is the high beam switch just a on-off switch?
Owner MK4 7642RD, 393 stroker, Gordon Levy Super Alloy T5, HDX Clutch, Moser 3.31 3-link with disc brakes, 17" Bullit wheels, NT05's, Seat heaters donated by WarmSeats.com, door panels donated by Herbs Door panels.
OK, I posted this on the other forum, but thought I'd add it here, too!
Simple toggle for me to trip the hi relay. On Richard Oben's advice, I ran the "big" light power (both low and high beam) through relays and let the off/on and lo/hi switches handle the little power to toggle the relays.
So, two toggles. One turns the lights on and off. The other sends power either to low beam or high beam.
The lo/hi switch is right by my right hand when it is on the steering wheel. Really easy to flick up and down.
One of the last Mark II's, FFR complete date 5/8/04, delivery date 5/23/04, donor-'93 Mustang GT. Yes, that is me in my Avatar. Paint done by Da Bat! It looks killer! Drive it like you stole it...
No, it is not. An On-Off switch is a single pole, single throw - SPST. It has two poles, or two connections for wires. Power comes to one pole, and then when the switch is closed, it goes out the other single pole.
The headlight switch is a single throw double pole - STDP. It has 3 poles, or three connections for wires. Power comes in to one pole. The single throw of the toggle will select one of the other two poles for the power to go out to.
.boB "Iron Man"
www.RacingTheExocet.com
Just to elaborate on Bob's (correct) response these are typically referred to as an ON/ON switch.
You'll have to look at the schematic. The switch can be used to power the lights directly, which means a Positive switching. Or it can be used to actuate a relay, which can be positive or negative switching.
.boB "Iron Man"
Just like the Ron Francis manual shows. Connect the light blue headlight dimmer switch feed wire in the dash harness to the center pole of the included STDP ON/ON switch. Connect the red low beam wire to one of the outside poles and the brown high beam wire to the other. It doesn't matter which; when you install the switch you'll orient it so that up=high beam. I can't recall if RF already tapped in a wire for the high beam indicator or not (I think they did). If not you simply add a pigtail from the brown high beam feed. Whether yoi installed it or Francis did you'll join this additional wire to one side of the blue indicator light and ground the other side. That's it!
Good luck,
Ok...I don't see a wire marked "brown high beam feed" I have a "brown switch feed wire" and a brown wire that is not marked. Both have two brown wires going into one connector. I think one is for the high beams and the other for the fan switch....how can I tell which is which?
Pull out the multi-meter, set it on continuity, and figure it out.
um...yeah.... don't got one Pete, but might need to get one or when I get my battery just see which one works.
I would put a multi-meter on the "must have tools to build a car" list. You can get a decent one for under $50: http://www.craftsman.com/craftsman-m...4&blockType=G4
