the factory open differential, and will behave much like the factory LSD that is in the rear differential, or like the front LSD that comes in the STI from the factory.
Modena's Torque Biasing Differential will provide improved traction under acceleration, but will open, or "Unlock" under deceleration as soon as you lift your foot off the accelerator. This is ideal for a car that is driven on the street, or at the track or Auto-X course because it will give you improved traction through the corner, and will help reduce understeer.
The reason that this differential is not called a "Limited Slip Differential" is because it doesn't "lock-up" when the wheels begin to slip, which means that both wheels are receiving the same amount of torque and turning at or near the same speed.
Instead, The Modena Torque Biasing Differential will transfer torque between the left and right wheel in order to make sure that 100% of the torque that is sent to the front axle is distributed between the two wheels. In other words, if one wheel is receiving 60% of the torque, this differential will make sure that the other 40% is sent to the other wheel.
This results in improved traction for a better exit from the corner, without inducing any understeer, which a "Locked" Limited Slip Differential has a tendency to do.
Professional installation is strongly recommended, and this diff comes with stub-axles all ready installed, for ease of installation.
This Modena Torque Biasing Differential is In Stock and Ready To Ship!
If you are looking for a clutch, you have come to the right place. We stock a number of Exedy Clutches, including their OEM replacement kits, and ACT and Clutch Masters clutches as well. We also stock the OEM flywheels and Exedy Light Weight Flywheels too!
Exedy is the manufacturer of the OEM (original equipment) clutch that comes in the Subaru WRX. If the time has come to replace your clutch, buying this kit directly from the manufacturer is a great way to get a great clutch at a great value. This kit is identical to the clutch that you would get from a Subaru Dealership, but it is less than half the price.
This Kit includes:
Exedy Pressure Plate
Exedy Clutch Disk
New Pilot Bearing and Throw-Out Bearing
Flywheel not included.
The 06+ clutch will also work for the Legacy GT models if you use the 06+ WRX flywheel
If you aren't sure which kit you need, remember that the transmission determines the clutch. So if you are using the transmission out of a 2006+ WRX, you need the clutch for a 2006+ WRX.
This is a brand new OEM Subaru Flywheel for the WRX, STi, or Legacy GT
These pieces are brand new straight from Subaru!
Please ensure you choose the correct flywheel for your application. If you are not sure which flywheel you need, give us a call or email us with the last 8 digits of your donor car's VIN number and we can make sure you are ordering the right piece.
EXEDY STAGE 1 HEAVY DUTY ORGANIC CLUTCH FOR THE 2002-2005 SUBARU WRX
This is a brand new Exedy Stage 1 Organic Heavy Duty Clutch for the 02-05 Subaru Impreza WRX 2.0L.
This clutch is the Heavy Duty variant, which increases the torque capabilities to 319 ftlbs wheel torque, over the standard Stage 1 Organic Clutch's 278 ftlbs wtq.
This will also fit the following models:
-- 04-05 Baja Turbo
-- 04-05 Forester XT
EXEDY organic racing clutches only use premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines. This is the preferred clutch for street and light horsepower track use. Driveability is similar to the stock clutch. Pedal efforts will be slightly higher because of the higher clamp loads. All of Exedy's clutch discs have spring center dampers to reduce drivetrain shock.
Perfect as a replacement clutch if you have modified your vehicle's power output.
Exedy Racing clutches with organic friction materials use only premium friction materials that are resistant to slippage and burst. Increasing clamp loads give the necessary capacity to handle modified engines. The preferred clutch for street and light horse power track use.
The drivability will be like a stock clutch. Pedal efforts will be higher because of the higher clamp loads. All Exedy clutch discs have high capacity spring center dampers to reduce the drive train shock and impact.
EXEDY LIGHTWEIGHT FLYWHEEL FOR THE 2002-2005 SUBARU WRX
Exedy Racing Flywheels are made from solid one-piece billet chromoly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel, and have the possibilities of separating from the flywheel.
