Page 1 of 10 123 ... LastLast
Results 1 to 40 of 404
Thread: iWire Turn Key 818 Harness for R and S Models
Hybrid View
    iWire's Avatar
    Lake Forest, CA
    Check out our interactive customer map!
    ECU Plates are finally in. Comes standard with V4 harnesses. iWire V1-3 customers can purchase them for $65 plus shipping, non iWire harness customers for $100 plus shipping.
    V4 manual completed and up for anyone to check out how simple the install is.
    Non Drive by Wire Engine Install Manual
    We're now shipping V4.0 harnesses that have been updated for a better fit, upgraded materials, and an ECU box to protect for the elements. In addition we're now a Cobb Tuning authorized dealer so make sure to grab an Accessport with your build!
    For those who are looking at having us build you a harness, the sooner you get a hold of us the better we can fit into your project timeline. We have streamlined our process while still giving you the ability to customize to suit your needs and with that you can now expect approximately 4-6 week wait. If you need a specific time frame please let us know.
    The goal of the kit was to build a high end race spec harness that is completely plug and play, built from scratch using bits from your Subaru harness, and customized to individual specifications. The end result is a turn key harness that can be for any type of build from the simple to the complex. Our main focus was to turn a wiring process into a mechanical one. All you need to do is to run the harness, sand a couple spots for grounds, bolt it down, and hook up the battery. Assuming the mechanical is ready to go, it should only be a couple hours of work before you'll be able to rip the car down the street.
    Includes:
    • All Kits come with 3 fuse boxes with accessory, key on, and constant power and all basic equipment from engine to headlights, taillights, cluster, turn signals, etc.
    • ECU box for mounting and protection from heat/moisture
    [*]$65 Mounting hardware
    • Adhesive or screw in tab with heavy duty zip tie
    • Self-fusing rubber tape to eliminate any vibration between the harness and clamps
    [/LIST]
    Options Include:
    • Cruise Control
    • ABS
    • Daytime Running Lights
    • Power Mirrors
    • Many more, just ask!
    Pictures of completed R and S harnesses can be found here -
    126 Justin S. 2.0 WRX Powered 818 #1181
    125 Ian P. JDM V7 Powered 818 #1178
    124 Terry B. 2.0 WRX Powered 818 #1177
    123 Johannes E. 06 WRX Powered 818
    122 Lawson S. 2.0 WRX Powered 818
    121 Christopher E. 06/07 WRX Powered 818
    120 Bill S. 06/07 WRX Powered 818
    119 Devin P. 2005 STi Powered 818
    118 Mike B. 2005 WRX Powered
    117 Kent S. 2.0 WRX Powered 818
    116 AllPro Subaru 2.0 WRX Powered 818
    115 Erick C. 06/07 WRX Powered 818
    114 Jason F. 06 WRX Powered 818
    113 TJ K. 2.0 WRX Powered 818
    112 Kozmic Motorsports STi Powered 818 Race Harness
    111 Jay S. 06 WRX Powered 818
    110 Ben B. 06 WRX Powered 818
    109 Joel B. 2.0 WRX Powered 818
    108 Barry R. 2.0 WRX Powered 818
    107 Wendell H. 06/07 WRX Powered 818
    106 Keith C. 06/07 WRX Powered 818
    105 BC H. BC H. 2.0 WRX Powered 818
    104 Glenn R. 2.0 WRX Powered 818
    103 Jeff B. JDM GD STi Powered 818
    102 Craig R 2.0 WRX Powered 818
    101 Tommy T. 06 NA powered 818
    V4.0 Harness Pictures
    Where you see empty looped wire, keep in mind they are extras added in by customer request for auxiliary power, ground, and signal wires to run fans/gauges/lights/etc.
