Results 1 to 11 of 11
Thread: Footbox access panel
    Grosse Pointe, Michigan
    I need to fabricate an access panel into the top left panel of my driver's side footbox. I found one excellent example in the "other" FFR forum, however any pictures, suggestions, etc. would be greatly appreciated.
    Sam Stanley
    Member KodiakCoupe's Avatar
    Kodiak, Alaska
    Just finished mine. I hope to post some photos of this very thing within the next couple days.
    steve
    The Coupe Du Jour #443
    http://www.flickr.com/photos/38188992@N04/
    Here is what i did for mine. I sized it by the area not covered by the body. Of course its a Mk 4 but it may give you a idea.
    Senior Member CJBergquist's Avatar
    Palo Alto, CA
    Here's mine.
    Try this like for more foot box photos.
    http://www.flickr.com/photos/5110304...7622924159838/
    If it's too LOUD....you're too OLD!!
    Build Site >> http://www.flickr.com/photos/51103049@N00/collections/
    FFR#0441CP Complete Coupe kit, IRS, T-5, 392ci 351W, Webers, Delivered 4/29/09
    Junior Member Matt's's Avatar
    Just curious, what purpose does the access to the footbox serve? Just wondering if it's something I should plan for on the build.
    Thanks!
    What was I going to say?
    Fort Lauderdale Fl.
    access to the fuse panel, as well as any issues you might have with steering or bake pedal assmembly, definitly gets you access should you need to replace the clutch saftey switch!!
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    MKIII #5835 Someday I Suppose's Avatar
    Stanhope, NJ
    Makes replacing a broken clutch cable a lot easier then standing on your head and trying to reach it from below.
    Quote Originally Posted by Matt's View Post
    Thanks!
    MKIII #3835 IRS, Anderson Performance 408 Levy T-5 Trans, Team III Wheels
    Paint completed November 2010, passed NJ State Safety Inspection June 21st, Tagged and First Drive 7/1/2011
    Good to know, thanks all!
    Senior Member rj35pj's Avatar
    Marion, IN
    Thanks for asking Matt....I was wondering the same thing.
    Senior Member snakebit31's Avatar
    Virginia Beach, VA
    I used the Moroso panel which Jegs and Summit both sell. I also placed one on the rear deck above the fuel cell, to access the fuel sending unit.
    Kodiak, Alaska
    OK, a little late completing the project, but here's a little different method. Maybe not as pretty, but I'm all for simple. easy and effective.
    This one's a pre-assembly view with a shim used to facilitate the hinge opening that also visibly balances the box. The hinge is SS:
    Pre-assembled showing the thumbscrew/rivet nut and weatherstrip mounted on a riveted AL tab:
    Completed/secured assy:
    Hatch open:
    steve
