Page 3 of 11 FirstFirst 12345 ... LastLast
Results 81 to 120 of 404
Thread: iWire Turn Key 818 Harness for R and S Models
    iWire's Avatar
    Lake Forest, CA
    Hey Brian,
    FYI- I installed the VSS simulator as we discussed. I know it works because my MPH jumps around from 20 to 40 mph tricking the ECU. However, I still have not been thrown into limp mode Pre-VSS sim zooming around the neighborhood. So who knows? Regardless, guys like me have an option ($40). I will have GPS MPH on the datalogger.
    We know it works to make the ECU happy enough not to throw a code, but it can't tell which gear it's in. Does it matter? Probably not and will be good to see how it goes with your car! Thanks for the update!
    When we say to our customers "if there is anything you need, please ask," we mean it.
    iWire Subaru Wiring Services
    Over 100 Custom 818 Wiring Harnesses Built
    http://www.iwireservices.com/factory...18-wiring-kits
    [email protected]
    Kirkland, WA
    Hey Brian,
    What is the $40 option?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Clovis, Ca
    http://www.enginewiring.com/catalog.htm#Featured
    Well look at that wiring
    Thanks- Chad
    Senior Member metros's Avatar
    NoVA
    I'm not entirely sure why you need the vss simulator. Is this something I'll need to look into with my iwire harness?
    Btw, post more videos Chad. The sound in your videos makes me want to drop whatever I was planning on doing and get back in the garage.
    iWire's Avatar
    Lake Forest, CA
    Hahah! Looks great Chad! :P That's weird part of my job. You know I'm doing it well when no one notices it. haha
    You will not need that. Chad is running an 05 LGT trans that does not have a VSS (05 LGT gets it from the ABS). Yours will be totally normal and use a stock VSS.
    [email protected]
    Kirkland, WA
    Chad seems to always want to be different
    Tony Nadalin
  7. #87
    Clovis, Ca
    I call it planning ahead. LGT Trans= beefier gears than a WRX trans. Is also a 4.11 final drive. All benefits.
    Thanks- Chad
  8. #88
    Kirkland, WA
    My JDM 5sp (which has beefier gears and a 4.11 final drive) has a VSS so I get benefits ++
    Tony Nadalin
  9. #89
    Senior Member philly15's Avatar
    Nov 2012
    Appleton, WI
    which model of those fuse/relay boxes do you use for these harnesses? I really like them, on the website I was looking at they have a 15303-2 -4 -5 and -6. was wondering which ones you used?
  10. #90
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by philly15 View Post
    Depends on what you are trying to do. I use the single bussed fuse and wire up the relays one by one, but you could use a non bussed as well depending on how many relays/fuses you need to hook up and what kind of power they need.
    [email protected]
  11. #91
    Nov 2012
    Appleton, WI
    Quote Originally Posted by iWire View Post
    that makes sense, the website I was on didn't really describe the difference between the models so I was kind of guessing.
  12. #92
    I used two 15310s for mine.
    Depending on how many circuits you keep and if you combine them, you can end up needing a lot of space. I didn't use busses boxes because some of my circuits are battery powered and some are ignition powered.
    I also used these relays:
  13. #93
    iWire's Avatar
    Lake Forest, CA
    Just an update to the thread.
    I really need to rename this harness. Working on the first true S model and have sorted the factory steering column issues. So, although it is designed for the "less is more crowd" most S owners would be very happy with all features available.
    [email protected]
  14. #94
    iWire's Avatar
    Lake Forest, CA
    One more update.
    We're now offering the choice for circuit breaker or fuse for the main power wire and no more solder joints to shorten the main engine plugs as I have found a source for the terminals (note: these are NOT for sale, sorry guys have to keep somethings to myself).
    These are panel/dash mount style but will also be available in a surface mount style depending on what people want.
    [email protected]
  15. #95
    Clovis, Ca
    Very nice. If I ever pop a main fuse, I'll grab one of those. I don't think I ever have popped the main one, but it would suck if you were at the track!
    Thanks- Chad
  16. #96
    Kirkland, WA
    One more update.
    Do we get an upgrade ?
    Tony Nadalin
  17. #97
    iWire's Avatar
    Lake Forest, CA
    It's so unlikley. Pretty much the only time I've ever seen the main fuse blow is if you arc the alternator when taking the terminal off with the battery still connected. I put an extra main fuse in the box so you should have one you can carry down so at least you can keep going if something were to happen.
    Do you want a circuit breaker? It's not really an improvement so to speak, just adds options because some are partial to one over the other.
    [email protected]
  18. #98
    iWire's Avatar
    Lake Forest, CA
    First S harness completed and out the door.
    https://www.facebook.com/media/set/?...1&notif_t=like
    [email protected]
  19. #99
    Kirkland, WA
    Look close to the R harness, well at least my R harness since Chad had to be different
    Tony Nadalin
  20. #100
    iWire's Avatar
    Lake Forest, CA
    Very close to the R (except for Chad's because he's "special"). Big difference is no switch panel and use of factory column switches. He also has leads to hook up an AC system. It's more a function of letting people know that this kit can fit the bill for most builds, S or R.