    Combined Full Harness
    ECU to Engine Section
    Front Harness Section
    Rear Harness Section
    Alternator - Battery - Circuit Breaker - Ground Strap
    ABS Sub Harness
    Detail Shot with Adhesive Lined Shrink Tube to seal, add strain relief, and clamp the split sleeve
    iWire's Avatar
    Lake Forest, CA
    Harness will come with heat and moisture resistant cover to protect the ECU. Please excuse the prototype, the final product will be much nicer looking and fitting as well as have a layer of heat reflective material and weatherstripping to seal and eliminate vibrations and noise.
    Main Dash Section with Fuel Pump Controller and Fuseboxes
    Hood/trunk light Switch, and OBD2 Port. We can provide a Cobb AP with your purchase for diagnostics and tuning. For R models, you can choose to run an aftermarket wiper switch and an all inclusive motorcycle switch in place of the factory wiper and lighting stalks.
    Options for switch panels and switches to be mounted in the dash are available.
    Customer Comments:
    To see all of our reviews click here!
    Huge compliment from Jim B. #054
    "Plugged in the wires, turned on the key. Started right up.
    Doesn't get any better than that.
    Thanks for your help."
    "Cant wait to get it. I do believe this is the way to go. I've wasted enough time trying to get my harness to fit. Thanks for offering this service!!"
    "Yeah, (dieting the OEM harness) was a lot of time and work and in the end, it's a hacked up harness. I could probably...maybe...make my own (harness) from scratch, but I don't have time or desire too. Dan really encouraged me to go your route after getting his."
    "I will say that I spent about 30 minutes laying out the harness on the floor then about 2 hours routing it in the car and the car started.
    VS
    2 months of wire diet, money for more wire, money for tape, money for burn ointment, and an unspecified amount of frustration with Subaru wiring and their color code. When I do this again, your harness will be in the budget from the beginning."
    "I just started laying my iWire harness in this weekend. I was reminded of the workmanship and couldn't help but think to myself that I was happy to have shelled out the coin for such a nice product."
    Check us out at www.iwireservices.com
    https://www.facebook.com/IWire-Wirin...5786161784988/
    949-510-8278
    [email protected]
    When we say to our customers "if there is anything you need, please ask," we mean it.
    iWire Subaru Wiring Services
    Over 100 Custom 818 Wiring Harnesses Built
    http://www.iwireservices.com/factory...18-wiring-kits
    [email protected]
    anderson
    great looking product!!!!
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by gpaterson View Post
    Would you consider putting an 818S harness together but using a keyless ingition system something like this? Would be great I think.
    Yeah we could do something like that. The harness in the pictures uses a push button start, just not as fancy.
    Quote Originally Posted by indiana818 View Post
    Thanks!
    [email protected]
    anderson
    sorry to bother you but i am in a twitter with my 818 problem
    i made the mistake of buying a vcp harness and I believe he wired the harness for a 2.5 turbo out of a 2002 impreza
    I have a 2002 2.5 ej25 non turbo engine the ecu is not right related to the iac valve mine has 6 wires and the turbo version only has 3
    is there a fix you would recommend? I did a continuity test and show 1 red wire coming from the ecu (tech s) to the iac valve
    kerry sylvester
    765 675 7949
    email: [email protected]
    symptoms of the engine iac valve doesnt talk to ecu or move in or out when i turn on and off the key
    iWire's Avatar
    Lake Forest, CA
    kerry sylvester
    765 675 7949
    Sorry about the delay on the response. It didn't pop in my notifications for some reason. I'm sure Wayne can help you out (he has an outstanding reputation) so I would go back to him. To answer your question, there are serious differences between the turbo and non turbo harnesses and ECUs. If that is the case it would probably need to be redone with the non turbo harness and ECU.
    Just finished up Mechie3/Zero Decibel Motorsports harness and it turned out great!
    [email protected]
    iWire's Avatar
    Lake Forest, CA
    Oh and come say hi and check out Brando's car this Saturday at the Huntington Beach meet!
