Results 1 to 1 of 1
Thread: For Sale - FFR2086
    Senior Member Todd Baumann's Avatar
    Howell Michigan
    For Sale - FFR2086
    Sale suspended - I appreciate everyone looking but an idiot at work the other day crashed into my car. I don't fell right trying to sell it to anyone in this condition so until it is finally fixed it will be off the market.
    For Sale: FFR MKI 2086. Purchased in December of 1999 and completed April 2000.
    Completely re-done in 2013. Price: $47,000 Negotiable, / for forum members $42,500
    The car has less than 20K miles on the odometer.
    It is registered and titled in Michigan as a "1965 Cobra Replica."
    This was originally a Donor build and last year it was completely rebuilt and powdercoated.
    The only used items on the car still are the rear axle housing and pedal box. Everything else has been changed out over the years and is now new or newer.
    This car is immaculate, show quality, and completely sorted.
    ENGINE AND DRIVELINE:
    Levy Racing Stage 5 408/351 Windsor, 540 HP, 550 ft/lb Torque Can run on 91 octane pump fuel but has on 93 minimum,
    steel crank, forged I-beam rods, forged pistons, Victor Jr. heads, custom hydraulic roller cam, Victor Jr. intake, 6000 rpm shift point, 6500 rpm rev limit
    Speed Demon 750 cfm double pumper carb, Chrome air cleaner, Mr Gasket welded aluminum valve covers.
    Canton Thermostatically controlled oil filter adapter and remote AFCO oil cooler Chrome Powermaster one wire Alternator with March V-belt pulleys
    and brackets Champ 7 qt oil pan w chrome dipstick MSD 6AL Ignition and Blaster 2 coil with Taylor 10.4 wires.
    New Stock fuel tank kit with Granatelli AN fitting fuel pick up, Holley electric "Blue" fuel pump, Fram HP1 fuel filter,
    Holley Regulator Fuel lines are polished stainless steel w/8 AN fittings and toggle shutoff switch,
    6an return line is in place for EFI conversion but not being used
    Gas-N Stainless Steel side pipes with Factory Five 4 into 1 headers Lakewood bell housing with Weber Heavy Duty clutch and Forte clutch extension bracket. Tremec 3550 5 speed manual transmission with 0.82 overdrive, Pro 5.0 Shifter
    Denny's Drive Shaft aftermarket drive shaft and Summit Racing Driveshaft safety loop
    Ford 8.8" solid axle housing shortened approx 4" with 5 lug axles, 3.27 rear gears, aluminum Differential cover with cap screws
    COOLING AND HEATING:
    Afco Aluminum Radiator with Breeze fan shroud and electric fan with thermostatic control and manual override
    Factory Five Stainless overflow tank
    Vintage Air Compact heater and defroster all mounted behind firewall
    BRAKES, SUSPENSION, WHEELS AND TIRES:
    5-lug SN95 front hub kit, Factory Five MK IV tubular lower front control arms and adjustable upper control arm assemblies
    David Borden's Steering Axis Inclination kit (SAI), Forte's Front 3/4" Anti sway bar
    Factory Five Flaming River manual rack and pinion steering kit 15:1
    Factory Five adjustable Koni coil-over shocks and Springs
    Mustang standard mounted emergency brake handle and cables.
    Ford Mustang 2 piston front calipers with cross drilled and vented rotors
    93 Cobra brake master cylinder with roll control selinoid
    Russ Thompson gas pedal with AC Cobra pedal pads on all pedals
    SN95 rear Mustang rotors and calipers
    Factory Five 3-Link adjustable rear suspension
    Compomotive wheels, Halibrad 5 lug replicas with spinners, 17x9 front with 245/45/17 BFG KDWS and 17x11.5 rear with new Nitto 555R 315/35/17 tires
    2nd Set of wheels and tires, Team III's with spinners and lug covers and BFG R1 tires, same sizes as others.
    Used once. (Will entertain seperating)
    (2) Nitto NT05 315/35/17 Drag Radials, not mounted (Will entertain seperating)
    ELECTRICAL:
    FFMetal trunk mounted battery box with new Optima Yellow Top battery, Keyed removable battery cutoff switch
    Painless wire harness with Painless braided black wire loom
    Autometer Classic electric gauges with cable driven Speedo
    FFR Ignition Switch, toggles, and light switch. Remote mounted battery posts.
    3 - under dash 12V accessory outlets
    INTERIOR:
    Dynamat Extreme covered cockpit, firewall and trunk
    Custom Firewall Forward kit and Engine bay Close out panels
    Russ Thompson Radiator aluminum upper cover
    Breeze seat installation kits with adjustable seat tracks
    Sube Classic roadster seats with Simpson 5 point harnesses and chrome trim rings
    Carpet (100% nylon pile)
    Black Factory Five dash with Competition guage layout covered in Vinyl
    427 reverse lockout replica shifter handle
    Autometer integrated Shift light with adjustable pills
    Herb's Custom door panels with pockets in black leather
    Factory Five sun visors and wind wings
    Factory Five Leather wrapped steering wheel
    Factory Five Wood Steering wheel
    ********** Windshield remote mount rear view mirror
    Cobra Earl's drop trunk kit and full carpet
    EXTERIOR:
    Factory Five chassis and aluminum - All Powdercoated Bengal Sliver
    Factory Five Chrome roll bar -drivers side only with Russ Thompson roll bar groumets and trim rings chromed
    Custom Paint and Bodywork - '94-95 Lambo Frost Titanium Silver with Ghost stripes top and bottom of hood and trunk
    Standard body mounts for hood, trunk, and doors
    Whitby side louvers, polished Chrome quick jacks front and rear, with ********** front groumets
    Aftermarket Lexan MR10 windshield
    Tri-State's Tonneau Cover
    Whitby soft top and side curtains
    Thanks for looking.
    Todd Baumann
    [email protected]
    8(one)0-93(one)-7276
    [IMG][/IMG]
    Last edited by Todd Baumann; 09-11-2014 at 05:02 PM. Reason: new price forum members
    Todd Baumann
    FFR Build School Instructor 16+ Years Mott Community College
    FFR 2086 MKI, 22+ years on the road
    FFR 300 MKI Coupe