    [email protected]
  21. #101
    Nepa
    What's the price on s model and what's needed to be sent in? Or can we sell off the factory harness to offset the cost? Thx
  22. #102
    Denver, CO
    Man I wish these wouldn't break my budget bank. It would be amazing in my kit.
  23. #103
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by Samiam1017 View Post
    Same price as R. It might be a little more depending on how many add-ons you want. I need the factory Subaru harness because I use it as the base to build this one. Besides the factory harness, ECU, and fuel pump controller I just need the lighting plugs and the fuel tank plugs that FF provides.
    Quote Originally Posted by bbjones121 View Post
    I wish I could bring down the cost, but the time in labor and cost of materials just doesn't make that possible at this point.
    [email protected]
  24. #104
    Senior Member Brando's Avatar
    Irvine, Ca
    Cool Brian, you pulled off the S harness. That's huge.
    Frank is almost done lets go for a drive.
  25. #105
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by Brando View Post
    Let's do it! I have your intake manifold harness here. I'm going to use it for a prototype for an option of custom intake manifold harnesses for guys that are taking things out like TGVs.
    [email protected]
  26. #106
    Kirkland, WA
    Just get a JDM engine and don't have to worry about TGV delete or harness
    Tony Nadalin
  27. #107
    iWire's Avatar
    Lake Forest, CA
    Well, that would be one solution.
    I'm also going to make it pretty for people who are interested in things like that.
    [email protected]
  28. #108
    iWire's Avatar
    Lake Forest, CA
    [email protected]
  29. #109
    NoVA
    How did I miss these 2 latest updates?
    Nice looking S harness. Can't wait to get ahold of it!
  30. #110
    iWire's Avatar
    Lake Forest, CA
    Dunno, but you're up next week as I'm about done with the current one.
    [email protected]
  31. #111
    iWire's Avatar
    Lake Forest, CA
    Six Star Cars is done. Ready to start your Jason. Thanks for your patience.
    https://www.facebook.com/media/set/?...1784988&type=1
    [email protected]
  32. #112
    Kirkland, WA
    Need to step up that production line ! Its so simple you just connect the red wire to white wire
    Tony Nadalin
  33. #113
    NoVA
    Awesome, looking forward to it.
  34. #114
    Jun 2012
    Hello, I'm really interested in this wiring kit but I have an 05 STI donor car and it has become my full track car. Therefore, my stock wiring harness is pretty much cut up for weight saving purpose. I have a few questions. This is for the S model as I like to be street use but more of a hybrid like an RS a little bit more on the track side.
    1). I will be using my 05 STI as donor and I would like to see if the harness will work or I may decide to use the 04 STI ECU to eliminate the immobilizer or can I just use a 06 WRX ECU which is a 2.5L? Whichever is easiest.
    2). Of course I wouldn't be needing the DCCD function and I will be using the 05 STI dash cluster instead of a WRX. Can it be wired up using the STI cluster?
    3). Like I said, my stock 05 STI wiring hardness is chopped up. So do I need to sent in my stock harness or how's that going to work out? I really like to avoid to spend the time to take the stock harness out if not needed.
    If I can avoid using the stock harness that would be perfect.
    Thank you.
  35. #115
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by mug23 View Post
    Thank you.
    1. Yes, we can do that no problem. However, I would suggest that you leave the 05 ECU in there. It's actually a better ECU to tune. The problem with the 04 it's basically designed as a 2.0 WRX ECU and they slapped the drive by wire and AVCS as it was a bit of a band-aid for Subaru to get the first USDM STi out. The 05 ECU is the first actually built for USDM STi platform.
    2. STi cluster, and any cluster someone might desire is not a problem. The plugs are the same as USDM WRX, it just has extra pins for the extra features.
    3. What exactly is cut? Ideally I would need the ECU to engine section uncut as we use some of the stock harness as a base. Beyond that, it doesn't really matter as I can use just the leftover pieces or grab them off a scrap harness from here. Shoot me some pictures to iwiresales at gmail.com
    Brian
    [email protected]
  36. #116
    Senior Member fact5racer's Avatar
    Did you get my JDM harness yet?
  37. #117
    iWire's Avatar
    Lake Forest, CA
    Quote Originally Posted by fact5racer View Post
    UPS came before I got in on Friday. I should have it Monday. I'll let you know.
    [email protected]
  38. #118
    iWire's Avatar
    Lake Forest, CA
    First of 4 in 4 weeks done. So far on schedule.
    https://www.facebook.com/11578616178...type=1&theater
    [email protected]
  39. #119
    iWire's Avatar
    Lake Forest, CA
    2 for 2.
    Just a heads up to anyone still looking for an engine. Any Impreza turbo/non turbo engine from 93-07 can be wired up with the factory ECU and will bolt right in to the 818. I generally recommend 02 and up because it opens up all of the modern tuning options, but it's not requirement.
    https://www.facebook.com/media/set/?...=3&uploaded=12
    [email protected]
  40. #120
    iWire's Avatar
    Lake Forest, CA
    Plenty of creature comforts on this S model!
    [email protected]