    Build list continued:
    079 John M. 07 WRX Powered 818 with Cobb 818 package, seat heaters, power windows, stereo, USB, test mode switch, mounting hardware, heater, map light, cruise control, master disconnect, hood and trunk light
    078 Michael M. 06 WRX Powered 818 with seat heaters, USB, AC, fog lights, map light, and Cobb 818 Package
    077 Tom F/ECS 06 WRX Powered 818 with with Cruise Control, Seat Heaters, Heater, AWIC, and Mounting Kit
    076 Dave L. 06 STi Powered 818 with master disconnect, Cobb accessport, IC water spray, AWIC, transponder and front and rear interior lights #745
    075 Adam H. 2.0 WRX Powered 818C with Racepak Street Dash, power windows, fog lights, AWIC, transponder, and AC
    074 Cliff W. 2.0 WRX Powered 818C with Cobb AP, power mirrors, power windows, master disconnect, heater, fog lights, and stereo
    073 Larry B. 2.0 WRX Powered 818 with with push button start, power windows, COBB accessport, cruise control, stereo, USB, and heater
    072 John H. 02 RS Powered 818 with cruise, USB, stereo, and heater
    071 Paul T. 06 WRX Powered 818C with every option you can think of!
    070 Wilfred R. 06 WRX Powered 818 - No frills added on this one
    069 Joe B. JDM GD STi Powered 818S
    068 Jim and Ralph V. 07 WRX Powered 818S with Cobb AP
    067 Andrew P. 03 RS to 818S - Very simple and straight forward harness.
    066 Ben S. 04 WRX Powered 818S with Power Windows, ABS, Power Mirrors, and Fog Lights
    Build list part 2
    Build list part 3
    065 Joe K 2.0 WRX Powered 818C With COBB Tuning Accessport, mounting hardware, cruise control, power rear view mirrors, fog lights, and power windows.064 John G. 06 WRX powered 818C with power windows, stereo, front and rear lights, and iWire Cobb 818 Package
    063 Mike Q. 2.0 WRX Powered 818C with power windows, power mirrors, map light, and our iWire Cobb 818 Package that includes AP, intake, and 3 port BCS
    062 Stephen C. 2.0 WRX Powered 818C with ABS and Racelogic Traction Control
    061 Robert G #2 2.0 WRX Powered 818C
    060 Factory Five Build School at Mott College 06 WRX Powered 818C
    059 Ray P. 07 WRX Powered 818R Update to V4
    058 Mike B. 06 WRX Powered 818S with OEM day time running lights and setup for power windows
    057 Alex M. 06 WRX Powered 818C with power windows, traction control, fog lights, and master disconnect
    056 Brian B. 2.0 WRX Powered 818S with power mirrors, cruise control, and seat heaeters
    055 Jason W. 2.0 WRX Powered 818S with seat heaters and Cobb Accessport
    054 Jim B. 07 WRX Powered 818S w/Cruise and Cobb Accessport
    053 David B. 06 WRX Powered 818S - Updated V4 harness with ABS, cruise, individual switches for a master, ignition, and Aux switches
    052 Mark H. 2.0 WRX Powered 818C with power windows, cruise, usb, stereo, heater, fog lights
    051 Chris W. 2.0 WRX Powered 818 R
    050 Gary C. #2 V7 STi Powered 818R
    [email protected]
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    Hi Brian,
    You indicated this was for an "R" model, but many of the things you listed as being supported would be needed only for street models. Is that to say this would also work in an 818S?
    Have you seen the 818 Registry on Google Maps?? https://www.google.com/maps/ms?msid=...a=0&dg=feature
    Want your 818 added to the Registry? https://docs.google.com/forms/d/1zmF...rNCY4/viewform
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by Xusia View Post
    Hi Brian,
    Just wanted to update this post. Yes, this is correct. Absolutely this harness would work in an S.
    Sound great Metalmaker12!
    Build List Continued!
