Results 1 to 40 of 43
Thread: How to adjust Koni single adjustable shocks
    I went on Koni's site to read about how to adjust the rebound of their shocks.
    http://www.koni-na.com/adjustment.cfm
    I believe our shocks are Series 82?
    Then we have to remove the big nut (21mm I think) to get the bump stop out?
    And we don't care about these 2 holes at the bottom of the rod, right?
    Then I start to get confused. We push it down to the max and turn it counterclockwise until we feel it goes into the adjustment cam.
    Then, we continue to turn it counterclockwise until it reaches its max and then we turn it back half a turn.
    Then what? Is that the softest setting?
    Senior Member AZPete's Avatar
    Yes, once you follow the instructions turning to the left (counter clockwise) the shock is at the softest setting. Then turn to the right to increase firmness. This adjusts only the rebound, not the compression. Rebound is when the shock extends, i.e., recovers from compression (a bump).
    From Koni-na.com
    Rebound Adjustment Procedures
    Remove the shock absorber from the vehicle and hold it vertically with the lower eye or pin attached in a vise. Use clamp plates to prevent damage.
    Fully collapse the shock absorber, at the same time turning the dust cap or piston rod slowly to the left (counterclockwise), until it is felt that the cams of the adjustment nut engage in the recesses of the foot valve assembly.
    Some shock absorbers include a bump rubber concealed under the dust cover and it must be removed prior to adjusting.
    The damper may have already been adjusted. Therefore check whether the shock absorber is in the adjustment position or not by keeping it collapsed and gently turning it further to the left counting at the same time the half turns until a stop is felt. Stop turning then and do not use force.
    Keeping the shock absorber collapsed, make 1 half turn (180 degrees) to the right (clockwise). In case of prior adjustment add the number of half the turns previously found. The total range is about 5 half turns.
    Pull the shock absorber out vertically without turning for at least 1 cm to disengage the adjusting mechanism. The dust cap or piston rod may now be turned freely.
    ADJUSTING DIRECTION
    Clockwise = Firmer
    Counter Clockwise = Softer
    That's what I understood.
    The part I don't, is this one
    Why do that? Wouldn't that stiffen the shock?
    In my case I am looking for the softest setting, therefore where is the softest setting, fully counterclock or half a turn before full counterclock?
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    Frank, you don't want the valve completely closed (because then you don't have a shock, right?!? you have a rod!), and this probably ensures the valve is minimally open, which would be the softest setting that still allows the shock to function correctly.
    Have you seen the 818 Registry on Google Maps?? https://www.google.com/maps/ms?msid=...a=0&dg=feature
    Want your 818 added to the Registry? https://docs.google.com/forms/d/1zmF...rNCY4/viewform
    you have a rod!
    How am I supposed to read that?
    Brian, I think I understand now. It doesn't work the same as shocks with pre-defined adjustments. For example my Bilsteins have 6 or 9 adjustments, with an external knob, with numbers on each adjustment and it clicks as well. There is no "in between" adjustment, if #1 is the softest, you put it there, nothing before 1 and after 1 it's #2 and it's the next click.
    Looks like the 818 shocks you adjust the valve directly so if you go too far you can shut it off, sort of?
    Half a turn clockwise. Why not 1/4, maybe it'll be softer and still work well. That's what I did on my KTM. Its rear suspension is really stiff, they recommend a certain amount of preload on the spring, but I realized if I preload it less, it's much softer and in my case, helps on the handling and comfort. Just a bit less! Not too much. So maybe it could be the same here. Just guessing!! I bet I'll be the first one to try.
    I can confirm though that the 818S shocks should have 4 settings, including the one it's currently set on. And yes, the bump stop needs to be removed.
    Eugene, OR, USA
    I just realized I was thinking turning the opposite direction - going to full stiff. So disregard what I said previously.
    I hear what you are saying, and I'm not sure. Still, I'd do what they recommend!
    I'll go a step further, I'll contact Koni and ask them. I know that may sound silly or picky, but there must be a valid reason for that half a turn back and I am very curious to understand. If I get an answer, I'll post!
