I looked for rear wheels that were 17x9 +35 but the only 17x9 Enkei RPF1 wheel made is +45 so I bought them after several guys said "just add a 10mm spacer", as if it's easy. The inner wheel rim hits the upper trailing arm so when I searched for spacers I found that I would have to remove the knuckle, press out the hub, press out the studs, press in new studs, press in the hub, reassemble and repeat for the other side. Any other solution?
I went with 17" because the 18" tires were over 25" diameter.
