Results 1 to 14 of 14
Thread: RoRi's Custom Parts - Radiator Spacers
    rori's Avatar
    Tulsa, OK
    These spacers raise the radiator by 18mm giving you the clearance you need to prevent the steering rack bellows from rubbing on the radiator hose. They are grooved on the inside to retain the OEM bushing. The bottom protrusion is offset by 1mm acting as a cam and allowing you to fine tune the placement of the radiator left, right, fore, aft, or simply to compensate for imperfectly welded tabs on the FFR frame. Includes 2 spacers, 2 washers, and 2 button head screws.
    $60 plus $5.80 priority mail shipping in the USA. International shipping available.
    Radiator Spacer:
    With bushing installed:
    Bottom Cam is offset 1mm and fits into FFR frame:
    Installed:
    Complete package:
    Senior Member metros's Avatar
    NoVA
    Payment sent via PayPal. Thanks for continuing to produce these great parts that make those little tweaks straight forward.
    After raising the radiator, any problem with hood or other body part clearance?
    Mechie3's Avatar
    There should be plenty of clearance. I raised mine up quite a bit and still have a good inch of clearance IIRC. The main reason to raise it is because if you don't the lower hose hits the steering rack bellows.
    Zero Decibel Motorsports
    Senior Member Triathletedave's Avatar
    Calgary
    Quote Originally Posted by tmoretta View Post
    What has to be done with the top brackets on the radiator if you raise the bottom? Does the kit include 18 mm spacers for the top as well? Can you post a picture of the solution on top please?
    TriguyDave
    818 noobie builder
    First start: Sept 28, 2014
    Go-carted: Oct 4, 2014
    Registered and Street legal Sept 30, 2015
    Calgary, Alberta
    rori's Avatar
    Tulsa, OK
    Quote Originally Posted by Triathletedave View Post
    I used Mechie3's solution: http://thefactoryfiveforum.com/showt...el-Motorsports
    San Diego Ca 92106
    If there's an inch or so above between the radiator and the hood, won't a portion of the airflow bypass the radiator and out the hood vents? Would a fitted sheet of aluminum from the radiator between the headlights to the end of the hood be worth the effort?
    rori's Avatar
    Tulsa, OK
    10 more sets now in stock. PM me if you are interested. Thanks
    rori's Avatar
    Tulsa, OK
    10 more sets arrived today. PM me if you need some.
    Hughesville, Maryland
    Do you still have them available
    rori's Avatar
    Tulsa, OK
    Yes, I have a few sets left.
    rori's Avatar
    Tulsa, OK
    I have 8 sets left. These will be the last of them. PM me if you are interested.
    Quote Originally Posted by rori View Post
    i'll take a set, pm sent
