Given that I really only have weekends to work on this, and given my wife's added motivation to make room in the garage for more cars... I think I'm about 1 year away from done. Agree?
What's done:
1) Donor tear down & parts clean-up (took 1 year)
2) Aluminum panels
3) Body buck
4) Rear-end install
5) 5-Lug conversion front & rear
6) Fuel tank install
7) Fuel lines
8) Brake lines
9) Pedal assembly
10) Brake booster
11) Seats
12) Wheels + tires
13) Engine mods : upper/lower intake, water pump, alternator, PS pump, 24# injectors
14) Engine + tranny install
15) Radiator install
16) Wiring
17) Hidden battery mod (trunk)
18) Secret compartment mod (trunk)
19) Mid-trunk separator mod + rear cubby hole
20) Stereo, speakers + AMP install
21) Stereo console mod (home made)
22) Radiator hose, PS hose
23) First start
24) MAF replace
25) Dial-in timing
26) Air + exhaust leak fixes
What's left:
1) Fan electrical shorting
2) Connect thermo switch
3) Why is Oil temp always max
4) Relocate coil
5) Install remote reservoir
6) Cut fuel filler neck
7) Align front-end to center
8) Install clutch cable
9) Mount T5 support frame
10) Install drive shaft
11) Tighten down ECU
12) Intall foot box top trap door
13) Tie down engine wiring
14) Tie down trans tunnel wiring
15) Install exhaust hanger bolts & rubber
16) Install T5 wire from harness
17) Install hazard rocker switch & tie-in
18) Resolve battery charge issue (alternator wiring)?
19) Carpeting
20) Water-tight speaker enclosures
21) Tie-down speaker wiring
22) Other aluminum
23) Dead pedal
24) Ready for Body-on
25) Door clearance adjustments
26) Lights & tests
27) Bumpers
28) Sand/fill body
29) Paint
30) Finishing chrome
Current pics & video:
Attachment 31074
