Results 1 to 3 of 3
Thread: Alignment
    Senior Member Tocoti's Avatar
    Rochester NY
    Alignment
    Hey all! I'm going to get the front end alignment. I'm using the manual steering specs. -1 camber, 3 on the caster. I'm in upstate NY . I'm wondering where you put your road crown correction in and if you like it. I was thinking of putting an extra half degree in the right caster. Any thoughts?
    That's fine on a two lane road but it's not so helpful on an interstate running in the left lane. So I never do it.
    I wouldn't do it. The roads are not that standardized IMO. I don't see a significant benefit. WEK.