    049 Josh H. 2.0 WRX Powered 818R with Switch Panel w/2 aux switches (one to power an AIM dash) and master shutoff.
    048 Brian B (Brian B 36) Second Build for his 06 STi Powered 818S with added 3rd box for Accessory Power, Power Windows, Cruise, Heater, Stereo
    047 Zero Decibel Motorsports (Mechie3) 06 WRX Powered 818S with Cruise, Seat Heaters, AWIC, Stereo, USB
    046 Stephen V. (Svanlare) 07 WRX Powered 818S with cruise, seat heaters, power mirrors, Traqmate leads, and kill switch
    045 Len S. 2.0 WRX Powered 818S
    044 Alan L 2.0 WRX Powered 818S with power windows for hardtop
    043 Mike A. 06 WRX Powered 818S
    042 Joe A. JDM V7 STi Powered 818S
    041 Davis K. 2.0 WRX Powered 818S
    040 John F. 2.0 WRX Powered 818S
    039 Rob M. 2.0 WRX Powered 818S with cruise control
    038 David C. from Australia RHD 06 WRX Powered 818R
    037 Patrick S. 06 WRX Powered 818S V3.0 fully modular harness
    036 Peter M. 2.0 WRX Powered 818S V2.5 w/modular rear harness
    035 Ethan H. 2.0 WRX Powered 818S
    034 Zsports Midwest 2.0 WRX Powered 818S
    033 Mike S. (Chedda) 2.0 WRX Powered 818S
    032 Travis H. 2.0 WRX Powered 818s - Harness V2.0 with modular body and engine harness
    031 Steve G. 04 STi Powered 818R
    030 Gregg C 06 WRX Powered 818S with RaceLogic Traction Control
    029 Justin S 2.0 WRX Powered 818S
    028 Neil G. 03 WRX Powered 818S
    027 Brian H. 05 WRX Powered 818S
    026 Noah B. 03 WRX Powered 818S with new gas tank and firewall
    025 Prime Performance JDM STi Powered 818R
    024 Dan M. 05 WRX Powered 818S
    023 Jim B. 05 WRX Powered 818S
    022 Lee H. 06 WRX Powered 818S
    021 Mitch W. 2.0 WRX Powered 818R
    020 Ray P. 07 WRX Powered 818R
    019 Simeon B. 06 WRX Powered 818S
    018 Ivan F. 06 WRX Powered 818S
    017 Tom M. 2.0 WRX Powered 818S
    016 Ron A 2.0 WRX Powered 818S
    015 Tim M. 07 WRX Powered 818S
    014 Brian B 2.0 WRX Powered 818S
    013 Lee and Robert G. 2.0 WRX Powered 818S
    012 Dave W. 06 WRX Powered 818R
    011 Criag's 06 WRX Powered 818R
    010 Doug's 06 WRX Powered 818S with Remote and Push Button Start
    009 Gary's V5 STi Powered 818R
    008 John's 2.0 WRX Powered 818R
    007 Jason's 2.0 WRX Powered 818S
    006 Six Star Car's 2.0 WRX Powered 818R
    005 Christian's 2.0 WRX Powered 818S
    004 Rick's 06 WRX Powered 818R
    003 Chad's 06 WRX powered 818R
    002 Anthony's JDM STi Powered 818R
    001 Brandon's JDM WRX Powered 818R
    [email protected]
    Kirkland, WA
    Hi Brian,
    I plan to license my "R" like I have done my Challenge car so I need the basic street items for inspection.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Exeter R.I
    OK, worth every penny!!!, nice job man. maybe when I get it all apart for paint I will consider this option
    Clovis, Ca
    Hey Brian- I wont need the trunk lights, ebrake stuff, or wiper on mine Looking good! BTW- you should get it tomorrow.
    Thanks- Chad
    Kirkland, WA
    Plan for the future, be aggressive, think bold
    Tony Nadalin
    iWire's Avatar
    Lake Forest, CA
    Haha! I think we he is trying to say is that's it's not big deal to have those provisions in there so you can use them later if you decide you need them.