The steel insert on alloy flywheels also has the possibility of warping which could alter the set clamp load of the clutch cover and effect disengagement. This could cause the flywheel to explode due to two different expansion coefficients (aluminum flywheel pressed on steel ring gear). Exedy steel billet and forged steel flywheels have passed engineering tests to 15,000 rpm. They are guaranteed to be explosion proof at that rpm.
Engine Code: EJ20T
Weight: 12.7 Lb.
Exedy Part # FF01T
Exedy Racing Flywheels are made from solid one-piece billet chrome moly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel, and have the possibilities of separating from the flywheel.
CUSCO HEAVY DUTY MOTOR AND TRANSMISSION MOUNT KIT FOR WRX, STI, AND GC8
Specially designed by Cusco for each application, these mounts are completely new. These are not cheap mount inserts; these are completely custom designed, complete mounts for the WRX. Perfect for those customers looking to drastically reduce engine movement.
These differ from the OEM and Group-N Mounts in that there are two metal plates, which are connected during installation with bolts through the stiffer rubber compound bushing.
This kit includes both lower engine mounts and the 5-speed transmission mount, and is sold as a kit only.
STi 6-speed customers will not be able to use the 5-speed transmission mount portion of the kit.
STI HARDENED GROUP-N ENGINE AND TRANSMISSION MOUNTS
These Engine and Transmission mounts are made by Subaru Technica International to replace the stock parts. They are made using stiffer rubber and plastic to reduce movement of the engine and transmission under hard acceleration and braking. These are strongly recommended for highly modified engines.
Each part is available separately, or you can save with our Group-N Engine Mount Kit which includes all three Engine Mounts, or our Complete Group-N Kit which includes the Transmission Mount as well.
Transmission Mounts are now available for both the 5 Speed and 6 Speed Transmissions!
Professional installation is strongly recommended.
Please note that the 2008 - 2012 WRX require 2 additional nuts per side to install the Group-N Lower Engine Mounts (total of 4). Part # 902380007
All Group N Engine Mount Kits now include free shipping!
Japan has different emission standards than we do here in the states, and so most of the STI’s come without Tumbler valves from the factory.
These are the JDM STI TGV’s for both top-feed injectors, and side-feed injectors. They will fit all USDM Turbo EJ Series Engines from 2002 – 2006 without modification. They can be installed on 2007+ USDM Turbo EJ Series Engines by slightly modifying the center bolt holes.
Also, please note that removing the TGV’s will require a tune on all cars, and may interfere with your car’s ability to start when it is very cold.
Cusco 1.5 Way Front Limited Slip Differential for the Subaru 5MT
Three ways to set your CUSCO limited slip differentials: 1 way, 1.5 way and 2 way.
1 way LSD: Specially suited for front wheel drive cars and AWD front axle cars. Activates under acceleration, and acts as a true LSD when the throttle is off. This CUSCO 1 way LSD will improve lap times without a doubt.
1.5 way LSD: Activates under acceleration while the under-steer under deceleration is less than on a 2 way LSD. Recommended for those who have a hard time with under-steer.
Two way LSD: Recommended on rear wheel drive cars and AWD rear axle cars. Activates on both acceleration and deceleration. Recommended for those who prefer aggressive driving and big angle drifting.
The Low Initial TYPE RS
Low power loss means better lap times for even the mild tuned of cars
Chattering is kept low
Improved durability as clutch plates are low pressured
The LSD efficiency is higher with smoother oil flow between plates.
The Benfits
According to CUSCO'S in house research, initial torque is 50 to 70% lower compared to the conventional cone plate type LSD enabling lower drive friction and better response.
The Type RS's Durability
Special precision springs, set in the pressure plate, assure steady coil movement
Clutch plates do not stick together like convetional cone plate type LSDs. Therefore less clutch plate wear or deterioration occurs.
The Benefits
The Type RS LSD had proved to be capable of competition use in the All Japan Gymkhana Championship without overhauling a single time during the season. With all drivers and teams finishing with good or championship reuslts at the end of the season.
Uncompromising Characteristics of the Type RS LSD:
Reacts to throttle work directly
Transfers high power without slippage
No clutch slipping in 0-400 meter accelerations (1/4 mile competition)
Transfer steady power in long drifts
Maintaining Stability And Performance
Cusco oil through system enables stability in high performance LSDs.
