Results 1 to 25 of 25
Thread: Lets talk Fender Flares
    Edmonton, Alberta
    So I recently read somewhere on the forum that someone was planning fender flares to run wider tires. (I don't remember who, but I don't think they have their kit yet) I'm on the verge of ordering wheels and tires and now I can't get the image of carbon fiber fender flares out of my head. So I thought we (ie; anyone interested) could talk over the viability, and our options.
    1. Do we NEED wider tires?
    I'm not sure there's enough members cars finished to know the answer to this. Perhaps FFR or wayne could chime in on the initial test sessions and how easy it was to get heat in the tires. Any Top Gear fans will remember Richard Hammond driving the renault F1 car, not enough heat in the tires is sketchy on track. If its a problem, then more downforce, and probably more power to achieve said downforce, etc, etc. (thats a discussion for later) Obviously for street cars, or the drag strip, it would help with traction and probably look bad ***.
    2. Are flares going to help run wider tires in the front?
    Correct me if I'm wrong, but won't wider tires contact the frame/aluminum at the rear of the front fender well? Wider tires, or less offset might just make matters worse.
    3. Are there any flares that will work without modification to the flare?
    Obviously the quarters/fenders will have to be trimmed, but if we can find flares that fit the body lines as is, then finished quality carbon fiber is an option. Otherwise we can look at fiberglass flares, and hack away.
    Here's a side shot for reference...
    And here's the largest flare from jdmflares.com (no affiliation)
    IMO the 818's rear quarters are so flared as is, that large flares would be our best option to avoid the "flare on flare" look. I'm not sure universal flares are an option up front, but that may be moot if the above mentioned fitment issues are true.
    carbon creation also makes a set (no affiliation)
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Senior Member TahoeTim's Avatar
    Mar 2014
    Lake Tahoe
    (insert barf smiley)
    it's not a 72 bronco!
    Exeter R.I
    Ummm bad idea, sorry car looks butter as is, and you don't need more tire
    Edmonton, Alberta
    Nothing worse than negative comments...
    I seen a race prepped FR-S at a car show last weekend, it had bolt on flares and 295's and IMO looked really good. I don't like the big flares on a otherwise flat body, but on the 818 they would be near the top of a sloped quarter. Not sure it would look great, but I'm not ready to puke and call it a tahoe either.
    818 SRX - #91
    Arrived 01/02/2014
    Tallahassee, Florida
    I know that if you are racing you do what you have to do to be competitive but for the street cars those flares just take away from the beauty of it all. Just my opinion I know and to each their own.
    Puyallup, WA
    I am planning on purchasing the jdmflares.com flares for my kit once the body is on and exact dimensions are finalized. I have 10.5" rims with 295s on the rear and 8.5" rim with 255 for the front.
    Edmonton, Alberta
    What offset up front, and do they clear the frame up front?
    818 SRX - #91
    Arrived 01/02/2014
    Senior Member Turboguy's Avatar
    Canada
    Is this the look you're after ?
    Edmonton, Alberta
    Quote Originally Posted by Turboguy View Post
    No, that's the look I'm trying to avoid.
    818 SRX - #91
    Arrived 01/02/2014
    Senior Member D Clary's Avatar
    Santa Rosa CA
    I am not sure that with the diameter restrictions on the front that flare would be needed. You could offset the rears out but the front would still be limited to about 24 inches from what I have read. So you could end up with 9 inches in front and 12 in the rear, doesn't sound right.
    Exeter R.I
    Sorry did not mean to be negative, those cars do look killer, so it might be an option and have at it. The thing with more tire might create undesired handling characteristics, but with like 12" rims out back with 335's that would be interesting.
    Clovis, Ca
    You will have to make some serious mods to be able to turn those meats in the front.
    Thanks- Chad
    Edmonton, Alberta
    I'm not sure there's been any serious discussion on what mods would be needed. It's always just shot down as too difficult or impractible. I don't see that a front gas tank is worth the effort, or a side pod radiator, but I fully support their efforts and I love the idea of stepping of the beaten path and pursuing it.
    818 SRX - #91
    Arrived 01/02/2014
    Clovis, Ca
    My 235's rub- but its a racecar- I do not go full lock on the track. 255's on the front for a street car that does U turns. I really want to see the mods. We all can learn that way.
    Thanks- Chad
    Apr 2014
    Oh man, that is gross looking! The other cars looks pretty aggressive though.
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    In the rear, it seems like it's mostly just body work, assuming you plan your offset correctly. So how it looks is largely a matter of vision & execution. The front will be slightly more difficult because you increase width, you must also increase diameter at some point, and the tire will contact something when turning - even if you run an offset that puts the tire out farther.
    Puyallup, WA
    My front tires are 255/30/18 with a 35mm offset. So far the with the current setup and off set i have the following issues; tires contact the sway bar at the links and minor frame contact. Im hoping a majority of the issues can be taken care of with some spacers. The rears are a 20mm offset and do not have any issues with suspension contact or the trailing arm. Body modification will definitely be required. Ill keep posting as more progress is done.
    Chicago, IL
    Keep us updated Kurk! And drop the sway bar - easy fix and you don't need it.
    I'm planning on flaring the fenders, but not with a bolt-on flare. Some folks really can't stand the bolt-on look, but to each his own. I think it looks pretty cool on some of the above examples, it's just not what I'm planning. I've got plenty of other body mods in mind, so doing the required blending isn't adding anything I wasn't intent on doing anyway.
    For the record, my interests are not initially "more tire" even though I'll probably move in that direction later. I'm building a track-only R-car and I've got aggressive aero plans, so I'm not terribly worried about not being able to get heat in the tires. Still, the FFR mule is doing pretty well with tires sized within the common ranges found on the 818. So "more tire" alone isn't the overriding concern for me. I want more track width, and that will require flares with just about any wheel/tire combo I'd plan. For my part, if it interferes with those plans, it's getting cut out.
    Best,
    -j
    Executive Director
    The Community Garage
    Puyallup, WA
    Itll be some time before i start mounting the body panels on but i will keep you guys posted.
    Canada
    Here are 2 other shots of the FRS you posted:
    ABout as bad as the pic 5 posts above.
    Denver, CO
    I think Porsche flares are the best looking. The body shapes to them well. If it is going to look good, they need to be part of the car or flow with it.
    Although an older generation, panteras are commonly flared.
    San Diego Ca 92106
    How radical do you want to go.
    Edmonton, Alberta
    I agree, the rear especially looks like ***. Please remember that my intention is not to ruin the look of the car. If need be, molding a flare in might the only way for it too look good. I'm glad that there's a few others determined to run wider tires, and now with a 600hp EZ30R build thread, we're about to see the need for them.
    818 SRX - #91
    Arrived 01/02/2014
    Who makes a 255/30R18 tire? or is that a typo and it's 35?
    Puyallup, WA
    That is a typo. Fronts are 35, rears are 30.
