Thread: Firewall Wiring
    Firewall Wiring
    The original cars used Lucas (prince of darkness) wiring looms. But modern reproductions use modern wiring harness. You can still get reproductions of the original wiring harness from places like Cobra Restorers, but that may open a can of worms. Still, you can make the firewall look more original using the old components but making them non functional. Here is a list of the components
    C5TF-FOMOCO, OEM style external regulator (AMK)
    115.003, Lucas SFB105 flasher (Retro Classic)
    115.018, Lucas SRB146 relay (Retro Classic)
    33117, Lucas DB10 relay box (Retro Classic)
    4FJ, Lucas fuse box (Various, i got mine off eBay)
    Here is a picture of the firewall of an original for reference
    You'll also want to use SW mechanical gauges
    Cheers
    Bill D
    Senior Member OCCPete's Avatar
    Dayton, OH
    You'll also need this for the toolkit
    Pete...nice and so true!
    In addition to the components I listed, you'll need the correct harness wrap and mounting clamps.
    The guys on Club Cobra were very helpful in identifying the correct wrap. It's similar to black electrical tape but doesn't have adhesive like the electrical tape. Here are two sources for the correct tape
    http://www.britishwiring.com/Harness-Tape-s/33.htm
    http://www.wiringharness.com
    Original cars used gold colored aluminum clamps P/N AN742. They are available at Aircraft Spruce
    http://www.aircraftspruce.com/catalog/appages/an742.php