    Senior Member metros's Avatar
    NoVA
    Anybody have input on how to change the settings on the double adjustable R coilovers?
    How does that red one look like and what is its Series #?
    Race application or still Street?
    Ok so Koni said that the 1 half turn or 180* is to find the adjustment indentation/mode, not to back off from being too far. Once you have the shock collapsed and in the adjustment indentation you can turn the shock in either direction, fully until it stops.
    Where was the shock ajusted to from the factory?
    I've heard from others here it's supposed to be adjusted to the softest setting. But I don't want to take the chance and assume all 4 are correctly setup the way I wish. I don't want to discover while driving that one of them, maybe only one out of 100, was at the stiffest setting and remove everything to check all 4 then.
    I wanna know exactly what I'm installing on the car and how. That's the beauty of a kit car.
    Quote Originally Posted by metros View Post
    Metros, if no one is able to help here in the short term, I suggest you fill in the contact form on koni-na. They responded to me within 12hours, which is just... amazing. Make sure you provide the shock Series and tell them it's for the 818R red shocks double adjustables.
    Clovis, Ca
    FYI- Regular 818R red shocks are not double adjustable. The only double adjustable shocks are the pricey upgrade ones.
    Thanks- Chad
    Oh so there are 3 types of shocks offered by FFR. Ok I get it.
    Well Metros as long as you detail what you got, they should answer you straight forward.
    Ok I did the adjustment on the single adjustable yellow shocks.
    Tip #1: use a vise, really, otherwise good luck.
    Tip #2: once you remove the nut on the top, remove the bump stop then put back the nut and the top metal cover and SCREW the nut a little bit. This will prevent you from unscrewing the metal cover once you adjust stiffness, cuz you turn that part clock wise or counterclock wise, so it can unscrew and lose all turning force.
    You will see the rod go down slightly once it gets in the adjustment holes.
    Tip #3: then I suggest you turn all over to one side. Move the rod just a bit on the other side to get it out of the holes and pull it, damn it! lolll Feel how hard it is. I say "how hard" and not "how hard or how smooth", cuz it's not that easy even at the softest setting. Soft is hard, stiff is harder. Then go again in the adjustment holes and turn all the damn way on the other side. Pull!!! Feel!!! lolll Then do the adjustment on either side you want.
    Tip #4: I found out it was easier to have the shocks installed sideways on a vise and pushing via the yellow part. You have much better grip and feeling of what's going on than having the shocks straight up on the vise and collapsing the rod. Besides if you follow tip #3, you don't need to check which side you turn, cuz after trying the 2 opposite settings, you just then turn on the side you prefer.
    I put mine all the way on the softest setting.
    shock bump stop question
    I know the Koni's have a bump stop that is used under compression.
    But what about extension. Is there an internal bump stop?
    This video may not tell everything, but maybe it helps.
    https://www.youtube.com/watch?v=ONl44FPP6lM
    It seems there is no internal bump stop. There is also minimal weight under extension, I mean a lot less stress than under compression with the weight of the car. Planning on some rallying, Bob?
  19. Thanks bittenbycobras thanked for this post
  20. #19
    No rallying for the 818, But I do get wheels in the air Autocrossing. IMG_2404_zps186ab162s.jpg
    Very glad to have heads up on this.. With our Miata's Koni Yellows, we're able to quickly adjust damping at the track, then back for street use. There's a small flat on the top of the damper that you twist using an included knob.
    This adjustment method makes it look like there's no chance at all of that, and to do it even at home is equal to replacing the shocks completely, as far as work is concerned?
    Our order currently includes the R springs & dampers, but not the $$ double adjustable.
    Does anyone know an alternate model that would allow for the adjustment to be done real-time, car-on-ground?
    How is FFR making adjustments to their Rs for track use?
  22. #21
    Here is a picture of the red/white 818r during assembly.
    They are using the red Koni's, I believe part# 30 1720
  23. #22
    If they are a 30 series, here's an interesting note:
    The 30 Series can be run inverted to reduce unsprung weight.
