FFR has a page (135 or super close) with rear suspension components torque specs, however it confused me more than anything else.
For example, it says "Trailing link". What is a trailing link, is it the OEM Trailing Arm (lower) or the FFR Trailing Arm (upper)?
Says "Lateral link". What is a lateral link, is it the OEM Lateral links (lower), also called "rear toe-link", or the FFR small Lateral link (upper)?
FFR also changes vocab depending on which page you read. So all in all, it confused me.
Can anyone help me identify the right specs for each and all of the 12 rear suspension bolts? (There are actually 11 but I skipped #9 due to a mistake. loll )
Except the shock, as it's obvious on FFR's chart that both bolts are around 45lbs, it says "upper shock" and "lower shock", can't go wrong.
I have marked the pictures with numbers and FFR specs with letter for cross-matching, but obviously there are some missing, which is possible FFR means "torque to OEM specs", but I still need to identify these.
