Results 1 to 2 of 2
Thread: One of the best FFR Roadsters anywhere ... $58,000
    Member KrissMotors's Avatar
    Boston & Miami
    This fantastic period-correct Ivy Green Mk3.1 was the sole reference car for the popular Mk3Build.com and Mk4 Build Manual. As such, it is extremely well documented ... practically every rivet and bolt has been photographed, and every penny spent has been posted online. It would cost about $70,000 to replicate this build quality today (not including labor). If you want the FFR Roadster but don't want to build it, this is the one to buy. A show car, a street car, and a track car.
    A brief summary:
    • Complete non-donor, all new parts
    • FFR independent rear suspension
    • Ford Racing Boss 302 with Mass-Flo electronic fuel injection
    • Professional fit and finish throughout
    • Licensed in Florida as an antique 1965 AC Cobra
    • Can be seen now in Waltham MA
    • Less than 2,000 miles
    • Many, many extras
    • $58,000
    Check out the original forum Graduation Thread from 2009. Log into the Build Manual (registration required, but it's free) to follow every step of this outstanding build. [Note: the Mk3Build.com web site is NOT included in this price.]
    Vehicle
    • 2460 lbs. curb weight (approximate)
    • front/rear weight distribution 46.9/53.1%
    • ground clearance 4.50” front, 4.75” rear at full curb weight
    • fuel sending unit and fuel pump access panels in trunk
    • VIN plate located on driver side cockpit cross brace
    Exterior
    • British Racing Green with matching Finish Line side louvers
    • dual roll bars, POR-15 durable black finish, Russ Thompson trim rings
    • Breeze trunk hinge system, prop rod, and trunk lock
    • FFR hood hinge system, Breeze prop rod, and dual hood locks
    • rolled edges, fender edges, widened tail light platforms, precision fit
    • period-correct separate bolt-on hood scoop
    • black side pipes with chrome heat shields
    • chrome over-rider bumpers front and rear (can be easily swapped for quick jacks)
    • period-correct 427 side and Cobra nose/deck badges
    • brake duct and oil cooler aluminum mesh screens
    • custom radiator cowling
    Engine
    • Ford Racing BOSS 302 M-6007-X302E
    • 302 cubic inch
    • 340 hp @ 5500 RPM, peak torque @ 2,500 RPM
    • BOSS 4-bolt main block M-6010-BOSS302 for lower-end stability at high power outputs
    • hydraulic roller camshaft M-6250-E303, .498” lift intake and exhaust, duration at .050” is 220 degrees intake and exhaust
    • double roller timing chain set M-6268-A302
    • Hi-Po SFI approved harmonic damper
    • Ford Racing aluminum GT-40 cylinder heads M-6049-X306 with 1.94” intake valves and 1.54” exhaust valves
    • ARP cylinder head bolts
    • roller rocker arms M-6564-B351
    • fuel pump eccentric M-6287-B302
    • reverse rotation water pump
    • valve covers M-6582-BOSS302
    • SFI billet steel flywheel with dowel pins pre-installed M-6375-D302
    • Canton racing oil pan with rear sump trap doors
    • 1.4Kw mini starter
    • SFI high performance balancer with two 0-40° timing marks (use set to left, facing engine, for reverse water pump configuration)
    Electronic management
    • Mass-Flo electronic fuel injection with single plane intake manifold and integrated fuel injector bungs
    • Mallory distributor, TFI mount, EFI Ford 302, HEI cap style, Series 79 (797040-002) with NAPA MP711 pickup
    • Aeromotive fuel regulator, 40 psi operating pressure
    • computer-controlled radiator fan, fuel pump
    • self-test connector for diagnosis codes, under dash passenger side
    • BBK 4-into-4 exhaust headers with welded oxygen bungs and sensors
    Electrical
    • separate fuse boxes for EFI and main harness
    • 3G, 95-amp alternator
    • 100 amp mega-fuse for alternator connection
    • multiple grounds for horn, radiator fan, lights, fuel pump, wipers, computer case
    • WeatherPack connectors on all body-mounted lighting
    • engine bay-mounted Breeze battery box
    • Optima 51R deep cycle battery (yellow top)
    Drivetrain
    • T5 M-7003-Z 5-speed manual transmission with short throw shifter
    • gear ratios: 1st 2.95; 2nd 1.94; 3rd 1.34; 4th 1.00; 5th 0.63 (same as 1984 T5 ratios)
    • limited slip powder coated differential with cast iron housing and aluminum cover, 3.55:1 final gear ratio (same as 2004-05 ratio)
    • Mustang HD clutch M-7560-C302N 10.5 inch single disc
    Suspension, brakes, steering
    • independent front suspension, adjustable upper control arm
    • independent rear suspension, adjustable upper and lower control arms
    • Koni coil over shocks with ride height adjustment sleeve
    • FFR coil springs, 500 lb front, 750 lb rear
    • Ford Mustang GT twin piston calipers with 11” front 5-lug vented rotors (1994 style)
    • Ford Cobra rear calipers with 11.65” 5-lug vented rotors (1994-98 style)
    • Wilwood 0.75” bore dual master brake cylinders
    • front/rear balance bar brake adjustment, removable access cover on footbox
    • Hawk HPS brake pads, HB274f.610 front and HB183n.585 rear
    • dual remote fluid reservoirs with convenient hood access
    Wheels, tires
    • Team III Halibrand wheels, 17×8” front, 17×10.5” rear, with spinners
    • Sumitomo HRT Z tires, 245/45 R 17 front, 315/35 R 17 rear
    • AC Interiors wheel well liners, front and rear
    Interior
    • Herb's leather door panels
    • upgraded Bentley black carpet with edging, driver floor and side scuff pads
    • full cockpit and trunk sound, vibration, and heat insulation
    • adjustable fresh air vents
    • stainless shifter handle, shift knob, boot, polished ring
    • left and right indicator lights (green), high beam indicator light (blue), check engine light (red)
    • vintage leather seats with Breeze adjustable tilt mount
    • dual roll bars with Breeze circular head rests
    • pedals matching height for heel-toe performance driving
    • battery cutoff switch with keep-alive memory fuse
    • vintage windscreen, tinted with Whitby custom side bars; DOT safety glass compliant
    • windscreen-mounted mirrors, rear and driver side
    • FFR wind wings
    • Lokar handbrake mounted driver side of transmission tunnel
    • Russ Thompson steering column self-cancel turn signal with high beam/flasher
    • 12-volt underdash recessed accessory plug
    • vintage all-electronic gauges with under-dash calibration patch bay
    Safety
    • full cockpit and trunk heat, fire, and sound insulation
    • driver and passenger roll bars with Breeze circular head rests
    • cockpit fire extinguisher
    • inertia switch, behind dash on passenger side
    • neutral safety switch
    • heat shields on side exhaust pipes
    • ​new FFR replacement pedals and quadrant modification
    INQUIRIES TO [email protected]
    Developer of the authoritative Build Manual Mk4Build.com used by over 1,000 FFR Mk3/Mk4 customers since 2009.
    Jul 2014
    Do you pics? If so, please post a few in this thread. Thanks, Matt