    100 Joseph B. 07 WRX Powered 818 with power windows, ABS, ground effect lighting, dome light, interior lighting, battery disconnect switch, and Cobb Accessport
    099 Calvin D. 07 WRX Powered 818 with Cruise Control, USB Port, iWire Mounting Hardware, and iWire T-Shirt
    098 Anthony N. V2 JDM STi powered 818
    097 Grant E. 2.0 WRX Powered 818 with power windows, accessory power, cruise control, master disconnect, and USB power socket
    096 Michael I. 2.0 WRX Powered 818 with economy battery disconnect and USB port
    095 Jason S. 2.0 WRX Powered 818 with power windows, fog light, longacre switch panel, USB, Longacre battery disconnect, and iWire mounting hardware
    094 Alan B. 06/07 WRX Powered 818 with cruise control, USB port, and iWire Mounting Hardware
    093 Phil B. 06 WRX Powered 818 with power windows, fog lights, master, and dual USB ports
    092 Bruce S. 06 WRX Powered 818 with cruise control, basic disconnect, COBB Accessport and SF Intake, iWire Mounting Hardware
    091 Mark F. 07 WRX Powered 818 with power windows, cruise control, ABS, switch panel, Cobb Acessport, Cobb Intake, Sport BCS, push button start, iWire T-Shirt
    090 Doug O. JDM WRX Powered 818 with switch panel and master disconnect
    089 Joseph N. 07 WRX Powered 818 with iWire Mounting Hardware, fog lights, hood light lead, transponder, stereo, heater, map light, USB with iWire Test Mode Switch
    088 Chris S. JDM STi Powered 818 with master disconnect, switches for carberry, power windows, USB, iWire Test Mode Switch, iWire Mounting Hardware, seat heater, and stereo
    087 Greg P. 2.0 WRX Powered Powered 818 with power windwos and iWire Mounting Hardware
    086 Christian B. 2.0 WRX Powered 818 with power windows, fog lights, cruise control, heavy duty master disconnect, mounting hardware, Cobb Acessport, Cobb SF Intake, and Cobb Boost Control #790
    085 Lou D. 2.0 WRX Powered 818 with power windows, side mirrors, stereo, switch panel, and iWire Mounting Hardware #787
    084 Jeff T. 04 STi Powered 818 with power windows, daytime running lights, ABS, side view mirrors, cruise control, and mounting hardware kit #785
    083 Lorne E. JDM STi Powered 818 with AVCS, master disconnect switch, USB power socket, stereo, AWIC, and mounting hardware
    082 Steven G. 2.0 WRX powered 818 with Cobb accessport, master disconnect, mounting hardware, fog lights, USB, stereo and heater
    081 Peter S. From Sweden 08 WRX Powered 818 with Haltech 2500 Elite ECU, IQ3 Dash, Haltech CAN Hub, Haltech Wideband 02 sensor, heater, stereo, USB, AWIC, and master disconnect
    080 Ron C. 03 WRX Powered RHD (Australia) 818 with cruise, power mirrors, map light, stereo, ABS, mounting hardware #760
    [email protected]
    Clovis, Ca
    Quote Originally Posted by iWire View Post
    I will never have them...haha No windshield, no ebrake, no trunks.... Its a race car.
    Thanks- Chad
    Chicago, IL
    Ditto. I have no plans even for headlights (no night-time enduro runs, so no need, the buckets aren't even going in). No turn signals, no horn, no wiper, no license plate light...that's a race car. The harness looks really nice, but it does seem to have a lot of extra for a straight up race car...though, I would like a heated cup-holder for my customary pre-run macchiato. =)
    Sweet offering Brian! A much needed service.
    Best,
    -j
    Executive Director
    The Community Garage
    San Diego Ca 92106
    Look forward to meeting you at HB this weekend.
    iWire's Avatar
    Lake Forest, CA
    You too! Excited to meet a new crowd of car enthusiasts.
    [email protected]
    Apr 2014
    Cool!
    Senior Member metros's Avatar
    NoVA
    Wow, neat and tidy is an understatement. Looks like a quality harness.
