Page 11 of 11 FirstFirst ... 91011
Results 401 to 404 of 404
Thread: iWire Turn Key 818 Harness for R and S Models
  1. #401
    Disabling the clutch safety switch is an option with an iWire harness, so it's possible the previous owner had that done. Your ECU should have the iWire harness number on it in case they have your harness's build options on record.
  2. #402
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by Brett33 View Post
    question just acquired a kit with your harness. Should I be able to start the car without pressing in the clutch?
    I assume not for safety and something is installed incorrectly but I want to verify.
    Brett
    Please send us an email to [email protected] with who you bought it from and a build number if possible. As eggman mentioned, disabling the clutch switch is an option and depending on when it was built we did it a couple different ways.
    When we say to our customers "if there is anything you need, please ask," we mean it.
    iWire Subaru Wiring Services
    Over 100 Custom 818 Wiring Harnesses Built
    http://www.iwireservices.com/factory...18-wiring-kits
    [email protected]
  3. #403
    iWire's Avatar
    Lake Forest, CA
    Busy season is very much upon us. We're crossing 818 build 110 and have a bunch in line. Make sure you get your inquiry in sooner than later so your project won't get delayed!
    [email protected]
  4. #404
    iWire's Avatar
    Lake Forest, CA
    Well that busy season has not stopped. We're over 120 and more than 10 sitting in line. If you are working on your 818 please reach out so we can get you scheduled.
    [email protected]
