Thread: Ridiculous question about spacers....
    Apr 2014
    Just starting my build and I know that things aren't always going to fit together perfectly. On my front lower control arms, the provided spacers are twice the thickness they need to be...so I need to grind them down. My dremel isn't making a dent and using a flat file might take me 2 months. How are you guys trimming spacers when they are too thick?
    I've put together a few of these have never had to change the thickness of the LCA spacers but I have had to spread the frame tabs. I suggest you give that a try.
    Good luck,
    Get a 1/2 inch bolt or all thread and put the nut or nuts inside the frame tabs. Unscrew the nut.
    Apr 2014
    ok...good points. The spacers I am struggling with now are on the lower shock mount. They need to be trimmed a bit. I'll figure it out.
    Senior Member ram_g's Avatar
    Houston, TX
    Well, there are lots of things for which you'll need something more than a dremel or a hand file. An air compressor and a good set of air tools are very handy, or (alternatively or in addition) a set of battery operated tools with interchangeable battery packs. Due to easy availability and frequent sales at Home Depot, I have a Ryobi One+ system with a couple of drills, an angle grinder, a sawzall, a handheld vacuum, etc... ALL of which have been very handy in my build.
    In this case if these are what I think they are (by the way, posting a pic always helps in this situation) I would clamp the spacers in a vice and have at it with an angle grinder.
    FFR Mk3.1 #6720. Carb'd 302. Fun.
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Know anybody with a lathe?
    Later,
    Mk3.1 #7074
    The shock spacers are aluminum. Two minutes and a hand file=DONE!
    Orange County
    I had the same issue with the lower spacers last week. I put the spacer in my vice and shaved down the spacer with my Dremel and a file. Worked pretty well and spacer fit with no issues afterwards.
    Ordered MKIV complete kit 4/2014. Completion 6/21/14. Delivery 7/19/14. Build started 7/20/14. Levy Racing stage 4 347 carb w/super alloy t5. 8.8 live rear axle 3.55. First time builder!