    Eugene, OR, USA
    Oh, it looks absolutely bad a$$ awesome!
    iWire's Avatar
    Lake Forest, CA
    Hopefully I see some of you guys out in Huntington Beach tomorrow! Look for the guy in the iWire shirt.
    [email protected]
    Kirkland, WA
    I received my harness on Friday, top notch, very high quality. I have not had a chance t install the harness yet, need to do some more work, but I did some engine work and I attached the harness to engine and battery and I was able to fire up the engine standalone. Nice job Brian ! Harness I sent weighed was 49lbs the harness I got back was 23lbs (all connector, modules, fuse boxes, etc.), nice job (as I have a bunch of extra wires run for future stuff). I'm 200% pleased with the work that you have done. More to come as I install. This is something that Dave needs to pick up on ASAP.
    Tony Nadalin
    Clovis, Ca
    Brian is getting ready to start on mine. I cant wait.
    Thanks- Chad
    iWire's Avatar
    Lake Forest, CA
    So glad to hear the car fired up and you're happy!
    We'll come up with some cool stuff on yours since it's extra simple.
    [email protected]
    iWire's Avatar
    Lake Forest, CA
    Showed up to today for C.Plavan. Same size as the other panel but comes with 2 switches. Good find Chad!
    [email protected]
    Kirkland, WA
    Chad just has to be different
    Tony Nadalin
    Clovis, Ca
    True! Haha-
    Thanks- Chad
    Mechie3's Avatar
    Indianapolis
    Would something like that work with the factory immobilizer? I assume you'd still have to put the key in somewhere though.
    Check out my new website!
    Clovis, Ca
    I have the key and ignition switch hidden under the dash. In fact I have not seen it in almost a year.
    Thanks- Chad
    iWire's Avatar
    Lake Forest, CA
    More than you can afford...Ferrariiiiii. ;D
    What Chad said. We'll just tuck it away. Key only needs to be in there to to have the immobilizer antenna pick up the RFID signal.
    [email protected]
    NoVA
    As badass as the 818 is by itself, that carbon control panel is just awesome by itself. Makes the interior much more racecarish.
    Michigan
    Wow, this is exactly the kind of kit that would help an electrical layman like myself wire a car up. Using a donated car's rat's nest is simply not an option for me. Bookmarking.
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by metros View Post
    The piece is really clean, good quality, and just happens to fit beautifully in the dash. The buttons/switches as well as the panel itself are solid. I'm going to see if they'll make a 4 aux switch version.
    Quote Originally Posted by EricScottZehnder View Post
    That's music to my ears.
    [email protected]
    iWire's Avatar
    Lake Forest, CA
    New shop, old table, but back to work on C. Plavan's harness!
    [email protected]
    Clovis, Ca
    Whooopish! Whooopsish!(Whip Sound).... Haha.
    Thanks- Chad
    iWire's Avatar
    Lake Forest, CA
    I was picturing more of a "vroom pssh" sound as you sat in your 818 seat waiting diligently for the harness to arrive. lol
    [email protected]
    Senior Member philly15's Avatar
    Nov 2012
    Appleton, WI
    I really wish I could afford to do this :/ definitely struggling with wiring my 818.
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by philly15 View Post
    I'm here to help!
    [email protected]
    Nov 2012
    Appleton, WI
    I'm here to help!
    my friend and I decided to try and tackle just building the harness ourselves from scratch. definitely time consuming, using one of my garage doors to post all the diagrams on. From what I noticed, there are very few actual fuses in the main circuits you actually need, kinda crazy to think about. I would also have to say Subaru's diagrams kinda suck imo. Now that we got it going, seems a lot easier than trying to make the stock harness work as it was. My only worry is if we might have deleted something critical for the ECU to function, flash, etc. since we deleted so many things, hopefully it all works out! We basically wired in only what we needed to control the engine and cluster basically, everything else such as lights, etc. we put all on their own separate circuit controlled by a switch panel, is there any issue doing it that way?
