0
0
ECM Mounting Problems
I have a 99 - 04 ECM Mounting Bracket, but the problem I am having is that the computer will only fit one way in on the bracket and it would end up having to be mounted up-side down in the GTM.. This will not work because the engine wire harness plugs can't be plugged in with the ECM mounted up-side down.. I am not sure what bracket they used in the build manual, but what have others used to mount their ECMs onto the mount that is on the GTM??
