0
0
818 Assembly Manual Revisions
I'd like to compile a comprehensive list of build manual revisions so to make it easier for anyone to compile a complete set of documents. Here is a summary of 818 Assembly Manual revisions with links to updates.
FULL VERSION AVAILABILITY:
This is available for purchase in printed and PDF form from the FFR parts catalog if haven't already bought the 818 kit.
UPDATES TO FULL MANUAL:
1E update - never released, turned into 1F
1F update - 9/25/2014
1G update
- Naturally Aspirated Fill Location
1H update - 2/3/2014
- Front lower control arm
- Front upper control arm
- Steering Rack
- Rear control links
- Lateral Link
- Front engine cover
- Windshield
- Door Liner
1I update - 4/9/2014
- Pedal Box
- Cable Accelerator Pedal (2002-2005)
- OEM Seats
- Windshield
- Center Console
1J update - 9/2014
- Turbo coolant overflow tank
- Shifter handle
- Door skin
- Door liner
- Side mirrors
- Door handles and pulls
- Center Console
- Appendix G: Wiper Instructions
1K update - apparently never released
1L update - 11/2014
- Headlight wires
1M update - 12/2014
1N update - 2/2015
- Major parts needed
- Removing the Donor Parts
- Preparing the Donor Parts
- Fuel level sender
- Fuel pump
- Under Front Aluminum
- Interior Aluminum
- Fuel System
- Fuel pump
- Fuel Level sending unit
- Fuel tank
- Fuel Lines
- Fuel vapor canister
- Gas cap
- Rear cockpit firewall
1O update - 3/2015
- Side mirrors
- Steering rack
- Unpacking Your Kit
- Cockpit front firewall aluminum
- Steering Rack
- Rear Suspension
- Drivetrain Install
- OEM Pedalbox
- Brake Master cylinder
- Clutch Master cylinder
- Steering Column
- Accelerator Pedal
- Fly By Wire Accelerator Pedal (2006-2007)
- Seat Belts
- Clutch hydraulic lines
- Wiring harness
- Main harness
- Steering column
- Pedalbox
- Headlight wires
- Radiator
- Horns
- Front coolant tubes
- Top hose
- Bottom hose
- Coolant overflow tank
- Cable shift Brackets
- Cable shift Transmission bracket
- Shifter linkage
- Cooling system
- Fuel System
- Fuel Lines
- Rolling Chassis Check
- Wheels
- Fluid Levels and Grease
818R Supplemental instructions - Revision A: 12/5/2014
Moderators - I've included links to download updates since they are not available for purchase. Please remove them or instruct me to do so, if desired.
