The FFR kit came with some hose couplers which can fit inside each other to handle multiple sizes.
This works fine when the hose needs to be fitted over a metal connector, like the radiator inflow and outflow - by tightening the clamp, it appears to make a good seal.
My water pump inflow is facing straight up and I need to make it turn 90 degrees to run the hose to the radiator.
The stainless hose provided by FFR doesn't make a tight enough angle and I think it will interfere with the hood of the car.
I found a 90 degree rubber hose that fits the water pump, but is too small for the inline filler neck (1.5"). I'd like to use one of the couplers provided by FFR, but on one side I'll have rubber to rubber with nothing solid underneath. See photo.
Is there some way to bond the interior and exterior hoses together?