    Does it seem like there might be clearance on the chassis to allow this?
    I guess the good news, even if they have to be removed to adjust, is that they're only held in by 2 bolts. Won't be doing it while in the line for tech inspection, but it isn't awful.
    The 30 series adjustment procedure looks a little easier than the series 82.
  24. #23
    Wow on a subie, I never thought they were doing like old VWs. lolll
    That being said, maybe you won't with the 818.
  25. #24
    As you can see in this picture:
    The stock 07 NA impreza has a LOT of body roll. With clean concrete, and warm Toyo 225 R888, we were driving right at the limit. The left side tires are barely touching the ground. The 818 will have a CG a lot lower than this car, so I'm hoping for a lot less body roll.
    Back to my original question:
    Does the Koni's have a internal bump stop that is used during extension?
  26. #25
    Encinitas, CA
    Yup, did that all the time in my A2 GTI 16V... two wheels stickin, one wheel slidin, one wheel flyin!
    Vintage 911's would lift an inside front wheel, but I'd hope the 818's cg should keep all four planted!
  27. #26
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Would love to find out this answer as well. Given the weight of the 818, I'm guessing it might be a challenge finding something.
  28. #27
    Freeport, ME
    sure, the race shock option, approx $2000
    Dan
  29. #28
    Hindsight's Avatar
    Atlanta
    The race shock option is adjustable while installed?
  30. #29
    Freeport, ME
    yes, check the Koni site
    Dan
  31. #30
    The upgrade unit are 3012 series. They can be adjusted for rebound while the car is intact, using an allen key on the knob. May not be the easiest to get to, but ought to be better than removing the shock.
    Compression damping is done off-car.
    http://www.koniracing.com/images/Fil...ence_Sheet.pdf (for reference)
    So, none of the above are quite as easy as a Koni yellow on our miata..
  32. #31
    Hindsight's Avatar
    Atlanta
    Thanks for the info... good to know.
  33. #32
    I'm waiting on info re: stroke length, etc.. to see if maybe Koni or others offer a more readily adjustable design which matches in spec, once you work out the damping requirements.
    One that's double adjustable, without removal from car: http://www.koniracing.com/rr82.cfm
    Maybe we're over-emphasizing it, but I sure have appreciated the easy adjustment on the yellows.
  34. #33
    Shock Travel
    How much shock travel should we have when the car is adjusted to ride height.
    I believe there is 4" of total travel including the bumpstop rubber.
    How much of the should be in the bump direction and how much in the rebound direction?
  35. #34
    Ideally you would be in the middle of the range of adjustment such that you had a roughly equal amount of bump and droop travel.
    Tony
  36. #35
    Feb 2013
    Westminster, MD
    Definitely not. We were going to run our Reds on the R this way but the spring would be in constant contact with rear suspension. Works great in the front though, and gives some room if you have a silly huge front sway bar too.
  37. #36
    Well, that beats neither, I guess.
    Tony,
    Is 50% static sag something you use for roadcourse cars, or rally? (both?) My experience is with motorcycles, where you shoot for around 1/3 static sag.
  38. #37
    Motorcycles put a lot of static load on the suspension around corners because they lean. Cars mostly side load the tires.
  39. #38
    NoVA
    I wanted to come back and update this thread on the 818R shocks that many of us are using. These are the red shocks that are rebound adjustable, not the double adjustable $$ option.
    With these shocks you don't need to compress the piston in order to adjust them. Put the top side (not the body end) into a vice. Remove the black dust cap. Press the button and hold it. Turn the shock body counter clockwise for softer and clockwise for harder. There are 4 main clicks of adjustment that you'll feel while turning the shock body.
  40. #39
    Jan 2012
    Anyone know the part number for the red R shocks, looking to upgrade and trying to find them outside of contacting factory five and giving them more money this week.
  41. #40
    The part number for the RED is 30 1720
    I think Koni makes them special for FFR. You can only get that part number from FFR.
    Koni may have an equivalent shock in there catalog, but I couldn't find it.
    here is info on the 30 series. http://www.koniracing.com/oval30.cfm