CUSCO's unique Oil Through System enables better oil flow inside the LSD for better efficiency. The casing made from CUSCO's unique technology allows the oil to flow from the wide end, to the pressure rings, then to the MZ clutch plates for efficeint lubrication. Making the LSD more stalbe and durable!
This was only possible with CUSCO's unique technology in manufacturing chromoly steel casing and gears that enabled a higher level of durability and a better flow of oil due to the large oil openings.
All Differentials come set at 100% lock-Up. They can be set up at either 60% or 80% lock-up for an additional charge.
This is a brand new Subaru Ring and Pinion Gear Set for the 2002 – 2014 Subaru 5MT transmission.
Through the years, Subaru has made 4 different ratios for this front ring and pinion gear, and depending on your application, it may be advantageous to swap out the stock ring and pinion for one of these other options.
Keep in mind that if you are using the transmission in an All Wheel Drive application, you will need to consider the transfer gear ratios, and rear differential ratios when changing the front differential ratio, otherwise serious drivetrain damage could result.
The available options are:
4.44:1
4.11:1
3.9:1
3.7:1
If you are not sure what would be best for your application, or of what other parts you may need to make this work, please contact us before placing your order.
We now have Company 23 Tools in Stock! They offer a wide variety of Subaru specialty tools that will make it much easier for you to work on your engine, change your timing belt, etc.
Here is a link to their full line of tools that we stock:
Remove both the intake and exhaust cam sprockets without damaging the cam or the sprocket
Perfect tool for cam seal renewal, cylinder head removal, or motor tear downs
3-piece welded construction handles the torque
High precision laser cut construction fits perfect
Long integrated handle makes it easy for one person
Comparable to factory tools #499207400 and #499207400-A
Locks the LH side cam sprockets from turning when the timing belt is removed
Prevents cam sprockets from spinning when belt is removed and eliminates potential valve damage
Saves time! Makes timing belt changes faster and easier especially when done with one person
Strong neodymium magnets ensure the tool stays in place even if bumped
Curved plate allows easy viewing of sprocket timing marks
Works with:
02+ Subaru Impreza WRX and WRX STI with 2.0L or 2.5L DOHC Turbo engines (EJ205, EJ207, EJ255, EJ257)
04-11 Subaru Forester XT with DOHC Turbo engines
05-10 Subaru Legacy GT with DOHC Turbo engines
05-10 Subaru Outback XT with DOHC Turbo engines
05-06 Saab 9-2X Aero with DOHC Turbo engines
04-06 Subaru Baja with DOHC Turbo engines
Unique profile specifically designed for Subaru fuel quick couplers.
Will not damage fuel line seals like universal fuel line tools.
Will not damage fuel lines like aluminum disconnect tools.
Molded from high strength polymer.
One-piece construction makes fast work of fuel disconnection.
Works on all couplers inside applicable engine bays.
Used in place of factory tool #42099AE000 and 18371AA000
Works with:
05+ Subaru Impreza
05+ Subaru Forester
05+ Subaru Legacy and Outback
06 Subaru Baja
05+ Subaru Tribeca
12+ Subaru BRZ
05-06 Saab 9-2X
12+ Toyota GT86
12+ Scion FR-S
Crankshaft rotating socket slips on over the crank snout
Enables an engine builder to rotate a complete engine with any ½” ratchet or breaker bar
Designed to allow easy location of TDC when replacing timing belts or other engine work
Low profile height makes access easy
Eliminates risk of crankshaft snout damage or backwards engine rotation
CNC machined steel designed for a lifetime of use
Comparable to factory tool #499987500
WARNING: Never use an impact wrench with the crank socket to rotate the engine.
Works with:
93-11 Subaru Imprezas
98-09 Subaru Foresters
94-09 Subaru Legacys
04-06 Subaru Baja
91-96 Subaru SVX
12+ Subaru BRZ
05-06 Saab 9-2X
12+ Toyota GT86
12+ Scion FR-S
